POV-Ray : Newsgroups : povray.binaries.images : Constructive Solid Geometry: problem! Server Time
19 Nov 2025 07:00:53 EST (-0500)
  Constructive Solid Geometry: problem! (Message 1 to 10 of 11)
Subject: Constructive Solid Geometry: problem!
Date: 8 Aug 2015 14:25:01
Message: <web.55c64901a06367f07a3e03fe0@news.povray.org>
Hi!
Problem with matrixes. :(
#version 3.7;
#include "shapes.inc"
#include "functions.inc"
global_settings {
    assumed_gamma 1.000000
sky_sphere {
    pigment {rgb<0.050, 0.050, 0.050>}
#declare Default_texture = texture{pigment {rgb 0.8}}
#declare Material = texture{
    pigment{color rgbft <0.8000,0.0388,0.1277,0.0000,0.0000>}
    finish{
        diffuse 0.8000
        brilliance 1.8000
        crand 0.0000
        emission 0.0000
        ambient <0.0000,0.0000,0.0000>
#declare data_Box_shape_003_ob = box { -1,1
    texture {Material}
#declare data_Cone_shape_001_ob = cone {
<0,0,-1.0000>,1.0000,<0,0,1.0000>,0.3000
    texture {Default_texture}
#declare data_Box_shape_ob = box { -1,1
#declare data_Box_shape_001_ob = box { -1,1
    texture {Material}
#declare data_Box_shape_002_ob = box { -1,1
    texture {Material}
#declare data_Boolean_000_ob =
difference {
    union {
        object {data_Box_shape_ob
    matrix <1.000000, 0.000000, 0.000000,  0.000000, -0.000000, -1.000000,
0.000000, 1.609000, -0.000000,  3.005314, 0.000000, 0.000000>
    object {data_Cone_shape_001_ob
    matrix <1.000000, 0.000000, 0.000000,  0.000000, 1.000000, 0.000000,
0.000000, 0.000000, 2.432501,  2.941242, 0.000000, 0.000000>
#declare data_Boolean_001_ob =
difference {
    union {
object {data_Boolean_000_ob
    rotate x*90
0.000000, 1.609000, -0.000000,  -0.840426, 0.000000, 0.000000>
object {data_Box_shape_003_ob
    matrix <0.166166, 0.000000, 0.000000,  0.000000, -0.000000, -0.166166,
0.000000, 0.166166, -0.000000,  0.000000, 1.426066, 1.168468>
object {data_Boolean_001_ob
    rotate x*90
0.000000, 1.609000, -0.000000,  1.365901, 0.000000, 0.000000>
object {data_Box_shape_001_ob
0.000000, 0.166166, -0.000000,  0.000000, -1.779218, 1.168468>
object {data_Box_shape_002_ob
0.000000, 1.297221, -0.000000,  2.212118, 1.555311, 0.825095>
light_source {
    <5.07,5.58,4.28>
    color rgb<1, 1, 1>
    fade_distance 25.0000000000
    fade_power 1
    perspective
    location  <0,0,0>
    look_at  <0,0,-1>
    right <-1.7777777777777777, 0, 0>
    up <0, 1, 0>
    angle  49.134343
    rotate  <-27.098163, 46.688390, -0.903519>
    translate <7.481132, 5.343666, 6.507640>
Download 'csg-problem.jpg' (90 KB)
Preview of image 'csg-problem.jpg'
Subject: Re: Constructive Solid Geometry: problem!
Date: 8 Aug 2015 19:35:00
Message: <web.55c691044327e3232aaea5cb0@news.povray.org>
"LanuHum" <Lan### [at] yandexru> wrote:
> Hi!
> #version 3.7;
> global_settings {
> sky_sphere {
>     finish{
>         diffuse 0.8000
>         brilliance 1.8000
>         crand 0.0000
>         emission 0.0000
>     texture {Material}
>     texture {Material}
>     texture {Material}
> difference {
>     union {
> difference {
>     union {
>     rotate x*90
>     rotate x*90
> light_source {
>     <5.07,5.58,4.28>
>     color rgb<1, 1, 1>
>     fade_power 1
> camera {
>     perspective
>     location  <0,0,0>
>     look_at  <0,0,-1>
>     up <0, 1, 0>
>     angle  49.134343
without further explanation of what you're trying to accomplish, the only thing
I can see is that your z axis appears to be flipped between the wireframe on the
right and the render on the left.
