![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Because the pattern has the feature of wood-cell-fiber, it is good to see the
interesting pattern.
The side section diagram:
Download 'cracke test 5 side.png' (2272 KB)
Preview of image 'cracke test 5 side.png'
![cracke test 5 side.png](/povray.binaries.images/attachment/%3Cweb.65a7e5c160c048b3f7e60deeaa81652d%40news.povray.org%3E/cracke%20test%205%20side.png?ttop=443824&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yes, interesting - and cool looking. Hopefully I can spend a little time
looking more at how this works.
Bill P.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Bill P.
I can explained it a little to save your time.
This is the first time I explore the f_crackle(x,y,z) pattern(in fact, I have
question to ask).
step1:
The "f_crackle_base" is a crackle pattern, I substract "f_crackle" from "1" for
I needing a 1.0 (white) value threads(voronoi border) filled the space. Then
power(.., 4) to make the thread thiner.
Download 'voronoi border.png' (693 KB)
Preview of image 'voronoi border.png'
![voronoi border.png](/povray.binaries.images/attachment/%3Cweb.65a91aef60c048b3f7e60deeaa81652d%40news.povray.org%3E/voronoi%20border.png?ttop=443824&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
My question is: Does POV-Ray have another version of voronoi pattern to use? I
said "Worley noise"
As a function?
step2:
multiply "f_crackle_base" to a f_bumps(x,y,z) noise, the "f_bumps" noise should
change its relative size to "f_crackle", so I #declare bum_size to adjust it.
#declare f_test(x,y,z) =
function(x, y, z) {
f_crackle_base(x,y,z) * f_bump_base(x,y,z)
The "f_test" pattern:
Download 'f_test.png' (664 KB)
Preview of image 'f_test.png'
![f_test.png](/povray.binaries.images/attachment/%3Cweb.65a91e0760c048b3f7e60deeaa81652d%40news.povray.org%3E/f_test.png?ttop=443824&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
step3:
f_disturb_bump(x,y,z) is another bumps pattern (It has two frequency). I wish
use it to disturb the "f_test" function, so I tried some combine method + - *
And this one is awesome. When I see I feel... great.
#declare f_output2 =
function(x, y, z) {
f_test(
x , y,
pow(
(x*x + y*y)/ (f_disturb_bump(x, y, z)+1)
, 0.75)
----------- ending -------------
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> said "Worley noise"
> As a function?
First, thanks for the break down of how what you've done works.
On the Worley noise... The answer given has been that it can be
duplicated with some set up of our crackle pattern, but I confess I've
never looked closely enough to know if this is exactly so. Let me see if
I can turn up references... Yes.
Ingo mentions the worley capability in the first post of this thread
(and I'd guess from the whole thread blob based potential pattern of
v3.8 might be able to emulate it too):
https://news.povray.org/povray.general/thread/%3CXnsAED66DFB68413seed7%40news.povray.org%3E/
Another thread from 2017:
https://news.povray.org/povray.general/thread/%3Cweb.5886420fb6cdab0dc437ac910%40news.povray.org%3E/
Having glanced at those threads wondering if yuqk's updated ripples and
waves patterns might be a partial path too.
https://news.povray.org/povray.pov4.discussion.general/thread/%3C6415c37b%241%40news.povray.org%3E/
But again, I've never really looked at what others are calling Worley
noise. Often with things like this there is sort of a base concept with
lots of tuning / customization capability piled on top. What one person
'calls' Worley noise might not be quite what someone else 'calls' Worley
noise.
Aside: The craters discussion happening now in another thread reminded
me that a long time ago I created an craters image based on crackle
where I might have, more or less, stumbled upon a near 'worley' set up.
Unfortunately, searches just now failed to turn up the work. Piles and
piles of of half backed projects from days gone by... :-)
Ah, I'd guess this link might help too when looking at crackle's form
vector:
https://www.imagico.de/pov/cr_form_en.php
especially maybe the javascript link on that page.
Bill P.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 1/19/24 06:23, William F Pokorny wrote:
> As a function?
Hit me while getting coffee this morning I didn't answer your second
question.
You can turn any pattern into a function of your own with something like:
#declare FnCrackle = function { pattern { crackle form <-1,1,0> ... }
The bit wrapped in pattern{} there can be any sort of valid pattern
specification as you'd set up for *_map use.
When you use something like 'f_crackle() in the official releases of
POV-Ray, what your are really getting is a shipped user defined function
coded at the bottom of functions.inc - and these are very simple
implementations like:
#declare f_crackle = function { pattern {crackle} }
with no provided ability to set options(a).
Bill P.
(a) - This one of the shortcomings I've worked some to address in my
yuqk fork / v4.0 suggestions. While I've not gotten to crackle, there
is, for example, a true inbuilt f_agate() implementation which makes
available all the options of the inbuilt pattern 'agate' as parameters
(and a few additional options).
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > As a function?
> question.
Thanks for your reminder. Although I ever use function {pattern {...}}, but I'm
not very familiar with it, so I forgot this a lot.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks for finding that link to clipka's response. I did several searches for
that thread, and as usual, nothing came up.
Here's a coverage of Worley noise and some derivative projects.
https://thecodingtrain.com/challenges/c4-worley-noise
- BW
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > said "Worley noise"
> > As a function?
> noise.
> vector:
> Bill P.
Yes, you are right! It is just function {pattern {crackle form <1,0,0>}}
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
