Magnatune: We Are Not Evil
  POV-Ray : Newsgroups : povray.binaries.programming : Blueprint output Server Time: 12 Oct 2008 16:16:24 GMT
  Blueprint output (Message 1 to 4 of 4)
Subject: Blueprint output
Date: 12 Apr 2005 11:55:00
Message: <web.425bb62a9e52cc2f420f83140@news.povray.org>
Hi, folks!
I am not a programmer, so I don´t have a clue if this is an easy task or if
you will hang me for the question. The idea is, to have a render output
option for making blueprints of the scene, like the wireframe- or edge-view
option in other programs. Something like the +UD option, but for the shapes
insted of the bounding boxes.
I suppose, it will not be easy, as POVRay doesn´t have polygons, but it
would be a great help when making real huge buildings and such things, to
have a bluprint where you can write down measures and distances and such.
Just thinking .... ;-)
Steely
Subject: Re: Blueprint output
Date: 12 Apr 2005 14:26:59
Message: <U7F5ADAwo9WCFwTV@econym.demon.co.uk>
Wasn't it Steely who wrote:
>Hi, folks!
For a real blueprint, you probably don't want a wireframe of the whole
house, what you want is a slice through the house, like this:
plane {y,0.1
  object
    { House
      rgb <0,0,1>
      rgb 1
Mike Williams
Gentleman of Leisure
Date: 12 Apr 2005 19:05:01
Message: <web.425c1b467809659376e394630@news.povray.org>
Don´t know if this would match in all and any cases, but more important: any
workaround to overcome the object pattern limitation of "no texture, no
patches" ?
If I have to construct two buildings, one with, one without textures and
patches, I´ll better go on with my (ugly hand-drawn) sketches ;-)
S.
Date: 13 Apr 2005 04:46:55
Message: <sMPHtBAcQKXCFwvo@econym.demon.co.uk>
>patches" ?
It would certainly be easier to change the POV program to remove those
limitations than it would be to get it to produce wireframe renderings
of things like isosurfaces and blobs.
Instead of the object pattern, you could difference the building with a
thin box. The textures from the original building would only appear on
the faces that are perpendicular to the camera, and therefore invisible.
difference {
  box {<-100,0.1,-100><100,0.1001,100>}
  object {House}
  pigment {rgb <0,0,1>}
  finish {ambient 1}
// white bits seen through the hole
plane {y,0 pigment {rgb 1} finish {ambient 1}}
Mike Williams
Copyright 2003-2008 Persistence of Vision Raytracer Pty. Ltd.
