POV-Ray : Newsgroups : povray.binaries.images : billboard tint Server Time
29 Jan 2026 13:17:05 EST (-0500)
  billboard tint (Message 11 to 20 of 21)
<<< Previous 10 Messages Goto Latest 10 Messages Next 1 Messages >>>
Subject: Re: billboard tint
Date: 3 Nov 2023 21:40:00
Message: <web.65459fe9310e11ef22cdb33dabc9342@news.povray.org>
William F Pokorny <ano### [at] anonymousorg> wrote:
> On 11/3/23 18:25, Mike Miller wrote:
> > my scene is enclosed/surrounded with a mapped sphere object. I did try Alain's
> > idea....same results. I added depth to the billboards but it renders both front
> > and back resulting in a double image. Is there backface culling in POV? ...don't
> > see it in the help files. I'll try a clipped plane just to test.
> There is interior_texture{}.
> I think you could make the normal texture{} completely transparent and
> the interior_texture{} your image map. It should be the first
> intersection on the billboard uses the exterior texture{} and the second
> interior_texture{}.
> Aside: By default texture{} gets used for the interior texture of shapes
> too - if you only specify a texture{}.
> Bill P.
I found the problem. It turns out that if add even a small amount of turbulence
(.3 or more) to the fog definition - it tints the alpha portion of the image
map. I set the turbulence to zero and it cleared it up. I'm not sure why, but it
worked.
Mike.
Download 'plant_sprite_fog_fix.jpg' (88 KB)
Preview of image 'plant_sprite_fog_fix.jpg'
Date: 3 Nov 2023 22:10:00
Message: <web.6545a75a310e11e1f9dae3025979125@news.povray.org>
> worked.
I would guess that it's probably not so much that it "tints" the transparent
portion as it patterns it in a way that the applied turbulence causes it to
mis-match the more distant parts of the scene.
Glad you got it to work out - things like that can drive you crazy.
- BW
Date: 3 Nov 2023 22:40:00
Message: <web.6545ae58310e11ef22cdb33dabc9342@news.povray.org>
> > worked.
> - BW
Thanks,
your deduction makes sense...and yes, it was driving me crazy. :)
Mike.
Date: 4 Nov 2023 00:56:40
Message: <6545cf08$1@news.povray.org>
> worked.
Thanks for the update. Probably true in the official implementations of
fog too, but my in my re-write of it, I left a comment that turbulence
affects short length ray results much more than longer ones.
In any case, glad you are on your way.
Bill P.
Date: 4 Nov 2023 09:15:24
Message: <654643ec$1@news.povray.org>
Op 3-11-2023 om 17:49 schreef Mike Miller:
> After taking some time off from POV, I'm ready to tackle a few new scenes I have
> in mind. One involves a landscape with some foreground vegetation. I started
> collecting some 2D sprite images of moss, grasses, and weeds thinking that I
> could populate the ground with them. I've run into a problem with the
> transparent portion of the png when turning on fog. The fog is tinting the
> billboard shape. I've removed the finish and have tried a variety of things in
> the shader with no success. I can fall back on 3D models if I can't get the
> sprites to work.  Below is what I used to texture this example. I understand
> that the bump statement will not have much of an effect without a finish. Any
> help would be appreciated.
> Thanks,
> Mike.
No /help/ from this side, just the (historical) mention that this
particular fog problem has been around since... prehistory. I first hit
it, I think, sometime in the late '90's or early '20's when I tried to
do exactly what you want to do. At the time I was also directed to use
media instead of fog. Otherwise, there was no satisfying workaround.
Date: 4 Nov 2023 11:15:00
Message: <web.65465edf310e11ef22cdb33dabc9342@news.povray.org>
> > Thanks,
> > Mike.
> Thomas
Same...I do remember trying this before back in the day. I guess I always use a
touch of fog in my scenes. It looks like turbulence 0 in the fog statement
works.
Mike.
Date: 5 Nov 2023 02:07:27
Message: <65473f2f$1@news.povray.org>
Op 04/11/2023 om 16:10 schreef Mike Miller:
>>> Thanks,
>>> Mike.
>> Thomas
> works.
> Mike.
Yes, that seems a nice workaround indeed. Very strange. I do not
recollect that it was mentioned at the time; probably not...
Note to self: add a note to Notes... ;-)
Date: 6 Nov 2023 10:26:14
Message: <65490596$1@news.povray.org>
> Note to self: add a note to Notes... 😉
Probably being redundant, but suppose I'll say, don't take the no
turbulence patch as too much of a general fix.
It may work in Mike's scene; I couldn't pick up a seam during a quick
check with gimp.
However, if we make the fog distance much more shallow or set the color
really large it should be we start to see exactly the scenario Alain
suggested where the space between billboards appears much more clouded
than the clear parts of the billboard do.
Bill P.
Date: 7 Nov 2023 02:13:27
Message: <6549e397@news.povray.org>
Op 06/11/2023 om 16:26 schreef William F Pokorny:
> check with gimp.
> Bill P.
Thanks, yes, I was aware of that indeed. In fact, I do not use fog very
much any more and prefer media instead...
Date: 7 Nov 2023 07:25:00
Message: <web.654a2c6d310e11e9b4924336e066e29@news.povray.org>
> worked.
Yeah, that's a strange problem; I'm glad you found a solution.
> #declare sprite = box {<-.5,0,-.01>,<.5,1,.01> } ;
> object { sprite material {M_grass_A} scale <30,40,1> translate <0,-1,0>}
Just thought I would mention that you can make a box object with zero thickness,
which might be better for billboards. I usually use that trick.
#declare sprite = box {<-.5,0,0>,<.5,1,0> };
I wonder if that would have any effect on your original problem.
A box can't be *scaled* to have zero-thickness, but it can be made that way
initially.