Your camera is a lot more complex than I would normally use, but I assume this
is a result of export from blender.
Normally, I would simply have
up y
right x*(image_width/image_height)
and adjust my height and width on the command line, or via an ini file.
I assume specifying the angle compensates for distortion in the foreground from
having a wide format aspect ratio with a perspective camera...
I also notice that you've converted your camera for a right-handed coordinate
system by negating the aspect ratio and looking toward the negative z... This
might explain the flipped axis.  Is blender right-handed or left?
A.D.B.
Date: 8 Aug 2015 20:15:00
Message: <web.55c69ae94327e3237a3e03fe0@news.povray.org>
> up y
> Regards,
> A.D.B.
There are objects which are correctly displayed. Color - red. Look in the
3D-viewport.
Only csg are incorrectly displayed. What does it have to do with camera?
I create box:
#declare obBox = box{}
I create cone:
#declare obCone = cone{}
I create csg:
#declare obBox_Minus_obCone = difference{
object {obBox matrixBox}
object {obCone matrixCone}
I make transformation and I declare:
object{obBox_Minus_obCone matrixObBox_Minus_obCone}
Result wrong
Date: 9 Aug 2015 01:35:00
Message: <web.55c6e45d4327e3232aaea5cb0@news.povray.org>
> > up y
> > Regards,
> > A.D.B.
> 3D-viewport.
> I create box:
> I create cone:
> I create csg:
> Result wrong
As near as I can tell, your objects are exactly where your matrix
transformations say they should be, though that's a really ambiguous way of
performing a scale and translate.
the offending translations appear to be happening in your difference objects.
matrix <
and
matrix <
Respectively, seem to have the objects shifted in the positive x axis.
I inserted axes using:
union {
    cylinder { -1e5*x, 1e5*x 1/128 pigment { rgb <1,0,0> } }
    cylinder { -1e5*y, 1e5*y 1/128 pigment { rgb <0,1,0> } }
    cylinder { -1e5*z, 1e5*z 1/128 pigment { rgb <0,0,1> } }
x: red
y: green
z: blue
A.D.B.
Download 'lanu01.png' (111 KB)
Preview of image 'lanu01.png'
Date: 9 Aug 2015 02:10:00
Message: <web.55c6edc04327e3232aaea5cb0@news.povray.org>
I edited your description for legibility, and added a camera above, looking
down:
#version 3.7;
global_settings {
sky_sphere {
    finish{
        diffuse 0.8000
        brilliance 1.8000
        crand 0.0000
        emission 0.0000
    texture {Material}
    texture {Material}
    texture {Material}
difference {
    union {
difference {
    union {
    rotate x*90
    rotate x*90
light_source {
    <5.07,5.58,4.28>
    color rgb<1, 1, 1>
    fade_power 1
    perspective
    location  <0,0,0>
    look_at  <0,0,-1>
    up <0, 1, 0>
    angle  49.134343
// Camera above, looking down
    perspective
    location <0.0, 10, 0.06>
    up z
    look_at 0
union {
You'll notice that things weren't exactly as they seemed in the isometric view
that blender provides.
This is one of the things I dislike about the controls in blender. They don't
provide you per-axis translation, so you can't be certain that things are where
you think they are.
Unless blender has an orthographic three-panel view that I haven't found...
A.D.B.
Download 'lanu02_topdown.png' (42 KB)
Preview of image 'lanu02_topdown.png'
Date: 9 Aug 2015 02:59:56
Message: <55c6fa6c$1@news.povray.org>
It's hard to tell in the image on the right what is solid and what isn't
due to the transparency.
Mike
Date: 9 Aug 2015 04:35:01
Message: <web.55c70fd34327e3237a3e03fe0@news.povray.org>
> Regards,
> A.D.B.
