|  |  | Hi,
Here's a remake of an old crackle chart, but using isosurfaces. It shows various
results from different forms. The one with white text is the standard form.
The attached image only uses metric 2, but the code can be changed if you want a
different value.
It's not at all exhaustive, but potentially handy for finding a jumping-off
point. (Please ignore the -0.0; it's been a while since using str() and I forgot
how to easily get rid of the minus sign ;P)
CrackleChart.pov
2023 Sam Benge
+fn +f +a0.03 +am2 +r3 +w7000 +h1000
#version 3.7;
global_settings{assumed_gamma 1.0}
#default{ finish{ambient 0} }
camera{
 orthographic
 right x*7 up y
 location <0, 5, -5>
 look_at 0
 angle 104
light_source{
 <-1, .5, -.25>*1e5, rgb <1.7, 1.6, 1.4>
 shadowless
background{rgb <.03, .1, .3>}
union{
 #declare N = 3;
 #for(Z, -1, 1, 1/N)
  #for(Y, -1, 1, 1/N)
   #for(X, -1, 1, 1/N)
    #local Form = <X, Y, Z>;
    #local Metric = 2;
    #local Translate = <X + Z*7.7, Y*1.5, 0>;
    #local FCrackle =
     function{
      pattern{
       crackle
       form Form
       metric Metric
       scale .75
    isosurface{
     function{
      y - .5 * FCrackle(x, 0, z) + .5
     accuracy .001
     evaluate 0, 10, .5
     scale .3/N
     rotate y*25
     translate Translate
    #undef FCrackle
    text{
     ttf "arialbd"
     concat("<", str(Form.x, 1, 1), ", ", str(Form.y, 1, 1), ", ", str(Form.z,
1, 1), ">")
     .1, 0
     rotate x*45
     translate <-4, -7.5, 0>
     scale .12/N
     translate Translate
     // white text for default crackle form, yellow otherwise
     #if(Form.x=-1 & Form.y=1 & Form.z=0)
      pigment{rgb 1}
     #else
      pigment{rgb <1, .8, .4>}
     finish{emission 1 diffuse 0}
 translate y*.1
 pigment{rgb .75}
Sam
 Download 'cracklechart.jpg' (1133 KB)
 Preview of image 'cracklechart.jpg'
|  |  | "Samuel B." <stb### [at] hotmail com> wrote:
> Hi,
> different value.
I really missed your posts, Sam!
This one could be very useful. Lately I have a very little time for pov-ing, but
when possible I want to try this kind of crackle on an old project.
Paolo Post a reply to this message
> > Here's a remake of an old crackle chart [...]
> Paolo
Oh, hi Paolo! I didn't realize it was you at first, due to the name change.
Yeah, this chart should help for certain things. There's another one online at
https://www.imagico.de/pov/cr_form_en.php But it's a bit hard to navigate and
imagine how it will look as a height or bump map.
I hope you get some time for doing what you want to do soon. In the meantime,
are you making notes and sketches?
Sam Post a reply to this message
