POV-Ray : Newsgroups : povray.binaries.programming : Blueprint output Server Time
20 May 2024 05:27:42 EDT (-0400)
  Blueprint output (Message 1 to 4 of 4)
Subject: Blueprint output
Date: 12 Apr 2005 07:55:00
Message: <web.425bb62a9e52cc2f420f83140@news.povray.org>
Hi, folks!
you will hang me for the question. The idea is, to have a render output
option for making blueprints of the scene, like the wireframe- or edge-view
option in other programs. Something like the +UD option, but for the shapes
insted of the bounding boxes.
would be a great help when making real huge buildings and such things, to
have a bluprint where you can write down measures and distances and such.
Just thinking .... ;-)
Steely
Subject: Re: Blueprint output
Date: 12 Apr 2005 10:26:59
Message: <U7F5ADAwo9WCFwTV@econym.demon.co.uk>
Wasn't it Steely who wrote:
>Hi, folks!
For a real blueprint, you probably don't want a wireframe of the whole
house, what you want is a slice through the house, like this:
plane {y,0.1
  object
    { House
      rgb <0,0,1>
      rgb 1
Mike Williams
Gentleman of Leisure
Date: 12 Apr 2005 15:05:01
Message: <web.425c1b467809659376e394630@news.povray.org>
workaround to overcome the object pattern limitation of "no texture, no
patches" ?
If I have to construct two buildings, one with, one without textures and
S.
Date: 13 Apr 2005 00:46:55
Message: <sMPHtBAcQKXCFwvo@econym.demon.co.uk>
>patches" ?
It would certainly be easier to change the POV program to remove those
limitations than it would be to get it to produce wireframe renderings
of things like isosurfaces and blobs.
Instead of the object pattern, you could difference the building with a
thin box. The textures from the original building would only appear on
the faces that are perpendicular to the camera, and therefore invisible.
difference {
  box {<-100,0.1,-100><100,0.1001,100>}
  object {House}
  pigment {rgb <0,0,1>}
  finish {ambient 1}
// white bits seen through the hole
plane {y,0 pigment {rgb 1} finish {ambient 1}}
Mike Williams
