POV-Ray : Newsgroups : povray.binaries.images : George Stephenson's Rocket Server Time
24 Mar 2026 04:36:43 EDT (-0400)
  George Stephenson's Rocket (Message 3 to 12 of 32)
<<< Previous 2 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: George Stephenson's Rocket
Date: 12 Apr 2019 03:15:06
Message: <web.5cb03aca6bc50fb5a50bb1200@news.povray.org>
> Looks very promising!
> Hopefully you will model the tender too.
> There is much wood - in the case you are looking for a real nice wood texture -
> think about a texture originating from the excellent isowood code by Christoph
> Hormann - here is the code for a texture using his functions -
> Norbert
Hello Norbert
yes, I'm aware of the isowood code. Renders good wood.
The model in the Railway Museum in York has the Rocket painted yellow, and
that's what I had in mind to render (to povray?) my model.
But of course I can use non-painted wood, and see how it looks. Povray will take
a lot longer though!
Ton
Date: 17 Apr 2019 07:45:01
Message: <web.5cb711036bc50fb575b136980@news.povray.org>
Here is an update on the Rocket. I've added the front bearing and its leaf
spring.
Ton.
Download 'forum2.png' (1276 KB)
Preview of image 'forum2.png'
Date: 23 Apr 2019 07:05:01
Message: <web.5cbef0586bc50fb523174ebc0@news.povray.org>
Another small step to completion, the boiler has been added, plus the steam
control valve. Only speed could be regulated, no brakes!
Ton.
Download 'forum3.png' (1144 KB)
Preview of image 'forum3.png'
Date: 24 Apr 2019 06:50:37
Message: <5cc03f7d$1@news.povray.org>
Ton wrote on 23/04/2019 13:00:
> Cheers
> Ton.
It looks promising!
Paolo
Date: 25 Apr 2019 09:40:00
Message: <web.5cc1b7c76bc50fb5624876100@news.povray.org>
> Cheers
> Ton.
If .. the brown part and yellow part of the rocket is too bright
Date: 29 Apr 2019 20:00:01
Message: <web.5cc78f706bc50fb542d8ebd00@news.povray.org>
Made some progress with my model. Added the steam dome and safety valve on top
of the boiler. Plus the smoke stack is in place.
I've also been playing with the textures and lighting. That seems like a never
ending process. It can always be improved.
Ton.
Download 'forum4.png' (1188 KB)
Preview of image 'forum4.png'
Date: 2 May 2019 02:55:15
Message: <5cca9453$1@news.povray.org>
What a beauty! I never realised somehow that the boiler was oval-shaped.
I assumed it was circular like the more recent steam locs.
Date: 2 May 2019 06:20:00
Message: <web.5ccac3d96bc50fb542d8ebd00@news.povray.org>
Bedankt for the compliment.
Is it oval? It's supposed to be a circle, a round circle.
Ton
Date: 2 May 2019 17:43:30
Message: <5ccb6482$1@news.povray.org>
Do the camera right & up vectors match the image aspect ratio (16:9)?
If I force-view the image at the camera default ratio, which is 4:3, the
boiler cross section looks circular.
If your camera block lacks these two vectors, you can fix the distortion
by adding
   right 16/9 * x
to your camera block.
Date: 2 May 2019 18:50:01
Message: <web.5ccb73386bc50fb542d8ebd00@news.povray.org>
> by adding
>    right 16/9 * x
This is highly embarrassing. Povray 3.8 sets the aspect ratio depending on the
image format. So I didn't set the right vector in the camera.
The #version in my pov-file was set to 3.7 however, and then the aspect ratio is
1.33.
There are some hawk-eyed people out there. Thanks everybody.
BTW as excuse for myself: As long as there are no circles in your object, you
hardly notice! Poor excuse, I know, but better than nothing.
Ton.
Download 'forum5.png' (1170 KB)
Preview of image 'forum5.png'
