POV-Ray : Newsgroups : povray.binaries.images : brain bot progress rendering Server Time
18 Feb 2025 17:32:33 EST (-0500)
  brain bot progress rendering (Message 11 to 19 of 19)
Subject: Re: brain bot progress rendering
Date: 20 Jul 2023 19:20:00
Message: <web.64b9bfff41b179efb5177e91dabc9342@news.povray.org>
> > > > > > Current modeling progress for a brain bot character. [...]
> > > > > It's looking really good!
> > > > > How are you modeling the brain?
> > > > Thanks,
> > > > the brain is one continuous sphere_sweep/cubic_spline. [...] I exported the
> > > > spheres via .x3d and converted the file to POV syntax. [...]
> > > Ah, tracing the brain folds is a good solution, for sure.
> > > I know nothing about the .x3d file type, but it sounds like it somehow preserves
> > > lots of info including ordered point arrays? Or it can at least be converted to
> > > arrays?
> > Yes, you are correct. The .x3d holds all the naming and transform information of
> > the Blender types. As long as you stick with Blender primitives (blobs, spheres,
> > torus, cube, etc. the output file is simple to parse. I use it to export point
> > arrays for POV lathes, sweeps, prisms, 2D arrays. I wrote a converter that reads
> > the .x3d and writes POV syntax. Attached shows spheres renamed as 'pointData in
> > Blender... I convert the points into 'mixed array' to be used in a construction
> > loop.
> > In Blender, I array a sphere along a bezier path with the 'curve' modifier.
> > Collapsing the array and curve moodier to create a list of loose elements still
> > maintains a creation order. Prefect for lathes, sweeps, prisms, ect.
> > Miller
> That's some welcome information! Years ago, I made a Blender-to-.pov arrays
> script in Python to transport object orientation data to POV-Ray (for rigid body
> sims), but Blender's Python API changed over time, and the script stopped
> working :( The .x3d file type seems like a promising replacement, and might even
> be less work than finding the changed API calls all over again.
> > Currently working on some sci-fi tower forms.
> It's looking more interesting all the time.
> Sam
Thanks.
You're welcome to the VBcode or executables for .x3d to POV if you think you can
use them. One thing that I'm not converting are quaternion. I got hung-up on the
math converting back to euler. It hasn't been a big problem but it would be nice
to store rotation.
Mike.
Date: 24 Jul 2023 19:25:00
Message: <web.64bf070d41b179eff8c47d526e741498@news.povray.org>
> Thanks.
> to store rotation.
> Mike.
I'll hit you up if I need it, but I haven't had a use for that recently. (Plus,
I don't work with VBcode, but maybe Code::Blocks probably supports it.)
Did the hang-up have to do with matrices? I know there's a way to derive
position, scale and rotation info from a single matrix.
I can't remember how I got rotational info out of Blender. This is the post I
made back when I was playing with a certain Blender-to-POV data exporter (I
can't believe it's already been 11 years!):
http://news.povray.org/povray.binaries.misc/thread/%3Cweb.5056a911b09798c46664708b0%40news.povray.org%3E/
Sam
Date: 24 Jul 2023 19:55:00
Message: <web.64bf0e4241b179eff8c47d526e741498@news.povray.org>
Just looked at the Blender-Python code I used for getting rotational data. The
following seems to be what I went with:
  DX = math.degrees(obj.rotation_euler[0])
  DY = math.degrees(obj.rotation_euler[1])
  DZ = math.degrees(obj.rotation_euler[2])
It would appear that I relied on a built-in conversion function to get the
rotation for each axis. (I don't know if forgetting things is a blessing or a
curse :/)
Sam
Date: 24 Jul 2023 22:00:00
Message: <web.64bf2c2c41b179efb5177e91dabc9342@news.povray.org>
> > Thanks.
> > to store rotation.
> > Mike.
> Sam
Thanks for pointing me to that.
11 years goes fast...
I've been exporting Blender data through .x3D which does a nice job of
formatting, but the rotations are written as quaternion. I tried tweaking a
quaternion to euler script in VB but failed. Below is a .x3d transform block.
Mike
<Transform DEF="pointData_032_TRANSFORM"
   translation="9.958521 56.574299 -0.017123"
   scale="0.154254 0.154254 0.154254"
   rotation="0.000000 0.707107 0.707107 3.141593"
Date: 25 Jul 2023 17:00:00
Message: <web.64c0371e41b179eff8c47d526e741498@news.povray.org>
> > > [...] I got hung-up on the math converting back to euler. It hasn't been
> > > a big problem but it would be nice to store rotation. [...]
> > Did the hang-up have to do with matrices? [...]
> Mike
You know, I think the solution might be quite easy since those values seem to be
angles in radians. Try converting the last three values to degrees like so:
#declare Rotation = rotate <0.707107, 0.707107, 3.141593> / pi * 180;
Sam
Date: 25 Jul 2023 17:05:00
Message: <web.64c038c841b179eff8c47d526e741498@news.povray.org>
> #declare Rotation = rota...
Oops, that should read as:
 #declare Rotation = <0.707107, 0.707107, 3.141593> / pi * 180;
Date: 25 Jul 2023 18:00:00
Message: <web.64c0447e41b179efb5177e91dabc9342@news.povray.org>
Thanks, I'll give that a shot.
I was using something like this but in VB --- got odd rotation results.
def quaternion_to_euler_angle(w, x, y, z):
    ysqr = y * y
    t0 = +2.0 * (w * x + y * z)
    t1 = +1.0 - 2.0 * (x * x + ysqr)
    X = math.degrees(math.atan2(t0, t1))
    t2 = +2.0 * (w * y - z * x)
    t2 = +1.0 if t2 > +1.0 else t2
    t2 = -1.0 if t2 < -1.0 else t2
    Y = math.degrees(math.asin(t2))
    t3 = +2.0 * (w * z + x * y)
    t4 = +1.0 - 2.0 * (ysqr + z * z)
    Z = math.degrees(math.atan2(t3, t4))
    return X, Y, Z
Miller
Date: 26 Jul 2023 18:40:00
Message: <web.64c1a08241b179eff8c47d526e741498@news.povray.org>
> Thanks, I'll give that a shot. [...]
Don't bother... it looks like was wrong. Check out this page:
https://edutechwiki.unige.ch/en/X3D_grouping_and_transforms
Here's the relevant bit:
"3.2 Rotations
Rotations are more difficult to understand, since it is possible to define any
arbitrary rotation axis.
rotation = 'x y z angle'
    x y z defines the rotation axis, angle is the amount of roation in radians
(i.e. 180 degrees = Pi)"
So, the first three numbers are the axis of rotation, and the fourth is the
amount of rotation in radians. The docs go on to give some tips but, if I'm not
mistaken, I think you can just plug the numbers directly into the
Axis_Rotate_Trans() macro in transforms.inc, making sure to do a radian->degree
conversion for the 4th value.
Sam
Date: 26 Jul 2023 20:25:00
Message: <web.64c1b81d41b179efb5177e91dabc9342@news.povray.org>
be
> "3.2 Rotations
> Sam
I'll give that a try...thanks so much!
Mike.
