POV-Ray : Newsgroups : povray.binaries.images : problem with functions.inc Server Time
20 Mar 2026 10:39:28 EDT (-0400)
  problem with functions.inc (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: problem with functions.inc
Date: 1 Sep 2015 11:40:34
Message: <55e5c6f2@news.povray.org>
On 2015-09-01 07:25 AM (-4), Norbert Kern wrote:
> #declare IterFn =
> function (N, Re, Im, Zr, Zi) {
>          select (
>                  N > 300 | Zr*Zr+Zi*Zi > 4,
>                  0,
>                  IterFn (N+1, Re, Im, Zr*Zr-Zi*Zi+Re, 2*abs (Zr*Zi)+Im),
>                  N/300
Reducing the recursion level does not prevent the crash.  I tried all
the way down to 1.
Date: 1 Sep 2015 15:00:01
Message: <web.55e5f483fed76a76a36927440@news.povray.org>
> > #declare IterFn =
> >          select (
> >                  0,
> >                  N/300
> the way down to 1.
The reason for this, I believe, is that pic doesn't support recursive functions.
You can get away with exactly one, if -and only if- it is defined before
anything else in the file.
A.D.B.
Date: 1 Sep 2015 18:00:01
Message: <web.55e61fb8fed76a762aaea5cb0@news.povray.org>
"Anthony D. Baye" <Sha### [at] spamnomorehotmailcom> wrote:
> > > #declare IterFn =
> > >          select (
> > >                  0,
> > >                  N/300
> > the way down to 1.
pov* -- stupid ipod.
anyway... it causes your system to crash, or just causes povray to crash?
A.D.B.
Date: 1 Sep 2015 19:25:01
Message: <web.55e63331fed76a76e2e8c9770@news.povray.org>
> Regards,
> A.D.B.
Hi Anthony,
only povray. I condensed the problem in perhaps 100 steps by deleting nearly
everything including tests with 3.6 and on a second pc.
There were similar problems with other (typically recursive) functions in the
past, but here I was getting angry, because I like this special fractal very
much.
Norbert
Date: 2 Sep 2015 03:16:16
Message: <55e6a240$1@news.povray.org>
>> declaring *any* function before your IterFn causes the crash.
> Thanks very much
You can get around the problem by unrolling the iteration into 300
different functions in an array:
#declare MAX_ITERATIONS = 300;
#declare Fns = array[MAX_ITERATIONS];
#declare Fns[MAX_ITERATIONS-1] = function (N, Re, Im, Zr, Zi) { 0 }
#local ITERATION = MAX_ITERATIONS-2;
#while(ITERATION>=0)
#declare Fns[ITERATION] =
         select (
                 Zr*Zr+Zi*Zi > 4,
                 0,
                 Fns[ITERATION+1] (N+1, Re, Im, Zr*Zr-Zi*Zi+Re, 2*abs
(Zr*Zi)+Im),
                 ITERATION/300
#local ITERATION=ITERATION-1;
#declare BurningShip = function (Re, Im) {Fns[0] (0, Re, Im, Re, Im)}
Date: 2 Sep 2015 04:15:00
Message: <web.55e6af2efed76a769dd03fb90@news.povray.org>
>          select (
>                  Zr*Zr+Zi*Zi > 4,
>                  0,
> (Zr*Zi)+Im),
>                  ITERATION/300
> #end
wow, it works!
Thank you very much.
Norbert
Date: 2 Sep 2015 09:58:45
Message: <55e70095$1@news.povray.org>
Am 01.09.2015 um 13:25 schrieb Norbert Kern:
> Hi,
> here is minimal code for the famous burning ship fractal.
> It renders fine as long as I don't include functions.inc (in another context I
> need functions.inc).
> Does anybody know the reason?
Yes: POV-Ray doesn't officially support recursive functions.
It works in /some/ cases, but has some quite severe limitations; my
personal recommendation would be to create one function for each level
of recursion; that shouldn't be too difficult using a #for loop and the
Parse_String() macro from strings.inc.
Date: 2 Sep 2015 11:10:00
Message: <web.55e71022fed76a76b426f96a0@news.povray.org>
> > Thanks very much
Wouldn't it use less memory to have only two functions that you #declare and
#undef within the loop?
http://news.povray.org/povray.binaries.scene-files/thread/%3C4ddda4d9%40news.povray.org%3E/
Date: 2 Sep 2015 12:10:01
Message: <web.55e71e86fed76a76b426f96a0@news.povray.org>
Nevermind, I'm pretty sure using only two doesn't save memory :/
Date: 2 Sep 2015 12:31:47
Message: <55e72473$1@news.povray.org>
Am 02.09.2015 um 18:06 schrieb Samuel Benge:
... and you're pretty right ;)
