POV-Ray : Newsgroups : povray.binaries.images : Something abstract Server Time
18 Nov 2025 07:54:21 EST (-0500)
  Something abstract (Message 1 to 10 of 11)
Subject: Something abstract
Date: 1 Mar 2020 18:15:01
Message: <web.5e5c41305cd1ad92e57675270@news.povray.org>
Hi all,
I'm pretty much just checking in to say hi. Hi!
This image uses clipped height fields and a technique resembling marching
squares. Just messing around, pretty much. Hope everyone's doing well!
Sam
Download 'tilefinder23m_03s+1m_32s.jpg' (265 KB)
Preview of image 'tilefinder23m_03s+1m_32s.jpg'
Subject: Re: Something abstract
Date: 2 Mar 2020 02:47:19
Message: <5e5cba07$1@news.povray.org>
Op 02/03/2020 om 00:11 schreef Samuel B.:
> Hi all,
> Sam
Sam! How good to hear from you! How are you doing? Well, I suppose,
seeing that gorgeous pure gold artifact you must have found in the
desert. :-)
Date: 2 Mar 2020 12:59:12
Message: <5e5d4970$1@news.povray.org>
Samuel B. wrote on 02/03/2020 00:11:
> Hi all,
> Sam
Very intriguing, as always, Sam!
Paolo
Date: 2 Mar 2020 14:20:04
Message: <web.5e5d5b41bbabb1311b6c6b3a0@news.povray.org>
"Samuel B." <stb### [at] hotmailcom> wrote:
> Hi all,
Great to see you're still producing the goods! Lovely image as always.
Bill
Date: 2 Mar 2020 17:05:01
Message: <web.5e5d82ccbbabb131e57675270@news.povray.org>
> desert. :-)
On average: ok ;) Yourself?
Date: 2 Mar 2020 17:40:00
Message: <web.5e5d8b20bbabb131ab765f000@news.povray.org>
> Hi all,
> Sam
Hi Samuel,
I know your clipped height fields code, but I don't get the marching squares
part.
Is it similar to your code for Randomized orientation of pattern instances?
And - your image is simple, but beautiful!
Hopefully you will make and publish more povray images.
Norbert
Date: 3 Mar 2020 02:26:05
Message: <5e5e068d$1@news.povray.org>
Op 02/03/2020 om 23:03 schreef Samuel B.:
>> desert. :-)
Hobbling along but I don't complain ;-)
Date: 3 Mar 2020 18:55:00
Message: <web.5e5eea0abbabb131e57675270@news.povray.org>
> > Hi all,
> > Sam
> Hi Samuel,
> part.
> Regards,
> Norbert
Hi Norbert,
I'm not sure I ever posted the thing I'm doing here. Attached is a 'cheat sheet'
showing how I figure out which tiles get used. There are 6 basic tiles: solid,
empty, outside corner, inside corner, wall, and 'bridge' which is two outside or
inside corners. I test four cells of a pattern to determine which tile gets
used. The cells are evaluated and counted starting from the bottom left. The
counting algorithm is 1*SW + 2*SE + 4*NW + 8*NE to obtain a decimal number from
the four 2 bit cells. Then I use that number to access objects created with the
cheat sheet in mind. For instance, number 1 is an outside corner facing the
upper right.
Sorry if that's confusing at all :P At any rate, I can provide the source if you
want.
Sam
Download 'tile chart.png' (9 KB)
Preview of image 'tile chart.png'
Date: 3 Mar 2020 19:05:00
Message: <web.5e5ef02ebbabb131e57675270@news.povray.org>
> want.
> Sam
I failed to mention that the fancy pattern is obtained via iterated transforms
and a warp{repeat x flip x} statement. This produces fractals :)
Date: 5 Mar 2020 07:15:02
Message: <web.5e60ec32bbabb131ab765f000@news.povray.org>
> Hi Norbert,
> upper right.
> want.
> Sam
I've a clear impression of the algorithm now, but of course I want the source!
Norbert
