POV-Ray : Newsgroups : povray.binaries.images : Snow and Ice Server Time
24 Feb 2025 02:43:02 EST (-0500)
  Snow and Ice (Message 1 to 5 of 5)
Subject: Snow and Ice
Date: 20 Jan 2022 09:40:00
Message: <web.61e97359a0362c2e4c33eaed5cc1b6e@news.povray.org>
After working on the snowman from the holiday scene I decided to do another snow
scene with icicles this time.  Of course, I had to find out how to most
realistically model the shape of an icicle, and found several papers that ended
up providing a pretty good approximate formula.
The image below uses the same texture and isosurface noise functions to model
the snow as I had used for the previous snowman, but with SSLT turned off.  I
attempted to render it with SSLT, and after 9 days it was only 14% complete,
(about half of the roof).  I imagine once it hit the icicles it would stall
completely.  I didn't see enough difference in the part that had completed, so I
killed it.
I am wondering if it would be possible to just turn on SSLT for the snow at the
edge of the roof closest to the camera?
-- Chris R.
Download 'scene-v1.1-hiq-rad9-2022-01-10.png' (1181 KB)
Preview of image 'scene-v1.1-hiq-rad9-2022-01-10.png'
Subject: Re: Snow and Ice
Date: 20 Jan 2022 12:28:54
Message: <61e99bd6$1@news.povray.org>
> -- Chris R.
No, unless the edge is a different object than the rest of the snow.
What you can do is to reduce the quality, take less samples.
Date: 20 Jan 2022 13:50:00
Message: <web.61e9aec1c38762a14c33eaed5cc1b6e@news.povray.org>
> > -- Chris R.
I guess what I'm wondering is if I had a version of the texture (T1) with sslt
enabled, and another version without (T2), and then used
   gradient x
   texture_map {
      [0.0 T1]
      [0.75 T1]
      [0.75 T2]
      [1.00 T2]
Would I get the slowdown from SSLT over the whole object, or just the portion of
the last 25% of the object in the X direction?
-- Chris R.
Date: 20 Jan 2022 17:41:24
Message: <61e9e514$1@news.povray.org>
>>> -- Chris R.
> texture {
>     gradient x
>     texture_map {
>        [0.0 T1]
>        [0.75 T1]
>        [0.75 T2]
>        [1.00 T2]
> -- Chris R.
I can't say. It may work. Worth doing some test.
I'd try this :
    gradient x
    texture_map {
       [0.0 T1]
       [0.74 T1] // avoid a sharp jump between SSLT and non-SSLT
       [0.76 T2] // MAY need a slightly broader overlap in some cases
       [1.00 T2]
The slight overlap should hide the change from SSLT to non-SSLT.
Date: 21 Jan 2022 01:40:00
Message: <web.61ea5459c38762a12636f1af607c1b34@news.povray.org>
> completely.
This may be an unworkable suggestion but I'll mention it anyway in case it gives
you another more workable idea - it looks like you're using area lights which
may be a factor in the rendering speed issue. Maybe you can use the light_group
feature to isolate the lighting for the snow from the rest of the scene. If it
works then that would be a major cheat that would make the scene look a little
less realistic but maybe you can minimize the effect somehow. I tried to use
photons with a light_group recently and it didn't work but I haven't tried it
with SSLT.
Kind regards,
Dave Blandston
