POV-Ray : Newsgroups : povray.binaries.programming : A povr tarball for Unix/Linux. Server Time
20 May 2024 08:35:29 EDT (-0400)
  A povr tarball for Unix/Linux. (Message 1 to 10 of 13)
Subject: A povr tarball for Unix/Linux.
Date: 4 Jul 2020 10:37:30
Message: <5f00942a@news.povray.org>
Please find attached my initial attempt at a Unix/Linux tarball for the
povr branch of POV-Ray.
It will unpack into a directory called povray2 due my own development
naming. Supposing you unpack into /tmp/povray2 , it should be you can cd
into that directory and do something like:
./configure COMPILED_BY="wfp" --prefix=/tmp/povr
make
make check
Optionally:
make install
The install size is 4-5MB. There is a script called povr in the root
directory. After a little editing, it can be used to run the compile 'in
place' or from an 'installed' compile result. Copy povr to your bin
directory or otherwise get it into your $PATH. After which, unix help:
povr --help
There are a couple of scenes in the scenes directory which should run
with 'povr fog.pov', say, once you have the povr script set up. A
reminder povr, often as not, breaks compatibility with existing POV-Ray
scenes.
A work in progress, but it's getting there. At this point I'm mostly
interested in whether others can get through 'make check' OK given the
necessary development libraries are installed local to your machine (see
./unix/README.md).
Bill P.
Download 'povray2_f9bc4ef7.tar.gz' (1641 KB)
Subject: Re: A povr tarball for Unix/Linux.
Date: 4 Jul 2020 11:35:00
Message: <web.5f00a13ed1e52a784d00143e0@news.povray.org>
hi,
> make
disp_x11.cpp:53:57: fatal error: xpovicon.xpm: No such file or directory
a quick 'find' confirmed that the icon's missing.
regards, jr.
Date: 4 Jul 2020 12:10:00
Message: <web.5f00a8bdd1e52a784d00143e0@news.povray.org>
hi,
> ./unix/README.md).
found a 'xpovicon.xpm' in the 3.5c source, copied that, and both the make and
make check went through.
thanks.  will play with it, a little, over the coming days.
regards, jr.
Date: 5 Jul 2020 07:50:57
Message: <5f01bea1$1@news.povray.org>
Thanks much! In my testing I only needed the .xbm files. Must of only
searched for xbgmap.xpm when deciding to lose both the *.xpm files...
Aside: In the whither thread you gently tossed an arrow at the Simple
DirectMedia Layer use. I've done a little debug work around 1.2 hangs
and povr/hgpovray have SDL2.0 and x11 support thanks to Jerome.
https://github.com/POV-Ray/povray/issues/118
https://github.com/POV-Ray/povray/issues/142
My understanding is that SDL1.2 was chosen for v3.7 because of problems
with x11 at the time - which perhaps are not all that different from
what we still see with x11 today.
In my povr/POV-Ray use all three display options still have issues with
x11 being the worst behaving. The x11 and SDL1.2 options suffer from
occasional hangs requiring a kill command to stop with x11 being worse.
Not seen the hangs in SDL2.0, but there is once in a while a had row of
pixels usually in the upper left on scaling to fit a window. I recommend
SDL2.0 use today if you have a choice.
Others can speak to it better than me, but I believe some of the issues
come to our code architecture being non-standard with respect to
interface handling. It would be more normal to have x11/SDL - or
whatever interface handler be the main loop from which everything else
is spawned.
Bill P.
Date: 5 Jul 2020 11:15:01
Message: <web.5f01ed40d1e52a784d00143e0@news.povray.org>
hi,
> > make check went through.  ...
> Thanks much!
a real pleasure, actually.  (see below)
> DirectMedia Layer use. ...
that, I think needs .. re-stating.  :-)
I'm not a betting person, but would put good money on: if you were to create a
VM and installed either Slackware (of course!  :-)) or some BSD-derived Linux,
or Solaris, you'd find no "problems with x11"[*].  I think that rather than from
the X Windows system, problems will occur when using a Ubuntu.  (Mark
Shuttleworth tried too hard to become the "cock on the midden"  :-))  (although,
having said that, who knows, perhaps it goes back to Debian)
[*] that's not to say that the API isn't .. cumbersome, or perfect.  O'Reilly
published a really good set of references to X11R5 and X11R6.
well now, "povr -y x11 ..." works beautifully here.  :-)  the only difference I
see is that the x11 gives me window that starts with a transparent background,
while the (default) SDL2 window is black when empty.
and _I_ really like that the X functionality is making a comeback.
first impressions, have only run a handful of scenes for quick trying out that
it "just works".  fully installed ~4.2M -- nice!  it feels quite .. sprightly,
the difference to the 10064268.alpha seems to be ~5% faster parse and ~10%
faster render.
I'll play some more in the week, then post a list of .. issues.
regards, jr.
Date: 10 Jul 2020 11:15:01
Message: <web.5f088567d1e52a784d00143e0@news.povray.org>
turns out that, so far, there are only two things on that list.  :-)
one is that 'povr' displays "povray: I/O restrictions are disabled".  confused.
the 'povray.conf' file contains (edited):
[File I/O Security]
;none       ; all read and write operations on files are allowed.
