hi,
"Melody" <nomail@nomail> wrote:
> "Cousin Ricky" <rickysttATyahooDOTcom> wrote:
> > I avoid Windblows of *any* flavor. ...
> win7 is the promised land.
there once was a man named Bill,
whose programs made users ill.
he though, completely undeterred,
became rich as a king, the uber nerd,
and kept bending the world to his will.
regards, jr.
https://www.youtube.com/watch?v=pQocN_c2uLI
> libpthreadGC2.a pthreadGC2.dll
> #include <pthread.h>
> #include <unistd.h>
C:\mirc614\irc\timer.h|32|warning: control reaches end of non-void function
[-Wreturn-type]
whats the fix for that warning? for this "non-void function"
??? compiler wont allow returning anything ??
void * twait(int secs)
/// do something here
newthread launcher from a dll - follow up.
int timer1(HWND mWnd, int secs, void * func)
pthread_t thread; int err;
err = pthread_create(&thread, NULL, func, (void *)secs);
if (err) return 1;
return 0;
timer1(mWnd,0,twait);
working now,
but is 4th parameter done the right way? what about &secs ??
you guys ought to know something.
extreme use of the term pseudo random,and phi
Download 'colochaos.jpg' (185 KB)
Preview of image 'colochaos.jpg'
hi,
> > #include <unistd.h>
> [-Wreturn-type]
> if (err) return 1;
> return 0;
> working now,
am fairly sure that should be 'void twait(int);', and I'd keep "do something
here" to just setting some (global) flag.
<https://www.gnu.org/software/libc/manual/html_node/Basic-Signal-Handling.html>
(specific to that library but the same principles apply)
and re 4th argument, you're converting the number of seconds to a pointer
(value), did you mean 'pthread_create(&thread, NULL, func, &secs)'? no need
(usually) to explicitly cast to '(void *)'.
regards, jr.
The way I'm reading it, based on my work with Arduino, is that your [if] flow
control directive is malformed and so the compiler if waiting to wrap that up
before hitting the end of the function.
if (err) return 1;
return 0;
change the above to:
if (err) {return 1;
[else] return 0;
and see what happens.
Of course, I could be totally wrong.
I also think that if at the top of your code you do
int secs = 0;
then you only need to use secs not int secs in the rest of your code.
turns out the only bug I could not really see a way to fix,
but I could patch it ...
return 1 to mIRC - dll still loaded....
calls twait(msecs) {
echos(GlobWnd,msecs);
// but mirc could only hear previous message
UNLESS
Sleep(50); /// fixes SendMessage issue
then everything OK. patched.
> > #include <unistd.h>
> [-Wreturn-type]
thought I tried it ... Well, *today this works. compiler stopped whining.
return (void *)0;
Triangle Inequality Average (TIA)
Mercator and figuring log(polar)(slowly) - examples are invisible and
explanations seemingly by those who can't. While those who can, just do it. pQ -
National Defense secret? Wiki was disappointing on the subject.
