POV-Ray : Newsgroups : povray.binaries.images : Faux Dupin Cyclide Server Time
21 Mar 2026 05:56:39 EDT (-0400)
  Faux Dupin Cyclide (Message 12 to 14 of 14)
Subject: Re: Faux Dupin Cyclide
Date: 30 May 2017 13:00:01
Message: <web.592da4f99364765ac437ac910@news.povray.org>
With regard to my continuing interest in tori, esp the Clifford Torus, and their
relationship to the Dupin cyclide by geometric inversion, I was playing with
some inversion code, and ran into some strange artefacts.
Perhaps someone can see what's going on here.   It seems very strange to lose
all of the objects above a straight line.
I had another instance where just the top right quadrant got wiped out.
#version 3.7;
global_settings{ assumed_gamma 1.0}
#include "math.inc"
sky_sphere {pigment {gradient <0,1,0>
                      color_map { [0.00 rgb <0.6,0.7,1.0>/2]
                                  [0.25 rgb <0.0,0.1,0.8>/4]
                                  [0.75 rgb <0.0,0.1,0.8>/4]
                                  [1.00 rgb <0.6,0.7,1.0>/2]
                      scale 2
                    } // end of pigment
          } //end of skysphere -------------------------------------
light_source { <-20, 100, -200>, 1 }
 location <0, 0, -20>
 up y
 look_at 0
#declare Line = 0.1;
#declare O = <0, 2, 0>;
#declare R = 3;
#declare Center = sphere {O, Line pigment {Green}}
#declare Circle_C = torus {R, Line pigment {Green} rotate x*90 translate O}
#macro Inverse (Point, CircleCenter, CircleRadius)
 #local P = vnormalize (Point);
 #local C = vnormalize (CircleCenter);
 <(Point.x-CircleCenter.x)*(R*R)/(pow(Point.x-CircleCenter.x,
2)+pow(Point.y-CircleCenter.y, 2)+pow(Point.z-CircleCenter.z, 2)) +
CircleCenter.x,
  (Point.y-CircleCenter.y)*(R*R)/(pow(Point.x-CircleCenter.x,
CircleCenter.y,
  (Point.z-CircleCenter.z)*(R*R)/(pow(Point.x-CircleCenter.x,
CircleCenter.z>
object {Center}
object {Circle_C}
#declare TCenter = <-4, 2, 0>;
#declare r0 = 2;
#declare r1 = 0.5;
// torus
#declare XT = function (TT, TP, TR, Tr) {(cos(TT) * ( TR + Tr * cos(TP) ))}
#declare YT = function (TT, TP, TR, Tr) {sin(TT) * ( TR + Tr * cos(TP) )}
#declare ZT = function (TP, Tr) {Tr * sin(TP)}
#for (Torus, 0, 1.5, 0.5)
 #declare TCenter = TCenter + <Torus, 0, 0>;
 #declare Steps = 180;
 #for (Theta, 0, tau, tau/Steps)
  #for (Phi, 0, tau, tau/Steps)
  #declare X = XT (Theta, Phi, r0, r1) + TCenter.x;
  #declare Y = YT (Theta, Phi, r0, r1) + TCenter.y;
  #declare Z = ZT (Phi, r1) + TCenter.z;
   //sphere {<X, Y, Z>, Line pigment {White}}
   sphere {Inverse(<X, Y, Z>, O, R), Line pigment {Blue*Torus}}
Download 'inversiontest.png' (358 KB)
Preview of image 'inversiontest.png'
Date: 30 May 2017 16:37:31
Message: <592dd80b$1@news.povray.org>
I got a completely blank image, except for the sky_sphere.
I also got these warnings:
----------[BEGIN MESSAGES]----------
Parsing 16549K tokens
File 'baldeagle-inversiontest.pov' line 54: Parse Warning: Divide by zero.
File 'baldeagle-inversiontest.pov' line 57: Parse Warning: Divide by zero.
File 'baldeagle-inversiontest.pov' line 60: Parse Warning: Divide by zero.
Parsing 36707K tokens
-----------[END MESSAGES]-----------
Please note that, as I saved your post, the #version statement is on
line 18.  If the #version is at the top of your scene file, you'll have
to subtract 17 from the above line numbers.  I also suspect several line
breaks introduced by the news software right about where the divisions
by zero occur.
> #version 3.7;
Evidently, your scene requires #version 3.71;
Date: 30 May 2017 16:55:36
Message: <592DDC44.6070400@aol.com>
> by zero occur.
Right you are.
Two line wraps on three lines. Copied from Thunderbird.
Regards
