Thomas de Groot <tho### [at] degroot org> wrote:
> Op 20/12/2021 om 21:52 schreef Chris R:
> This looks very convincing to me.
> [nitpicking] Maybe the snow seems a bit polluted by industrial fall out
> from its original surroundings? [/nitpicking] :-)
I think that's the effect of larger bits of transparent ice and not fluffy
diffuse snow. At least that the impression I get, especially with the specular
reflections.
I wasn't quite able to envision an earlier comment about adding some emission,
but now I think that it does need to be in some way "brightened".
deeper sslt?
rgbt?
emission?
a smaller emissive or rgb 1 diffuse 1 snowball just beneath the surface?
Still, a very impressive texture - it is looking REAL.
"Chris R" <car### [at] comcast net> wrote:
> The snowman is taking on a life of his own. Still need to do some work on the
> scarf. I added more texture to his arms, and the nose needs more texture as
> well. I'll have to see about more prominent placement that makes the puddle
> more visible in the full scene, and see how much the sslt affects the total
> rendering time...
It is looking better and better! I think the new light-placement is also a very
good improvement. I like that frozen ice puddle too; I tried something like that
years ago but was never quite happy with the result.
I really like your initial render of the entire scene; so many nice textures and
lighting effects. Worth the extended render-time; it's a beauty.
[m@b wrote:]
Here is my take on a melting snowman:
<https://youtu.be/puo_eVkz0gY>
That's great! Very well-done. I also like the fluffy appearance of your
snowman-- and the way its carrot nose tilts as the melting proceeds. A nice
touch.
Happy Holidays to All!
> > Any particular tools you use to convert frames to movies?
> > -- Chris Rath
> <https://ffmpeg.org/> is very versatile, you can call it as a shellout
> from POV-Ray.
> m@
I currently use VirtualDub 2 FilterMod (which includes ffmpeg as its engine, I
believe.) It has a GUI, which I like. Even though old, it's still available...
https://codecpack.co/download/VirtualDub-FilterMod.html
It can output various modern (or old) file formats, with various types of
compression. It has lots of configurable choices too-- many of which I don't
understand or use, ha. But I'm always learning.
[I've never been able to understand the 'shellout' feature in POV-Ray for
Windows, or how to use it. I don't come from a programming background, so the
concept itself is kind of a mystery.]
> reflections.
> deeper sslt?
> rgbt?
> emission?
If anyone is interested, here is what I am using for the material:
#declare Real_snowman_snow_texture3 = texture {
granite
color_map {
[0.0 rgb <1.2, 1.2, 1.2>]
[1.0 rgb <1.15, 1.15, 1.15>]
scale 0.5
finish {
fresnel
diffuse 0.7
specular albedo 0.2
roughness 0.001
subsurface { translucency 0.5 }
#declare Real_snowman_snow_material3 = material {
interior {
ior 1.33
The snowballs are isosurface spheres. I use f_snoise3d at a scale to deform the
spheres, and the f_granite at a smaller scale to get the bumps that make the ice
crystals on the surface of the sphere.
-- Chris R.
> A bit of a work-in-progress, but far enough along to show. This took about
> 4-days to render without any camera blur, which I'd like to add at some point.
> There are a few more ornaments/elements I'd like to add in for interest. I'll
> probably have to play with the lights a bit or it will never finish rendering
> before the holidays are over... :-;
> -- Chris Rath
Taking a lot of your suggestions into account, I give you the final rendering,
completed just in time to end 2021, (it took 4 1/2 days to render!)
Happy New Year to all, and I look forward to more POV-ing in 2022.
-- Chris Rath
> > -- Chris Rath
> -- Chris Rath
Sorry, forgot to attach the image...
Download 'scene_v1.1-2021-12-31.png' (985 KB)
Preview of image 'scene_v1.1-2021-12-31.png'
