simple example image for a cloud surface to start with
Scene file at
http://news.povray.org/povray.text.scene-files/message/%3Cweb.5a186b419a2a53c19ae32810%40
Download 'cloud_surface.png' (234 KB)
Preview of image 'cloud_surface.png'
> Scene file at
a53c19ae32810%40
Yes, that cloud looks good enough for my needs! Thanks a lot!
But here's one more question: I don't want the cloud surface to be flat
like a plane. Is there any way, to get it slightly rounded, like it
follows the round shape of a planet? I want to see, at a vast distance,
the horizon, that's why.
http://www.avg.com
> Scene file at
Have a look at the a:
I am quite happy with the shape of the clouds, but there are some things
where I don't know how to change:
- that the tower disappears slowly below cloud surface (now it is white)
- that the tower puts its gentle smooth shadow on the clouds
- that the clouds are lilac in shadow and remain pink in light
- and pink (as now) in the illuminated areas
Any suggestions?
http://www.avg.com
Download 'sl - cloud cities.jpg' (171 KB)
Preview of image 'sl - cloud cities.jpg'
Am 25.11.2017 um 00:36 schrieb Sven Littkowski:
Make sure to use scattering media with an extinction value of 1.0.
Also, do use the newest version of POV-Ray, and do use the default media
sampling method (2 I think). Media has seen several fixes of the
underlying math, some of which could not be applied to the older
sampling methods.
I forgot to post the scene code:
#version 3.7;
global_settings
assumed_gamma 1.0
#default
finish { ambient 0.0 diffuse 0.0 }
#include "textures.inc"
#include "glass.inc"
#include "metals.inc"
#include "golds.inc"
camera
/*ultra_wide_angle*/ angle 20 // diagonal view
location < -20.0 , 15.0 ,-00.0 >
look_at < 0.0 , 2 , 0.0 >
// sun -------------------------------------------------------------------
light_source { < 250, 100, -250 > color < 1.0, 0.62353, 0.46667 > *5 }
// sky
sky_sphere
pigment
gradient < 0, 1, 0 >
color_map
[ 0.0 color rgb < 1.00000, 0.62353, 0.46667 > ] // Pink
[ 0.4 color rgb < 0.64706, 0.30588, 0.59608 > ] // Purple
[ 0.6 color rgb < 0.64706, 0.30588, 0.59608 > ] // Purple
[ 1.0 color rgb < 1.00000, 0.62353, 0.46667 > ] // Pink
scale 2
// ground -----------------------------------------------------------------
//---------------------------------<<< settings of squared plane dimensions
plane
< 0, 1, 0 >, 0
texture { pigment { color rgb < 0.24706, 0.38431, 0.058824 > *1.0 }
finish { ambient 0.0 diffuse 0.0 } }
rotate< 0, 0, 0 >
//------------------------------------------------ end of squared plane XZ
//---------------------------- objects in scene ---------------------------
box
< -1.0, -0.5, -1.0 > < 1.0, 1.0, 1.0 >
texture { T_Copper_1A }
pigment{ rgbt < 0.20784, 0.19216, 0.25098, 1.0 > }
finish { reflection 0.5 }
hollow
interior
media
emission < 0.9, 0.9, 1.0 > *1.5
absorption < 0.0, 0.0, 0.5 >
scattering
3, < 1.0, 1.0, 1.0 >
extinction 2.0
density
gradient < 1.0, 0.25, 0.5 > // controls the cloud formation
turbulence 0.5
frequency 5
color_map
[ 0.0 rgb 0.0 ]//border
[ 0.5 rgb 0.1 ]
[ 1.0 rgb 1.0 ]//center
} // end color_map
} // end of density
} // end of media ----
} // end of interior
translate < 0.0, 1.0, 0.0 >
scale < 5.0, 1.5, 5.0 >
fog
fog_type 2
distance 2
color rgb < 0.20784, 0.192160, 0.2509800 > *0.8 // Purple
color rgb < 0.49020, 0.058824, 0.0078431 > *0.8 // Blood Red
fog_offset 0.1
fog_alt 1.25
turbulence 1.8
cylinder
< 0.0, 0.0, 0.0 > < 0.0, 4.0, 0.0 > 0.25
texture { T01 }
sphere
texture { T01 }
http://www.avg.com
Are you sure that is a shadow? It is in the right area for a reflection.
Regards
You misunderstand me. I want to know, how to make the tower creating a
soft, gentle shadow on the clouds.
http://www.avg.com
> #version 3.7;
> global_settings
> assumed_gamma 1.0
> #default
> camera
> // sky
> sky_sphere
> pigment
> color_map
> scale 2
> plane
> < 0, 1, 0 >, 0
> rotate< 0, 0, 0 >
> //---------------------------- objects in scene ----------------------------
> box
> hollow
> interior
> media
> //emission < 0.9, 0.9, 1.0 > *1.5 remove
> //absorption < 0.0, 0.0, 0.5 > probably not needed
> scattering
> extinction 2.0
//Should be 1.0 to be acurate
> density
> turbulence 0.5
> frequency 5
> color_map
> [ 0.5 rgb 0.1 ]
> } // end color_map
> } // end of density
> fog
> fog_type 2
> distance 2
> fog_offset 0.1
> fog_alt 1.25
> turbulence 1.8
fog never interact with your light. It just add it's colour over some
distance.
Quick and fast and dirty hack from before media was introduced.
Remove that fog.
> cylinder
> texture { T01 }
> sphere
> texture { T01 }
> http://www.avg.com
If your media is not present enough, just increase it's density.
> http://www.avg.com
Remove that emissive madis and that fog.
Both are killing the shadow.
You are right I did. Alain's post should do it.
Regards
