POV-Ray : Newsgroups : povray.binaries.images : Visualizing camera view frustum Server Time
28 May 2024 17:12:49 EDT (-0400)
  Visualizing camera view frustum (Message 11 to 18 of 18)
Subject: Re: Visualizing camera view frustum
Date: 17 Apr 2017 15:10:01
Message: <web.58f511fa1652a4dcc437ac910@news.povray.org>
Mike Horvath <mik### [at] gmailcom> wrote:
> Make sure you are using radians and degrees properly. You may have to
> convert between the two.
Well, the thing is, when I do it all in SDL, it works out fine.
I send the value of angle out to the debug stream, and it's the expected 68.3
degrees or whatever.
Then I work it all out step by step in Excel, and it's just looking WAY off.
See my rows labeled radians and degrees.
I'm using degrees = (radians /pi)*180, and it gives me the same result as
Excel's degrees() function.   So I'm wondering if the atan2 function is flawed.
Date: 17 Apr 2017 15:55:29
Message: <58f51db1$1@news.povray.org>
Do you know for sure this is the correct answer?
Mike
Date: 17 Apr 2017 16:16:02
Message: <58f52282$1@news.povray.org>
On 4/17/2017 7:47 AM, Bald Eagle wrote:
> I was trying to work out a few things, and was using my code and that in
> screen.inc as a guide, but of course nothing ever works out the way it's
> supposed to.
> Excel gives me wildly different results from what POV-Ray returns for the camera
> view angle formula.
> #declare Angle = 2*atan2d (0.5*CamR.x*Camera_Aspect_Ratio, CamD.z*Camera_Zoom);
> I was hoping someone could run a quick check and confirm.
> This certainly wouldn't be the first time Excel was just plain wrong.
What input values are you using?
Mike
Date: 18 Apr 2017 07:55:00
Message: <web.58f5fdbb1652a4dcc437ac910@news.povray.org>
> Mike
It's just the standard default camera.
So, CamR.x = 1
Aspect ratio = 1.33333333333.......
CamD.z = 1
and Camera zoom = 1
so the calculation basically works out to be 2 * atan2 (0.666666666666666.....)
  converted to degrees
which ought to be very close to 67.38
It works just fine in POV-Ray, I'm just wondering what's getting buggered up in
Excel, or if I'm having an extended "senior moment"
Date: 18 Apr 2017 08:59:10
Message: <58f60d9e$1@news.povray.org>
atan2 takes 2 parameters, this is important and likely where you've gone
wrong. Make sure you've got the parameters the right way round - Excel
takes (x,y) not (y,x).
If you've already pre-calculated the y/x gradient (eg 0.66666) then for
atan2 to give the correct result in Excel you need to use
atan2(1,0.666666). If you do it the other way round atan2(0.66666,1)
then you're going to get the wrong answer.
2*degrees(atan2(1,0.666666)) gives 67.38 degrees in Excel.
Date: 18 Apr 2017 09:11:33
Message: <58f61085@news.povray.org>
Am 18.04.2017 um 13:51 schrieb Bald Eagle:
As Scott just pointed out, Excel has `ATAN2(X;Y)`, while virtually all
proper programming languages have `atan2(y,x)`.
Date: 18 Apr 2017 10:10:01
Message: <web.58f61de31652a4dcc437ac910@news.povray.org>
Ah yes.
Apparently I was having a "Microsoft Moment".
Thanks for restoring my sanity (such as it is)  ;)
Date: 18 Apr 2017 11:54:21
Message: <58f636ad$1@news.povray.org>
Beware, atan2 is not always taking parameters in same order.
In Povray SDL, atan2(A,B) gives the angle in radians of tangent (A/B).
In C (man page), atan2(y,x) gives the angle in radians of tangent (y/x)
In Excel, atan2(x_num,y_num) ... yes, they swapped the parameters !
