POV-Ray : Newsgroups : povray.binaries.images : Re: Cloud Surface Server Time
18 Nov 2025 20:31:23 EST (-0500)
  Re: Cloud Surface (Message 1 to 10 of 109)
Subject: Re: Cloud Surface
Date: 24 Nov 2017 14:05:01
Message: <web.5a186c9e9a2a53c19ae32810@news.povray.org>
simple example image for a cloud surface to start with
Scene file at
http://news.povray.org/povray.text.scene-files/message/%3Cweb.5a186b419a2a53c19ae32810%40
Download 'cloud_surface.png' (234 KB)
Preview of image 'cloud_surface.png'
Date: 24 Nov 2017 14:56:03
Message: <5a187953$1@news.povray.org>
> Scene file at
a53c19ae32810%40
Yes, that cloud looks good enough for my needs! Thanks a lot!
But here's one more question: I don't want the cloud surface to be flat
like a plane. Is there any way, to get it slightly rounded, like it
follows the round shape of a planet? I want to see, at a vast distance,
the horizon, that's why.
http://www.avg.com
Date: 24 Nov 2017 18:36:59
Message: <5a18ad1b@news.povray.org>
> Scene file at
Have a look at the a:
I am quite happy with the shape of the clouds, but there are some things
where I don't know how to change:
- that the tower disappears slowly below cloud surface (now it is white)
- that the tower puts its gentle smooth shadow on the clouds
- that the clouds are lilac in shadow and remain pink in light
- and pink (as now) in the illuminated areas
Any suggestions?
http://www.avg.com
Download 'sl - cloud cities.jpg' (171 KB)
Preview of image 'sl - cloud cities.jpg'
Date: 24 Nov 2017 18:51:02
Message: <5a18b066$1@news.povray.org>
Am 25.11.2017 um 00:36 schrieb Sven Littkowski:
Make sure to use scattering media with an extinction value of 1.0.
Also, do use the newest version of POV-Ray, and do use the default media
sampling method (2 I think). Media has seen several fixes of the
underlying math, some of which could not be applied to the older
sampling methods.
Date: 24 Nov 2017 18:54:41
Message: <5a18b141$1@news.povray.org>
I forgot to post the scene code:
#version 3.7;
global_settings
 assumed_gamma 1.0
#default
 finish { ambient 0.0 diffuse 0.0 }
#include "textures.inc"
#include "glass.inc"
#include "metals.inc"
#include "golds.inc"
camera
 /*ultra_wide_angle*/ angle 20   // diagonal view
 location  < -20.0 , 15.0 ,-00.0 >
 look_at   < 0.0 , 2 , 0.0 >
// sun -------------------------------------------------------------------
light_source { < 250, 100, -250 > color < 1.0,  0.62353,  0.46667 > *5 }
// sky
sky_sphere
 pigment
  gradient < 0, 1, 0 >
  color_map
   [ 0.0 color rgb < 1.00000,  0.62353,  0.46667 > ] // Pink
   [ 0.4 color rgb < 0.64706,  0.30588,  0.59608 > ] // Purple
   [ 0.6 color rgb < 0.64706,  0.30588,  0.59608 > ] // Purple
   [ 1.0 color rgb < 1.00000,  0.62353,  0.46667 > ] // Pink
  scale 2
// ground -----------------------------------------------------------------
//---------------------------------<<< settings of squared plane dimensions
plane
 < 0, 1, 0 >, 0
 texture { pigment { color rgb < 0.24706,  0.38431,  0.058824 > *1.0 }
 finish { ambient 0.0 diffuse 0.0 } }
 rotate< 0, 0, 0 >
//------------------------------------------------ end of squared plane XZ
//---------------------------- objects in scene ---------------------------
box
 < -1.0, -0.5, -1.0 > < 1.0, 1.0, 1.0 >
 texture { T_Copper_1A }
 pigment{ rgbt < 0.20784,  0.19216,  0.25098, 1.0 > }
 finish { reflection 0.5 }
 hollow
 interior
  media
   emission < 0.9, 0.9, 1.0 > *1.5
   absorption < 0.0, 0.0, 0.5 >
   scattering
    3, < 1.0, 1.0, 1.0 >
    extinction  2.0
   density
    gradient < 1.0, 0.25, 0.5 >  // controls the cloud formation
    turbulence 0.5
    frequency 5
    color_map
     [ 0.0 rgb 0.0 ]//border
     [ 0.5 rgb 0.1 ]
     [ 1.0 rgb 1.0 ]//center
    } // end color_map
   } // end of density
  } // end of media ----
 } // end of interior
 translate < 0.0, 1.0, 0.0 >
 scale < 5.0, 1.5, 5.0 >
fog
 fog_type   2
 distance   2
 color rgb < 0.20784,  0.192160,  0.2509800 > *0.8 // Purple
 color rgb < 0.49020,  0.058824,  0.0078431 > *0.8 // Blood Red
 fog_offset 0.1
 fog_alt    1.25
 turbulence 1.8
cylinder
 < 0.0, 0.0, 0.0 > < 0.0, 4.0, 0.0 > 0.25
 texture { T01 }
sphere
 texture { T01 }
http://www.avg.com
Date: 24 Nov 2017 19:18:38
Message: <5a18b6de$1@news.povray.org>
Are you sure that is a shadow? It is in the right area for a reflection.
Regards
Date: 24 Nov 2017 20:30:42
Message: <5a18c7c2$1@news.povray.org>
You misunderstand me. I want to know, how to make the tower creating a
soft, gentle shadow on the clouds.
http://www.avg.com
Date: 24 Nov 2017 21:41:40
Message: <5a18d864@news.povray.org>
> #version 3.7;
> global_settings
>   assumed_gamma 1.0
> #default
> camera
> // sky
> sky_sphere
>   pigment
>    color_map
>    scale 2
> plane
>   < 0, 1, 0 >, 0
>   rotate< 0, 0, 0 >
> //---------------------------- objects in scene ----------------------------
> box
>   hollow
>   interior
>    media
>     //emission < 0.9, 0.9, 1.0 > *1.5 remove
>     //absorption < 0.0, 0.0, 0.5 > probably not needed
>     scattering
>      extinction  2.0
//Should be 1.0 to be acurate
>     density
>      turbulence 0.5
>      frequency 5
>      color_map
>       [ 0.5 rgb 0.1 ]
>      } // end color_map
>     } // end of density
> fog
>   fog_type   2
>   distance   2
>   fog_offset 0.1
>   fog_alt    1.25
>   turbulence 1.8
fog never interact with your light. It just add it's colour over some
distance.
Quick and fast and dirty hack from before media was introduced.
Remove that fog.
> cylinder
>   texture { T01 }
> sphere
>   texture { T01 }
> http://www.avg.com
If your media is not present enough, just increase it's density.
Date: 24 Nov 2017 21:44:17
Message: <5a18d901$1@news.povray.org>
> http://www.avg.com
Remove that emissive madis and that fog.
Both are killing the shadow.
Date: 24 Nov 2017 23:04:54
Message: <5a18ebe6@news.povray.org>
You are right I did. Alain's post should do it.
Regards
