POV-Ray : Newsgroups : povray.binaries.images : Catenary Bridge (WIP) Server Time
20 Aug 2025 16:27:04 EDT (-0400)
  Catenary Bridge (WIP) (Message 1 to 10 of 10)
Subject: Catenary Bridge (WIP)
Date: 3 Jun 2016 21:50:04
Message: <web.575233129834c9d25e7df57c0@news.povray.org>
Because catenary bridges are way cooler than power lines.   :)
Download 'catenarybridge.png' (1054 KB)
Preview of image 'catenarybridge.png'
Subject: Re: Catenary Bridge (WIP)
Date: 3 Jun 2016 23:40:02
Message: <web.57524c8615adef735e7df57c0@news.povray.org>
Slight progress before packing it in for the night.
Adjusted scale of struts, added cross-braces, red iron oxide paint texture,
added quick heightfield mountains, water, sky sphere.
Download 'catenarybridge.png' (1578 KB)
Date: 4 Jun 2016 09:45:28
Message: <5752db78$1@news.povray.org>
Cool. I've always enjoyed views of such bridges. The New Rivers Gorge
bridge as an example.
Bill P.
Date: 4 Jun 2016 22:55:00
Message: <web.575393bd15adef735e7df57c0@news.povray.org>
> Bill P.
I actually managed to grab the geo data from USGS, convert it into a png, and
then a heightfield, and once I got it all scaled and un-lost myself in the
aerial view, I managed to get things reasonably aligned.
Still needs some scaling and repositioning, and then it's mostly a matter of
working on the textures, seeing what I can do with plants again :O  and all of
that skilled stuff that takes forever.   :D
Download 'catenarybridge.png' (812 KB)
Date: 5 Jun 2016 02:40:03
Message: <5753c943$1@news.povray.org>
>> Bill P.
> Thanks  :)
Good work!
Maybe the USGS data are a bit too /global/ for this scale? A bit of
extra roughness added to the png should do the trick.
Date: 5 Jun 2016 16:45:00
Message: <web.57548e3415adef735e7df57c0@news.povray.org>
> Good work!
Thanks - though it was just a quick mock-up.
Why yes, as I found out.
The only data set I can find of that area is a 1 sec arc that covers something
like 69 miles square.
Once I figured out just HOW BIG the map was, corrected the scale, oriented
myself, found my way through it, and zoomed WAY WAY in to where I actually
wanted to be....   :O
I had to convert the original color png to a 16-color, and that brought out all
the elevation data, but at that resolution, it looks like Hell.
> A bit of  extra roughness added to the png should do the trick.
> Thomas
Any recommendations for data sources, fixing up what I've got?
"extra roughness"?
Date: 6 Jun 2016 02:59:52
Message: <57551f68@news.povray.org>
On 5-6-2016 22:40, Bald Eagle wrote:
>> Good work!
> wanted to be....   :O
Yes, those are huge. It has been more than 15 years ago when I last
played with USGS data (I must have a couple of CD-ROMs with DEM data
gathering dust somewhere) and they are great for overviews but not
detailed enough for close up. We always want better of course ;-)
>> Thomas
> "extra roughness"?
I think I miscalculated here :-) Now I seem to remember that the png are
processed elevation data, not something you can modify out of hand. Just
a thought: use the png inside a function with some randomisation?
However, I am afraid that would totally change the resulting landscape.
Date: 6 Jun 2016 07:15:01
Message: <web.57555a5015adef735e7df57c0@news.povray.org>
That 15 (or 20) years just blinks by, doesn't it?
> Just
Now there's something I wouldn't have thought of - or even thought I could do.
:O
I'll try to dig up some code to do that when I get back in tonight.
I tried blurring it, but that didn't work out so well.
Date: 6 Jun 2016 07:28:36
Message: <57555e64$1@news.povray.org>
Yes, it does. The memory is diffuse about the matter however.
>> Just
> :O
> Thanks  :)
I'll try to dig through the accumulated dirt to find something useful.
Don't hold your breath though ;-)
Date: 7 Jun 2016 03:51:56
Message: <57567d1c$1@news.povray.org>
This is something you can play with as an example:
#declare F_HF_01 =
function {
     image_map {
       tga "MyImage.tga" //gamma 1.0
       map_type 0
       interpolate 2
     warp {repeat x}
     warp {repeat y}
     rotate 90*x
     scale 50
     warp {
       turbulence 0.5
       octaves 2 //[6]
       lambda 1  //[2]
       omega 0.2 //[0.5]
     scale 1/50
#declare P =
function {
   F_HF_01(x, y, z).hf
   - f_hetero_mf(x,y,z, 0.8, 2, 5, 0, 0.9, 2)*0.3
   //- f_noise3d(x,y*2,z)*0.5
   - f_agate(x,y,z)*0.01
height_field{
   function 500, 500 {P((x-0.5)*MyXscale+0.5, 0, (y-0.5)*MyZscale+0.5)}
   translate <-0.5, 0, -0.5>
   scale <MyScale>
   pigment {MyPigment}
This is from an old test scene of mine, partly based on an example by
Mike Williams.
