POV-Ray : Newsgroups : povray.binaries.programming : call megapov in Matlab, but where is the pic generated from megapov? : Re: call megapov in Matlab, but where is the pic generated from megapov? Server Time
25 Jan 2026 18:43:57 EST (-0500)
Date: 12 Jul 2012 04:10:01
Message: <web.4ffe85d3b8031fa793fd1c190@news.povray.org>
> Enzo, the answer to your question is contained on your post two times!>
> > !"C:\Program Files\POV-Ray for Windows v3.6\bin\MEGAPOV"
> > +I"E:\Dropbox\POV ray\2012.07.10\Tree Model_only
> > Leafs_no_shadow08.pov" +O"E:\Dropbox\POV ray\2012.07.10\a.bmp"
> > +L"C:\Program Files\POV-Ray for Windows v3.6\include" +W800 +H600
>    Here the command line contains the output file name, explicitly set to
> "E:\Dropbox\POV ray\2012.07.10\a.bmp".
> > Output Options Image resolution 800 by 600 (rows 1 to 600, columns 1
> > to 800). Output file: E:\Dropbox\POV ray\2012.07.10/\Dropbox\POV
> > ray\2012.07.10\a.bmp,
>    And here again, the renderer tells you about it on the messages window...
> > I thought that might the problem "Graphic display......Off ", but how
> > can i turn on it?
>    No, that was not the problem, but anyhow you can turn display on
> adding +d on your command line.
>    Regards,
> Jaime
Hi Jaime,
I redo the coding and did like you said, and the mega generate the pic
but i can not open it, and the message like this:
Support libraries used by POV-Ray:
  ZLib 1.2.3, Copyright 1995-1998 Jean-loup Gailly and Mark Adler
  LibPNG 1.2.8, Copyright 1998-2002 Glenn Randers-Pehrson
  LibJPEG 6b, Copyright 1998 Thomas G. Lane
  LibTIFF 3.6.1, Copyright 1988-1997 Sam Leffler, 1991-1997 SGI
Redirecting Options
  All Streams to console..........On
  Debug Stream to console.........On
  Fatal Stream to console.........On
  Render Stream to console........On
  Statistics Stream to console....On
  Warning Stream to console.......On
Parsing Options
  Input file: E:\Dropbox\POV ray\2012.07.10\Tree Model_only Leafs_no_shadow08.po
v (compatible to version 3.61)
  Remove bounds........On
  Split unions.........Off
  Library paths:
Output Options
  Image resolution 800 by 600 (rows 1 to 600, columns 1 to 800).
  Output file: E:\Dropbox\POV ray\2012.07.10/Tree Model_only Leafs_no_shadow08.b
mp, 24 bpp Targa
  Graphic display......On  (gamma: 2.2)
  Mosaic preview.......Off
  CPU usage histogram..Off
  Continued trace......Off
Tracing Options
  Quality:  9
  Bounding boxes.......On   Bounding threshold: 25
  Light Buffer.........On
  Vista Buffer.........On   Draw Vista Buffer....Off
  Antialiasing.........Off
  Clock value:    0.000  (Animation off)
  0:00:00 Parsing
  0:00:01 Parsing 297K tokens
  0:00:02 Parsing 2405K tokens
  0:00:03 Parsing 4486K tokens
  0:00:04 Parsing 6267K tokens
  0:00:05 Parsing 8250K tokens
  0:00:05 Creating bounding slabs
  0:00:05 Creating vista buffer(null)
  0:00:05 Creating light buffers
  0:00:05 Creating light buffers 9232K tokens
Scene Statistics
  Finite objects:         8305
  Infinite objects:          0
  Light sources:             0
  Total:                  8305
  0:00:00 Displaying
                (null)
                  (null)
                    (null)
                      (null)
                        (null)
                          (null)                                  .........
                            (null)                               ..   ........
...                              (null)                             ..
...................                           (null)                          ..
.... ................                           (null)
.... ............. ......                            (null)
  0:00:01 Displaying line 292 of 600(null)                        .... ... ...
..  ..........                         (null)                       ... . ...
     ..........                         (null)                             .
         .. ... .                         (null)                          .....
           . .....                          (null)                           . .
 ..             .                             (null)
              .                                 (null)
                                                  (null)
                                                    (null)
                                                      (null)
                                                        (null)
                                                          (null)
                                                            (null)
  0:00:01 Postprocessing Phase 0, line 0
  0:00:01 Done Tracing
Render Statistics
Image Resolution 800 x 600
Pixels:           480000   Samples:          480000   Smpls/Pxl: 1.00
Rays:             480000   Saved:                 0   Max Level: 1/5
Ray->Shape Intersection          Tests       Succeeded  Percentage
Disc                            185440           57549     31.03
Bounding Box                   1203270          646763     53.75
Vista Buffer                   5352939         3105899     58.02
Calls to Noise:                   0   Calls to DNoise:              10
Smallest Alloc:                  18 bytes
Largest  Alloc:               94256 bytes
Peak memory used:           8009158 bytes
  0:00:01 Reclaiming memory
Total Scene Processing Times
  Parse Time:    0 hours  0 minutes  5 seconds (5 seconds)
  Photon Time:   0 hours  0 minutes  0 seconds (0 seconds)
  Cloth Time:    0 hours  0 minutes  0 seconds (0 seconds)
  Mechsim Time:  0 hours  0 minutes  0 seconds (0 seconds)
  Render Time:   0 hours  0 minutes  1 seconds (1 seconds)
  Postpr. Time:  0 hours  0 minutes  0 seconds (0 seconds)
  Total Time:    0 hours  0 minutes  6 seconds (6 seconds)
I dont understand what the "null" is, would you See this for me?
Thank you
Aenzo
best regards!
