POV-Ray : Newsgroups : povray.binaries.images : Elliptical torus Server Time
28 May 2024 16:38:46 EDT (-0400)
  Elliptical torus (Message 10 to 19 of 39)
<<< Previous 9 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Elliptical torus
Date: 4 May 2020 07:10:00
Message: <web.5eaff7d5a032ea3dfb0b41570@news.povray.org>
William F Pokorny <ano### [at] anonymousorg> wrote:
Perhaps useful to review that work as we look for an
> f_elliptical_torus() or complete parametric solution.
I'll go back to my initial post and see what else I need for the parametric.
I had a key insight last night that I need to pursue when I get back later.
With regard to a workaround, if needed:
http://www.econym.demon.co.uk/isotut/splines.htm
Which I should have thought of much much earlier.
Date: 4 May 2020 15:15:01
Message: <web.5eb06994a032ea3dfb0b41570@news.povray.org>
So, just to provide a diagram for the elliptical torus, we can see that the same
sort of situation exists, and the same calculations are used once we establish a
length from the origin to point P.
And I think that's where things get interesting (complicated).
https://courses.lumenlearning.com/ivytech-collegealgebra/chapter/deriving-the-equation-of-an-ellipse-centered-at-the-or
igin/
describes how the definition of a torus (constant distance from two foci) gets
algebraically converted down to pow(x,2)/pow(a,2) + pow(y,2)/pow(b,2) = 1.
But really what we want is a distance function for the points on an ellipse.
I found this excellent answer for how to do that
https://math.stackexchange.com/q/1760296
so since the distance is sqrt(pow(x,2)+pow(y,2)), I use the equations from that
post to substitute in for x and y in the distance function to get:
#declare DistE = function (x, y, z, a, b){
 sqrt (
 (pow(a,2)*pow(b,2)*pow(x,2))/((pow(b,2)*pow(x,2))+(pow(a,2)*pow(y,2))) +
 (pow(a,2)*pow(b,2)*pow(y,2))/((pow(b,2)*pow(x,2))+(pow(a,2)*pow(y,2)))
and then plug that into the main isosurface equation for an elliptical torus
with a constant circular cross-section.
#declare IET =
function (x,y,z,a,b,r) {
 pow(DistE(x,y,z,a,b) - sqrt(pow(x,2)+pow(y,2)) ,2) + pow(z,2) - pow(r,2)
But I still get no visible surface.
Date: 4 May 2020 16:15:01
Message: <web.5eb07701a032ea3dfb0b41570@news.povray.org>
Helps to provide the diagram...
Download 'implicitellipticaltorus.png' (130 KB)
Preview of image 'implicitellipticaltorus.png'
Date: 4 May 2020 16:50:06
Message: <web.5eb07f87a032ea3dfb0b41570@news.povray.org>
So, I looped over x, y, and z and sent the evaluated function result to the
debug stream.   Massive delay from sending 8000 points to the text stream
later...
 and I get values in the hundreds, less, less, less, and maybe a min of 0 or so.
I then plotted points with a value of 10 or less with spheres.
There's definitely an elliptical shape in there somewhere....
Download 'implicitellipticaltorus.png' (119 KB)
Date: 4 May 2020 17:25:06
Message: <web.5eb08780a032ea3dfb0b41570@news.povray.org>
Oh look:
If I clean up my sloppy code and cease engaging in flagrant dumbassery.....
Download 'implicitellipticaltorus.png' (148 KB)
Date: 4 May 2020 20:10:00
Message: <web.5eb0ae7ca032ea3dfb0b41570@news.povray.org>
And wow - wouldn't you know - when you actually do the math correctly, it comes
out dead-on.
f_elliptical_torus in the proper x-z plane
Download 'implicitellipticaltorus.png' (93 KB)
Date: 5 May 2020 07:23:39
Message: <5eb14cbb$1@news.povray.org>
> out dead-on.
Cool! :-)
I'm going make another attempt at an inbuilt function for this. If
you've tweaked something in the code from the previous few posts, please
let me know.
More ReL (Real Life) than RaL (Ray Life) today - so likely later this
week before I get to it.
Bill P.
Date: 5 May 2020 13:35:01
Message: <web.5eb1a390a032ea3dfb0b41570@news.povray.org>
> let me know.
Nope - Just been playing around with it a bit to make sure the outer and inner
shapes are truly elliptical (they are).
I know we have a vlength() - but it can't be used in functions (vector
argument).
Maybe if there was a way to just do a Vlength (x,y,z) to get around that...
I was also thinking that non-circular cross sections would be something nice to
have - something like the form factors for the helix functions.  I have one
function that I'll try to work out for that, but other functions similar to the
superellipsoid, "squircle", and rounded box seem like they would have utility
for povvers as well.
Conversely, It would be great to have a "torus" that was spherical or
ellipsoidal - but could follow the shape of some other function or spline.
With regard to dot notations and vectors - what is the "native form" for a
pigment pattern?  Is it an "rgb" vector where each component simply has the same
value unless modified by a color_map?
And is it therefore slower to use .gray or .hf?
So much ReL.  Juggling Arduino, work, home, and COVID ridiculousness.
No worries - take your time.  :)
Date: 5 May 2020 20:20:01
Message: <web.5eb2022ba032ea3dfb0b41570@news.povray.org>
I made excellent progress in translating the function of main interest to into a
pattern and an isosurface.   I think in order to make it function as a
cross-sectional term, it needs to "translate its frame of reference to the
origin", and so I might need to convert the atan2 function to a polynomial.
But I might be wrong about that.
Essentially, I need to calculate the _angle_ that I'm at around the cross
section using x and y....
So I'd need to do something like this, only in SDL.
https://stackoverflow.com/questions/11930594/calculate-atan2-without-std-functions-or-c99
float normalized_atan2( float y, float x )
    static const uint32_t sign_mask = 0x80000000;
    static const float b = 0.596227f;
    // Extract the sign bits
    uint32_t ux_s  = sign_mask & (uint32_t &)x;
    uint32_t uy_s  = sign_mask & (uint32_t &)y;
    // Determine the quadrant offset
    float q = (float)( ( ~ux_s & uy_s ) >> 29 | ux_s >> 30 );
    // Calculate the arctangent in the first quadrant
    float bxy_a = ::fabs( b * x * y );
    float num = bxy_a + y * y;
    float atan_1q =  num / ( x * x + bxy_a + num );
    // Translate it to the proper quadrant
    uint32_t uatan_2q = (ux_s ^ uy_s) | (uint32_t &)atan_1q;
    return q + (float &)uatan_2q;
Date: 5 May 2020 20:45:00
Message: <web.5eb207fba032ea3dfb0b41570@news.povray.org>
Scratch that initial misconception.
Which means that I need to unravel the dot product between two vectors.
The first vector being the normalized blue segment in the drawing.
The second vector being the normalized radial vector in the vertical plane of
the blue vector.
Got some cool screw-ups, and have some visual confirmation that I can get a nice
non-circular/elliptic shape to the R of the torus.
Maybe I'll get it before tomorrow afternoon.
