POV-Ray : Newsgroups : povray.binaries.images : sky light render Server Time
26 Jun 2024 09:20:55 EDT (-0400)
  sky light render (Message 11 to 20 of 23)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Re: sky light render
Date: 9 Apr 2016 08:00:11
Message: <5708eecb$1@news.povray.org>
Am 09.04.2016 um 13:38 schrieb LanuHum:
>>> I'm develop a sky light generator.
>>> It is near finished. This is a demo image.
>> Files at
http://news.povray.org/povray.binaries.scene-files/thread/%3Cweb.5707d40c6218fcf9af5560460%40news.povray.org%3E/
>> I write it fast because I also want to release it quickly.
>> I must go to bed.
> I downloaded, I rendered...
> This sky?
This! Is! SPARTA!
Sorry, couldn't resist :)
Date: 9 Apr 2016 09:15:00
Message: <web.5708fd9b87bb2a51af5560460@news.povray.org>
> > Files at
> > I must go to bed.
> This sky?
You should not change the "real" pov-ray camera on my pov scene.
In fact, you should only modify the setting I describes previously.
Date: 9 Apr 2016 10:05:00
Message: <web.57090bc787bb2a51af5560460@news.povray.org>
> >> Files at
> >> I must go to bed.
> > This sky?
> This! Is! SPARTA!
That's ...ok
Date: 9 Apr 2016 10:25:01
Message: <web.57090f9f87bb2a517a3e03fe0@news.povray.org>
I changed nothing.
If I want to show a cube, I don't turn the camera by 180 degrees from it.
I badly read in English, but I well see the picture. I study changes in source
code looking at the picture. But, in your case I have nothing to begin.
If you wants to show the sky, turn the camera towards the sky.
Date: 9 Apr 2016 10:35:00
Message: <web.570912d987bb2a517a3e03fe0@news.povray.org>
> This! Is! SPARTA!
https://www.buro247.ru/images/BD-PICASSO-acrobate-bleu.jpg
Date: 9 Apr 2016 10:45:01
Message: <web.5709142e87bb2a51af5560460@news.povray.org>
> > Another concept diagram, the principle of this little program. Each pixel on the
> > output image generates a "primary path" to calculate the scattering sun light
> > with many segments. then return the sum of them. the variable
> > 'sky_light_primary_path_res' in the .pov is control the resolution of it.
> > If the 'calc_secondary_scatter' turn on, it will sampling secondary paths on
> > every segment of the primary path. then add the effect "sunlight --> skylight
> > --> skylight". It will much slower when you turn it on. But for a dense/thick
> > atmosphere it will make some difference.
> This is the demo. The left is only the primary scattering, it takes 34s to
> render. the right is calculate the primary + secondary scattering, it takes
> 18m33s to render.
...., I must say, if you want to use it for the environment(lighting), it is not
very well yet. First of all, what's the real extinction coefficient of our
atmosphere. I don't know that very well. The current value is just my guess.
Secondly, the sampling method of the secondary scatter which I implement is not
very good. But you can turn off the ground reflection by setting 'ground_albedo'
zero. It will eliminate the most obvious artifact. Finally, I should calculate
the output color of the sun again(in the output text file).
This image is the comparison of the ground_albedo 0.2 and 0.0. You can see the
artifact disappear.
Download 'demo3.png' (58 KB)
Preview of image 'demo3.png'
Date: 9 Apr 2016 11:10:00
Message: <web.57091ab087bb2a51af5560460@news.povray.org>
> I changed nothing.
Can you download it again? Because I just downloaded and tested it
immediately(unzipped it, then open the file click the 'render'), it is nothing
wrong.
Date: 9 Apr 2016 11:25:00
Message: <web.57091dfc87bb2a51af5560460@news.povray.org>
> > I changed nothing.
> wrong.
When the render finishes, this is what my folder appearance.
Download 'screen.png' (48 KB)
Preview of image 'screen.png'
Date: 10 Apr 2016 02:45:47
Message: <5709f69b$1@news.povray.org>
And that is correct for me too. Maybe you should emphasize that
half_render should be put standard to /false/ so that the whole sky is
rendered, which is more comprehensive. It may take a bit more render
time but that is no problem.
I still have a lot to test but I like it.
Date: 10 Apr 2016 03:21:58
Message: <5709ff16@news.povray.org>
projection (2) gives an error message. In fact, #case(2) is empty.
