POV-Ray : Newsgroups : povray.binaries.scene-files : iterative imaging 3 Server Time
27 Mar 2026 00:26:23 EDT (-0400)
  iterative imaging 3 (Message 1 to 10 of 12)
Subject: iterative imaging 3
Date: 23 Feb 2008 01:22:06
Message: <47bfbb8e@news.povray.org>
Basic instructions are included in the .pov. Have fun with it!
Sam
Download 'us-ascii' (2 KB)
Subject: Re: iterative imaging 3
Date: 23 Feb 2008 02:05:00
Message: <web.47bfc58db272b0105676ec960@news.povray.org>
"good luck"... huhuhuhu
I never really played around with fractals.  But it surprises me the fractal
patterns weren't used, being instead a simple radial transformed... O_o
Date: 23 Feb 2008 04:16:05
Message: <47bfe455@news.povray.org>
   Shouldn't this have a warning about hypnotic/addictive effects on the
subject? Please, I've scenes to finish this weekend! ;)
Jaime
Date: 23 Feb 2008 10:57:31
Message: <47c0426b$1@news.povray.org>
In the process of trying to understand what you did,
I tried to clean up your code and then I modified it a bit.
Here's my modifications if anyone is interested.
(The code should work in the same way.)
Tor Olav
http://subcube.com
Download 'us-ascii' (3 KB)
Date: 23 Feb 2008 18:30:49
Message: <47c0aca9$1@news.povray.org>
That's my idea of a disclaimer ;)
Correct me if I'm wrong, but isn't an IFS fractal built in a similar
fashion?
Sam
Date: 23 Feb 2008 18:32:25
Message: <47c0ad09$1@news.povray.org>
Ha, it does that to you too? It's fun plugging new numbers into the seed
to find that next unique combination.
Sam
Date: 23 Feb 2008 18:37:30
Message: <47c0ae3a@news.povray.org>
Hm, is frame_number a a built-in variable? Good work on the code.
I'm thinking of posting another version I worked on last night which
helps prevent the image from becoming dark over time.
Sam
Date: 23 Feb 2008 18:48:04
Message: <47c0b0b4$1@news.povray.org>
Yes it is.
http://povray.org/documentation/view/3.6.1/228/#frame_number
Date: 24 Feb 2008 04:03:39
Message: <47c132eb$1@news.povray.org>
   I did more than that... I first separated the coloring to a new seed, and
then I started to use other patterns instead of radial. I got very
interesting results with quilted, crackle and bozo patterns. I also changed
the filter to 2 to avoid some of the darkening in the iteration.
   Thank for a lost but funny Saturday! ;)
Jaime
Date: 29 Feb 2008 09:50:01
Message: <web.47c81a60b272b0108cb754d0@news.povray.org>
> fashion?
> Sam
Yes it is.  In fact, a special case of what you've done is what Barnsley called
the "condensation set" of an image under an IFS.  Just to be sure, I recreated
a bunch of Barnsley's pictures from "Fractals Everywhere" using your technique.
So, THANKS!  This is just what I've been looking for; it should allow me to play
with "Superfractals" (Barnsley's next book) using POVRay.  Also, since other
shapes, patterns, transforms can be iterated, there are many generalizations to
the old linear examples that can be added.
I'd been puzzling over ways of getting POVRay to do this; why I didn't think to
simply input the previous image as an image map; well, that's because some
people are creative (like you), and some, well, less so.  One technique I had
tried that produced some of what I wanted, but not most, was to recursively
call the "checker" pattern.  I might revisit it now, just to see if the new
insights I got from figuring out your technique add anything to it.
Anyway, once I find a few things I like, I'll toss them up in PBI to add to the
collection, unless they're just a lot uglier than what others do.
Dave
