![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks, I'm never quite sure what to use for an image map, but this one worked
out fairly well.
Technical aside:
While working on this, and reviewing the code, I noticed that the bicubic_patch
block doesn't allow trailing commas in the list of the control points.
Is this something that can be addressed without too much hassle?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 19.09.2018 um 18:26 schrieb Bald Eagle:
> out fairly well.
> Technical aside:
Yes, that could be done. Actually it would simplify the parser for
bicubic patch.
I'm not even sure why an extra comma explicitly forbidden - it's rather
unusual style in POV-Ray. Maybe it was implemented before commas were
made always optional, or the person implementing this piece of the
parser didn't know that.
I'm also looking at the matrix syntax while I'm at it.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Le 18-09-18 à 15:11, Bald Eagle a écrit :
> So - here's a coil wrapping around a torus 5 times. Super easy as a sphere
> weep and parametric or isosurface or polynomial... but if the torus is
> deformed...
5 times around ? Then, why to I count 12 rotations ?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > deformed...
We use common core principles to guess at the floating-point values, and when
you do that, 5 = 12 for sufficiently large values of 5.
No really, I started off with 5, and decided it looked better with 12.
It was a counting test - you passed! :D
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> deformed...
I still see 5... :-0
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>>> a sphere
>>>> torus is
>>>> deformed...
>> and when
Mod(12,7) ??
Adjust your viewpoint. ;-)
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>>>> a sphere
>>>>> torus is
>>>>> deformed...
>>> and when
> Mod(12,7) ??
When I squint I see 12... ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Bald Eagle" <cre### [at] netscape net> draw:
>>> "a kind of strange toroidal form of life"
Looks yummi to me.
B.Gimeno
pd. Seems that everything I look is yummi at lunch time.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
hi,
> > > deformed...
phew. I'm so glad I read this. :-)
fwiw, I thought the image posted Sep 4th cool, the "crumpled" surface. it looks
a little like a kitchen/tea towel dropped, if the texture was more "terry
cloth".
regards, jr.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
This looks similar to the shape of the plasma stream inside a
Wendelstein fusion reactor (check online). Amazing.
http://www.avg.com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
