Op 22/04/2020 om 20:24 schreef Norbert Kern:
> This idyllic (non-realistic) scene is the result of several months of work. It
> took that long because of an experiment.
> I was curious about what would happen when only looking long enough at each
> parts of the scene and so detecting not so good parts.
> In fact I detected one flaw after another for three long months.
> So I substituted, changed or retextured nearly all objects, some of them several
> times.
Absolutely gorgeous scene indeed. While your "experiment" contains the
danger of never finishing scene building, it is absolutely essential for
reaching any level of perfection. I do something less extreme than you
myself, with the result that over the last couple of years my production
has dramatically fallen ;-) There are other reasons too for this drop
but those are coming from RL... Anyway, this is a landmark image.
> In the end the scene used 155 individual objects - by comparison my recent redo
> of "warm_up" only used 21 meshes.
> So the scene contains 31 animals (9 birds, 7 mammals, 11 insects, 3 frogs and 2
> fishes).
> Since some of them are nearly invisible, I downloaded a 8000*4500 pixel version
http://news.povray.org/povray.binaries.scene-files/thread/%3Cweb.5ea0897b523527c5afdd13e10%40news.povray.org%3E/
> Rendering this version took more than 9 days and 43 GB of RAM were used.
I suppose continuous render or did you interrupt and continue (+c) a
couple of times?
> I worked several weeks on an atmosphere alone, but in the end all I did was
> adding a subtle fog effect.
I recognise that. ;-)
> The chief motiv of the image is the contrast of light and shadows as it is
> important in impressionistic painting or gothic architecture.
> I'll explore this topic in my next images more.
Cant wait...
> Beside this philosophical reasons it was important for me in a more technical
> sense as it is the first image since 15 years developed with assumed_gamma 1.
> I think, I'll stay at this since it is obviously possible to realize strong
> contrasts with assumed_gamma 1...
I can only approve.
> Happy rendering in difficult times,
> Norbert
Thanks! My thoughts go to the numerous who are threatened of losing
their livelihood because of covid19.
Indeed. So as not to hijack discussion of this absolute masterpiece, switching
to off-topic thread for this...
>> work. It
>> [snip]
> render.
>> it is
>> technical
>> assumed_gamma 1.
>> strong
> to fiddle with the assumed gamma, but to change the lighting environment.
Like reducing the ambient amount.
> > Norbert
> WOW. That's one beautiful image Norbert! Bravo.
> Going to sit back, drink a cup of coffee, and stare at it for a while.
> Bill P.
Lol - in the case you wonder about where all the animals are, here is an image
with all the creatures...
Norbert
Download 'light & shadows_animals.jpg' (92 KB)
Preview of image 'light & shadows_animals.jpg'
"Ton" <ton### [at] gmailcom> wrote:
> Fantastic, would like to visit this place. Povray is surely amazing, well done.
> Cheers
> Ton.
Thank you - I can remember a guy many years before - he said, povray can depict
anything. I want to add - it's sometimes hard to know, what I want to depict.
Norbert
> I would expect so. Real life does it linearly; it is our perceptions
> that are non-linear. My response to a low contrast scene has not been
In fact texturing was really simple. A finish like "specular 0.3 roughness 0.003
diffuse 0.6 ambient 0" worked with nearly all objects. When I used assumed_gamma
2.2 there was much more work to do :-)
The biggest change was to reduce the radiosity contribution of the sky.
Here I used rather extreme settings (at least for me) -
#version 3.7;
#declare RAD = 8;
global_settings {
assumed_gamma 1
max_trace_level 255
noise_generator 2
radiosity {
pretrace_start 0.08
pretrace_end 0.04/RAD
count 30*RAD
nearest_count min (20, RAD)
error_bound 3/RAD
low_error_factor 0.5
recursion_limit 1
gray_threshold 0
minimum_reuse 0.015
brightness 1
adc_bailout 0.005
normal on
media off
#declare skyf = 0.5;
light_source {
<0,0,40000> color srgb (<2.42,2.23,1.87>+2.173*0.3)*0.85
area_light <1000,0,0>, <0,1000,0> 5,5 adaptive 0 jitter circular orient
rotate <-47,-50,0>
sky_sphere {
function {max (min (y, 1), 0)}
color_map {
[0.0000 srgb <212*skyf,221*skyf,239*(1+skyf)*0.5>/255]
[0.1029 srgb <219*skyf,229*skyf,244*(1+skyf)*0.5>/255]
[0.1512 srgb <233*skyf,241*skyf,250*(1+skyf)*0.5>/255]
[0.1949 srgb <223*skyf,239*skyf,252*(1+skyf)*0.5>/255]
[0.2444 srgb <201*skyf,227*skyf,252*(1+skyf)*0.5>/255]
[0.2921 srgb <180*skyf,213*skyf,250*(1+skyf)*0.5>/255]
[0.3732 srgb <144*skyf,180*skyf,239*(1+skyf)*0.5>/255]
[0.4255 srgb <137*skyf,172*skyf,235*(1+skyf)*0.5>/255]
[0.7067 srgb < 97*skyf,126*skyf,198*(1+skyf)*0.5>/255]
[0.7740 srgb < 92*skyf,119*skyf,190*(1+skyf)*0.5>/255]
[0.8275 srgb < 88*skyf,114*skyf,185*(1+skyf)*0.5>/255]
[0.8850 srgb < 85*skyf,111*skyf,180*(1+skyf)*0.5>/255]
[0.9425 srgb < 82*skyf,107*skyf,175*(1+skyf)*0.5>/255]
[1.0000 srgb < 79*skyf,103*skyf,170*(1+skyf)*0.5>/255]
Norbert
Thank you Thomas. Indeed there was this danger - but in the end it became clear,
that I want to improve by making other images. There is a subtle intuitive
voice, which guided me. I simply wanted to exclude superficial rational
reasoning...
> couple of times?
No, I used my two machines - the first for doing all the changes and the second
one for rendering. The second machine with 64 Gb RAM is loud and can heat my
whole passiv house - so my window was wide open all the time since xmas ;-) .
> > Norbert
My rational side says such things are and will be inevitable. Personally I
conducted some scenario exercises with similar topics in my compony and in the
beginning I was shocked by the outcomes - this pandemie can lend to very deep
economic recessions - and wars.
Times are becoming even more interesting (in the chinese sense - may you live in
interesting times)...
Norbert
Wow! That's absolutely stunning. Thanks for sharing it.
David Buck
> times.
> fishes).
> Norbert
Hi Norbert,
3 months well spent!
You really are the master of this kind of nature image, certainly what I
inspired to achieve on my attempts but never had the skill and patience to
achieve this level of detail.
Glad you provided the extra large image and also the animals only version so I
could zoom in and spot them. The one I still couldn't see was the Squirrel but I
think even when you don't see/notice these they still add something to the
image.
great work as always.
Sean
It's a marvel. Congratulation.
Pascal
