![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thomas de Groot <tho### [at] degroot org> wrote:
> Op 17-1-2024 om 04:40 schreef Samuel B.:
> > There will always be some stretching, since not all objects will be boxes or
> > superellipsoids aligned to one sole direction. You have to do your
> > transformations before applying the triplanar mapping.
> Sam, I am very happy with this final development, thank you very much
> for your efforts!
No problem, Thomas. It was a fun exercise :)
I tried to tackle craters today, with mixed success. It's a surprisingly
difficult thing to model. Attached is an attempt to make a surface suitable for
close up shots. I went a bit overboard with the hills and small-scale noise, and
as a result the craters sort of got lost. (But that happens in real life as
well, if you've taken a close look at some of the Apollo moon landing photos.)
Sam
Download 'crater-map-height-test2m_13s.jpg' (101 KB)
Preview of image 'crater-map-height-test2m_13s.jpg'
![crater-map-height-test2m_13s.jpg](/povray.binaries.images/attachment/%3Cweb.65a9bce35a76cfb716bed5696e741498%40news.povray.org%3E/crater-map-height-test2m_13s.jpg?ttop=443824&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Triplanar Mapping - to: Bald Eagle, Sam, and Kenneth
Date: 19 Jan 2024 07:34:46
Message: <65aa6c66$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Op 19-1-2024 om 01:05 schreef Samuel B.:
Maybe a little overdone at this scale but somehow I think the
crater-feeling is there. Maybe going for larger structures first might help?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 19 Jan 2024 11:59:04
Message: <65aaaa58$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> for your efforts!
> Sam
That's pretty good.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Bald Eagle" <cre### [at] netscape net> wrote:
> Nice work - that's looking really good! :)
> So now here's a question - while trying to hunt down an answer to WFP's default
> importance question, I stumbled upon a thread where clipka discusses
> pleochromism.
> https://en.wikipedia.org/wiki/Pleochroism
> I know that I've brought up the topic of wet paper in the past in this regard.
> It seems that this approach might also make for a good anisotropic effect if we
> roll some layered texturing + filter/transmit into it?
> What do you think?
> - BW
> (You wouldn't believe how hard it is to find an example image of this effect)
For photographic examples, maybe look up tourmaline and axinite/ferroaxinite.
It's an interesting problem. I think rendering pleochromism accurately would
require access to POV-Ray's shader system at a level not exposed to the end user
(i.e., the source code would have to be altered). But maybe you could do as you
seem to suggest, and try using a slope pattern to drive two textures with
differently filtered pigments.
This and other types of special optical effects (such as chatoyancy) are things
most renderers have trouble with. I expect to see such effects supported by
future renderers as time goes on.
Sam
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > I tried to tackle craters today, with mixed success. [...]
> Thomas
There's a sweet spot I want to hit, something around the scale one might see
depicted in a moon landing photo.
I managed to get the scale closer to what I want (see attached image), but it's
still a bit too close up.
Sam
Download 'crater-map-height-test0m_37s.jpg' (168 KB)
Preview of image 'crater-map-height-test0m_37s.jpg'
![crater-map-height-test0m_37s.jpg](/povray.binaries.images/attachment/%3Cweb.65adc47d5a76cfb716bed5696e741498%40news.povray.org%3E/crater-map-height-test0m_37s.jpg?ttop=443824&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Alain Martel <kua### [at] videotron ca> wrote:
> > [...] craters today [...]
> That's pretty good.
Thanks Alain.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 22 Jan 2024 02:26:45
Message: <65ae18b5@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Op 22/01/2024 om 02:27 schreef Samuel B.:
Well, this is almost reaching a Wow-effect :-) Very well done indeed,
Sam! I am impressed with the casual (?) way in which you seem to
generate such things...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Both of your images look really great, like the surface of asteroids--from the
photos that have been returned from spacecraft that have actually made landings.
Your result looks like an accumulation of loosely-held debris that has been
pulverized by micro-meteoroids over eons of time. Nice!
I still have a soft spot for those quaint old sci-fi movie depictions of
sharp-edged craggy mountains and craters on outer-space planets...but alas, that
appearance has been proven false.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 24 Jan 2024 02:09:31
Message: <65b0b7ab$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Op 23/01/2024 om 16:48 schreef Kenneth:
Yes, that was also my impression indeed.
Space is infinite, so maybe.... ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> it would appear that if you wish to rotate your objects you have to put up with
> some issues.
A beautiful effect, Sam!
This image is a candidate for my next wallpaper.
Paolo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
