POV-Ray : Newsgroups : povray.binaries.images : uv mapping uv-mappable objects from scratch Server Time
15 Aug 2025 21:18:43 EDT (-0400)
  uv mapping uv-mappable objects from scratch (Message 1 to 3 of 3)
Subject: uv mapping uv-mappable objects from scratch
Date: 16 Aug 2019 21:30:00
Message: <web.5d5757a84c72a7284eec112d0@news.povray.org>
So, I managed to get the first step of the wholly SDL-based uv mapping worked
out.
Had to get my head back into "function space" and "pigment space" first, and
then things proceeded with only a few hiccups.
Shown is the image map on a unit square, followed by a unit sphere uv-mapped
with a function pigment, rotated around y by 0, 90, 180, and 270 degrees.
Maybe tomorrow I can make some more progress toward non-spherical parametric
objects and see how that goes.
Download 'uvmappingtest.png' (449 KB)
Preview of image 'uvmappingtest.png'
Subject: Re: uv mapping uv-mappable objects from scratch
Date: 21 Aug 2019 02:30:00
Message: <web.5d5ce485236c7e68884ec9560@news.povray.org>
> out.
Hi, to make sure I understand correctly, this is pov code only, no bitmap? did
you post the scene somewhere?
Date: 21 Aug 2019 06:35:00
Message: <web.5d5d1d64236c7e684eec112d0@news.povray.org>
Hi Maurice,
The image data comes from png that I made in POV-Ray a while back (I believe I
was trying to recreate TOK's NURBS object....)
IIRC, that's not really relevant - you can create the same png "in memory"
without saving it to a render, and use that as you would any other.
But the code to _uv_map_ the image data onto the sphere is all SDL, not a
mechanism in the source code.   It's just a simple sphere - I haven't had a
chance to elaborate on this any.
It's dirt simple, but it of course took me WAY too long to see the path to
success.  But that IS the path to success, now, isn't it - persistence.
#version 3.8;
global_settings {assumed_gamma 1.0 }
#include "functions.inc"
#include "math.inc"
 //location <0, 40, 2.5>
 location <1.0, 0, -3.5>
 up y
 look_at <1.0, 0, 0>
 //look_at <0, 0, 0.01>
light_source {<1, 0, -10> rgb 1}
background {Gray10}
#declare U = function (X, Y, Z) {(0.5 + atan2 (N(Z, X,Y,Z), N(X, X,Y,Z))/(2*pi)
#declare V = function (X, Y, Z) {(0.5 + asin(N(Y, X,Y,Z))/pi)}
#declare USphere = function (X, Y, Z) { U (X, Y, Z)}
#declare VSphere = function (X, Y, Z) { V (X, Y, Z)}
#declare Image = pigment {image_map {png "Grid.png" once}}
#declare ImageMap = function {pigment {Image}}
#declare RGBPigment =
          average
          pigment_map {
                  function { ImageMap (USphere (x,y,z), VSphere (x,y,z), 0).red
                  color_map {
                      [ 0 red 0 ]
                      [ 1 red 3 ]
0).green }
                  color_map {
                      [ 0 green 0 ]
                      [ 1 green 3 ]
                  function { ImageMap (USphere (x,y,z), VSphere (x,y,z), 0).blue
                  color_map {
                      [ 0 blue 0 ]
                      [ 1 blue 3 ]
    } // end pigment map
   } // end pigment
union {
sphere {0, 0.5 texture {pigment {RGBPigment} finish {specular 0.4}} rotate y*0
translate -x*0.5}
sphere {0, 0.5 texture {pigment {RGBPigment} finish {specular 0.4}} rotate y*90
translate x*0.5}
sphere {0, 0.5 texture {pigment {RGBPigment} finish {specular 0.4}} rotate y*180
translate x*1.5}
sphere {0, 0.5 texture {pigment {RGBPigment} finish {specular 0.4}} rotate y*270
translate x*2.5}
translate -y*0.5
box {0, 1 scale <1, 1, 0.01> texture {pigment {Image} finish {specular 0.4}}
translate <0.5, 0.25, 0>}
