POV-Ray : Newsgroups : povray.binaries.scene-files : Triscan Macro File Server Time
19 May 2024 21:21:46 EDT (-0400)
  Triscan Macro File (Message 1 to 2 of 2)
Subject: Triscan Macro File
Date: 11 Mar 2000 23:01:44
Message: <38CB12D0.732F7F15@enter.net>
Triscan.mcr is a macro definition file designed to work with
MegaPOV's new features, such as trace(), min_extent, max_extent,
and so forth to produce a simulated surface scan of a #declared
POV object, and export it as a triangle mesh in RAW or LSL
format. RAW files can then be converted with programs such as
3DWin or Crossroads to a number of other formats, and LSL files
can be directly imported into the Leveller height field editor.
Using this macro, I have...
 - Scanned POV objects and imported medium quality wiremeshes of
   them into Rhinocerous and Poser as imported/prop objects. These
   can then be used for helping to shape, pose, and scale creations
   you intend to import back into POV-Ray for use with the original
   models.
 - Scanned POV objects and made them into Moray UDOs ... even in
   cases where the primitives are not supported by Moray -- such as
   julia fractals (which greatly expands the range of what you can
   use in Moray)
 - Scanned simple POV-Ray objects into Leveller reference shape
   files. This would allow you, for example, to make a house, wall,
   bridge, or whatever in POV-Ray script, then import a reference
   shape of it into Leveller to use to sculpt a landscape around,
   and reimport that height field back into POV for use with the
   original models.
What this file CAN'T do...
If you're looking for a high quality tesselation that can be used in
other rendering engines and will produce exact copies of POV-Ray
objects, THIS ISN'T IT. This technique which uses the trace()
function in MegaPOV tends to lose enough detail and suffers from
a few inherant problems that I feel could only be solved by internal
access to the primitive's native parameters and tesselation routines
that would probably be too complex for POV script, or anything but
a binary patch. The meshes this produce can be low quality for a
quick and dirty reference shape, or even medium to fair quality,
if you're will to wait a bit longer, but for full quality POV-Ray
primitives, I'm afraid this is just not a substitute. Still, it
may have its uses, so here it is.
Download 'triscan.zip' (15 KB)
Subject: Re: Triscan Macro File
Date: 14 Mar 2000 17:53:52
Message: <38CEC374.AEE37973@enter.net>
Fabian BRAU wrote:
> Your macro for Moray user is very very great!
> Very good job!
Thank you!
> So I just ask you if I can use your freeware macro Triscan for this
> purpose!
> In the doc of povray, the team say that everyone can use it (povray)
> freely for commercial or non-commercial purpose!
Fabian: absolutely. Just to make it official, all source code,
utilities, macros, etc that I release, including Triscan are free
for all derivative uses, just like POV-Ray itself. By all means,
any use you can think to put Triscan to you are welcome to do so.
I hope it will serve you well.
And good luck on the game you mentioned. It sounds very intriguing.
Myst/Riven style games are of course my favorite, being a fan of
both exploring and making raytraced worlds. I would be interested
to see how it turns out!
Cheers!
Charles