;read-only  ; uses the "read+write" directories for writing (see below).
restricted  ; uses _only_ "read" and "read+write" directories for file I/O.
; [Shellout Security] determines whether POV-Ray will be allowed to call
; scripts (e.g. Post_Frame_Command) as specified in the documentation.
; Specify one of the 2 following values:
; - "allowed" means that shellout will work as specified in the documentation.
; - "forbidden" means that shellout will be disabled.
[Shellout Security]
;allowed
forbidden
have not yet tested whether it's just the displayed info.
the second problem is a "third party" scene which fails:
==== [Parsing...] ==========================================================
FILE FOUND - Including ../...../L_01_04.inc
File '/home/jr/POVr/share/povray-3.8/include/transforms.inc' line 92:
Parse Error:
Cannot pass uninitialized identifier to non-optional LValue.
Fatal error in parser: Cannot parse input.
Render failed
that scene works fine with 10064268.alpha.
have not, so far, found the time to re-read the various newsgroup posts wrt
'povr' specific features and changes[*], so will probably use it just as an
alternative to the 10064268.alpha.
[*] maybe you can put all those together, in some text file.
regards, jr.
Date: 10 Jul 2020 14:16:39
Message: <5f08b087$1@news.povray.org>
> Parse Error:
> Render failed
Thanks! The first and likely the second issue(2) are the same problem.
There were updates to the code so that "make check" less often fails or
is fooled by a previous install on the system doing the compile. Say an
existing 'system level' functions.inc, a user setting of POVINI or
whatever. Those changes required the introduction of a new internal only
environment variable which when set (I think) turns off all the normal,
nearly fanatical internal attempts to find existing .conf, .ini and .inc
files(1) with which to run.
I screwed up the setting of the variable in the Makfile - and then
covered up that mistake with another in the code hiding the fact I'd
broken the normal setting of paths given I usually run with an uncommon
POVINI setting. I believe the issue now fixed in my code.
(1) - Related. I am taking a run at no longer installing .conf and ini
defaults in a user's HOME directory. Doing this makes it hard to run
several POV-Ray versions side by side - though I have hacks to do it.
(2) - It might also be this second case is some actual incompatibility.
I've made changes so more often the code will kick out the actual
offending identifiers to make things easier to debug. On removal of old
keywords, for example the errors should complain about the specific
keyword. It's obviously still not reporting the identifier in your case.
Aside: Some of the bad command line flag / ini setting errors are now
being reported too where they've long not been on unix platforms. Jerome
added a workaround years back to kick out the command line text on
errors, but that's less helpful than getting the more specific error text.
(*) - It's a hack at the moment, but I do have a povrTextDocumentation
directory in the root compilation directoy which includes primarily
areas of povr different than POV-Ray. If something exists there, it
behaves differently in some way from the official POV-Ray. The
exceptions to this rule in the inbuilt function changes are all
documented in functions.inc and the density file stuff is on the wiki.
Bill P.
Date: 10 Jul 2020 15:20:00
Message: <web.5f08bdced1e52a784d00143e0@news.povray.org>
hi,
looking forward to your posting an updated version.
agree that a user 'povray.conf' is not needed/useful.
feel different about the 'povray.ini', find it convenient to have a set of
defaults, for that login, which I can override on a case-by-case basis.  (could
you not install a 'povr.ini' in '~/.povray/3.8/'?  would get round the naming
issue)
I'll be happy to try that scene again, after installing the update.
ok.  I had hoped for something included in the tarball.
and another "rant" :-), this time regarding the install locations.
what is wrong with '/usr/local/doc/'?  what is the rationale for
'/usr/local/share/doc/' and '/usr/local/share/man/'?  it cannot be the "shared"
aspect, because then, logically, other shared directories would belong there
too, eg '/usr/local/share/bin/'!  plain weird.  (and yes, I know it's an Ubuntu
thing, not your decision, per se)
regards, jr.
Date: 11 Jul 2020 05:35:00
Message: <web.5f0986ffd1e52a784d00143e0@news.povray.org>
hi,
have still not seen any "hangs", but managed to get an error; when beginning
render of 2nd frame in animation.
povr +L/usr/local/share/povray-3.8/include +a0.1 +w960 +h720 \
        +o/tmp/render/frm_ +iTorusKnotMinimal35.pov +kc +kfi0 +kff359
X error: BadLength (poly request too large or internal Xlib length error)
.... [message repeats another eight times]
[xcb] Unknown sequence number while processing queue
[xcb] Most likely this is a multi-threaded client and XInitThreads has not been
called
[xcb] Aborting, sorry about that.
povray2: xcb_io.c:259: poll_for_event: Assertion
`!xcb_xlib_threads_sequence_lost' failed.
/home/jr/bin/povr: line 14: 845235 Aborted    ${INSTALLDIR}/bin/povray2 -y x11
regards, jr.
Date: 11 Jul 2020 10:26:13
Message: <5f09cc05$1@news.povray.org>
On 7/11/20 5:31 AM, jr wrote:
> hi,
> called
> regards, jr.
Thanks. I've not done any animations with the x11 display. I'll try it
myself later today. I'd make a moderate bet from your output it's again
the architectural problem of x11/sdl* not being at the top thread-wise,
so to speak.
Bill P.
