|  |  | As Cousin Ricky already mentioned, a video from Numberphile as been released
recently about an interesting formula to calculate the shape of an egg. I gave
it a try today and share the result with you, cf image below. I did it as a
macro in an include file so that anyone interested could reuse it easily.
The macro and explanation about it are available on my website:
https://baillehachepascal.dev/2022/egg.php
Pascal
 Download 'egg.jpg' (213 KB)
 Preview of image 'egg.jpg'
released
egg. I gave
it as a
 > Pascal
Interesting work!
Paolo
|  |  | hi,
the eggs look nice -- you missed Easter by just a few days.  :-)  had a look at
the blog post, could not see a link to "quick get" an archive, is copy+paste the
only option?
regards, jr. Post a reply to this message
> I did it as a
Nicely done!
Your explanation of the idea is very clear, and the comments in the code are
very useful. I shall refer to this in the future.
From your image, it appears that the various textures are uv-mapped onto the
eggs(?)-- but there is no uv_mapping in your code that I can find. Do you think
that your macro could make use of v3.8's 'lemon' or 'ovus' uv_mapping ability? I
have not yet used those features, so I do not know where the appropriate code
should be placed in your macro, or if it would work there. Post a reply to this message
> released
> egg. I gave
> it as a
>  > Pascal
> Interesting work!
> Paolo
Thank you.
Pascal Post a reply to this message
|  |  | "jr" <cre### [at] gmail com> wrote:
> hi,
> only option?
> regards, jr.
Yes :-)
Forgive my laziness. I've just updated the article with a zip file, which url
is:
https://baillehachepascal.dev/2022/Data/povegg.zip
> > I did it as a
> Nicely done!
No uv_mapping here. The textures you see in the image are generated by the
'EggRndTexture' macro in 'egg.inc'. This is a multi-layered 'texture {pigment
{bozo ...}}'.
The shape is a lathe, see the macro 'EggShape' macro in 'egg.inc', not a lemon
or ovus. Then, uv_mapping would be possible if using the 'lathe' mapping. For
example as follow:
object {
  EggRndShape(lengthEgg, radiusEgg, seedShape)
    uv_mapping
      image_map { png "img.png" }
    scale <1,lengthEgg,1>
In 'img.png', the top-down axis corresponds to the small end-big end axis, and
the left-right axis warps around the egg. Note that I haven't tried and I'm
writing this only by referring to the doc.
|  |  | hi,
> ... I've just updated the article with a zip file, ...
pls check your "info" inbox.
