POV-Ray : Newsgroups : povray.binaries.images : Irid vs SSLT redux (with less assumed gamma) Server Time
29 May 2024 03:11:29 EDT (-0400)
  Irid vs SSLT redux (with less assumed gamma) (Message 11 to 17 of 17)
Subject: Re: Irid vs SSLT redux (with less assumed gamma)
Date: 2 May 2016 20:20:08
Message: <5727eeb8@news.povray.org>
> Oh, and one more thing...
> Am 02.05.2016 um 14:40 schrieb Simon J. Cambridge:
>> Points of note. The meshes need severe sub-division, the more the merrier. I
>> also ran the gamut of 20 to 50 mm_per_unit for SSLT and settled on 40.
> The mm_per_unit setting is not up for debate. Whatever distance in mm
> one POV-Ray unit of distance supposedly corresponds to, that's the exact
> value to plug in there.
> So suppose your elf is 190 units tall, then mm_per_unit must be set to
> 10, because we all know eleves stand 1.90 m tall. (Unless of course it's
> an elf, in which case mm_per_unit must be set to 1, because we all know
> elfs are 19 cm in height).
> All tweaking is to be done on the translucency parameter.
Ordinary Elf from D&D are around 5' tall, but those from Athas are 7'
tall and polar Elf are 7.5'.
Those from Elfquest are about 2.5 to 3', while the Ancients are 7 to 8'
tall.
I've seen some as short as 5cm all the way up to 3m tall in a variety of
other settings.
The height variations are *MUCH* larger that those among Humans. That
mean that any hight you give to your elf is exact.
Date: 3 May 2016 03:00:49
Message: <57284ca1$1@news.povray.org>
On 2-5-2016 17:20, clipka wrote:
> Am 02.05.2016 um 16:47 schrieb Simon J. Cambridge:
>> Actually, the being depicted is not an Elf! (And in making such a rash and
>> unwarranted assumption you have seriously dented your credibility in the process
>> - you need to read my books to find out more.)*
> What -- and delay POV-Ray development? No way! ;)
> (To be honest, I guess I'm not a book person anymore. I just don't find
> the time, opportunity and patience these days.)
Sad! Sad! Sad!  :-)
>> have to mess with the numbers as the being depicted is roughly ten feet tall.
>> (You really need to read my books to find out more)**
> Must be a troll then.
> A seriously skinny one. You need to feed it better. :P
Watch out! You are well on the way to make an enemy for life ;-)
> random association: https://youtu.be/cITjfIMXN0g
Date: 3 May 2016 15:45:01
Message: <web.5728ff04aca34b7887fca9f40@news.povray.org>
> POV-Ray 3.6 already supported the "assumed_gamma" statement.
> Half-heartedly, but it did.
And so did 3.5, for that matter.
Date: 3 May 2016 15:45:02
Message: <web.5728ff6daca34b7887fca9f40@news.povray.org>
> tall.
Do you all still use ' in Canada?
Date: 3 May 2016 16:34:29
Message: <57290b55$1@news.povray.org>
Am 03.05.2016 um 21:43 schrieb Cousin Ricky:
>> tall.
Maybe not, but the authors of fantasy roleplay games -- most of which
are Americans -- still do.
Date: 3 May 2016 17:22:28
Message: <57291694$1@news.povray.org>
>>> tall.
And I do too.
Along with " for inches.
Regards
Date: 4 May 2016 12:36:00
Message: <572a24f0$1@news.povray.org>
>> tall.
Yes.