In 3D-window: Menu => View => Toggle Quad View
#version 3.7;
global_settings {
sky_sphere {
    pigment{color rgbft <0.8000,0.0300,0.0546,0.0000,0.0000>}
#declare Material_001 = texture{
    pigment{color rgbft <0.8000,0.0510,0.0190,0.0000,0.0000>}
#declare Material_002 = texture{
    pigment{color rgbft <0.7838,0.8000,0.0830,0.0000,0.0000>}
#declare data_Box_shape_006_ob = box { -1,1
    texture {Material_001}
#declare data_Box_shape_005_ob = box { -1,1
#declare data_Box_shape_004_ob = box { -1,1
#declare data_Cone_shape_ob = cone { <0,0,-1.0000>,1.0000,<0,0,1.0000>,0.3000
    texture {Material}
    texture {Material_002}
#declare data_Boolean_002_ob =
difference {
    union {
0.000000, 2.166961, -0.000000,  0.000000, 0.000000, 0.000000>
    object {data_Cone_shape_ob
        texture {Material}
    matrix <1.073773, 0.000000, 0.000000,  0.000000, -1.038544, -0.272790,
0.000000, 0.272790, -1.038544,  0.000000, 0.000000, 0.598508>
difference {
    union {
        texture {Material}
#declare data_Boolean_ob =
difference {
    union {
        texture {Material}
object {data_Boolean_002_ob
    rotate x*90
    matrix <0.702762, 0.000000, 0.000000,  0.000000, -0.000000, -0.702762,
0.000000, 1.522857, -0.000000,  -1.625485, 0.000000, 0.000000>
    rotate x*90
0.000000, 1.522857, -0.000000,  1.729432, 0.000000, 0.000000>
object {data_Box_shape_006_ob
    matrix <0.000000, -2.966263, 0.000000,  0.000000, -0.000000, -0.118176,
0.118176, 0.000000, 0.000000,  0.000000, -0.098659, 0.806181>
object {data_Box_shape_005_ob
0.118176, 0.000000, 0.000000,  0.012403, -0.098659, -0.806181>
object {data_Box_shape_004_ob
0.118176, 0.000000, 0.000000,  0.855792, -0.098659, 0.000000>
0.118176, 0.000000, 0.000000,  -0.744167, -0.098659, 0.000000>
    matrix <2.966263, 0.000000, 0.000000,  0.000000, -0.000000, -0.118176,
0.000000, 0.118176, -0.000000,  0.000000, -1.649006, 0.000000>
0.000000, 0.118176, -0.000000,  0.000000, 1.635401, -0.000000>
object {data_Boolean_ob
    rotate x*90
0.000000, 1.522857, -0.000000,  0.000000, 0.000000, 0.000000>
light_source {
    <5.07,5.58,4.28>
    color rgb<1, 1, 1>
    fade_power 1
    perspective
    location  <0,0,0>
    look_at  <0,0,-1>
    up <0, 1, 0>
    angle  49.134343
Download 'for_views.jpg' (271 KB)
Preview of image 'for_views.jpg'
Date: 9 Aug 2015 13:37:53
Message: <55c78ff1$1@news.povray.org>
Am 08.08.2015 um 20:22 schrieb LanuHum:
> Hi!
It's difficult for me to tell from the images what's happening; however,
in general I would check...:
- whether the matrix export /per se/ works properly, and puts the
coefficients in the right order; and
- whether in this case the actual matrix should be exported, or its
inverse instead.
Also, if in Blender the transformation is stored in a different format
(like a set of rotation and a scaling operations), then I would suggest
exporting those, instead of trying to "bake" them into a matrix.
Date: 9 Aug 2015 14:35:00
Message: <web.55c79c164327e3237a3e03fe0@news.povray.org>
If the object is transformed by modifiers, I can't receive its arrangement
without matrix:
translate = matrix.translation[:]
rotate = tuple([degrees(e) for e in matrix.to_3x3().to_euler()])
scale = matrix.to_scale()[:]
But, without modifiers - seldom it is ( little) used.
Orientation of the exporter - animation.
The user will use armature (bones), array, array with curve, dupliverts,
dupliface, dupliframe, dupligroup, particles.
All coordinates are calculated from object.matrix_world
> inverse instead.
matrix.inverse csg or components?
I in matrixes understand nothing!!! :(
Date: 9 Aug 2015 14:58:31
Message: <55c7a2d7$1@news.povray.org>
Am 09.08.2015 um 20:29 schrieb LanuHum:
>> inverse instead.
I'm refering to the matrix inverse here. In a nutshell, a matrix's
inverse is the matrix that, when applied, reverts the effect of applying
the matrix itself: If the original matrix applies a rotation, the
inverse applies the opposite rotation; if the original matrix applies a
scaling by the factor N in any direction, the inverse applies a scaling
by the factor 1/N in that same direction; if the original matrix applies
a translation by a vector V, the inverse applies a translation by -V;
and if a matrix applies any combination of the above in a particular
order, the inverse applies the respective inverse of the individual
operations in reverse order.
In raytracing, a transformation matrix's inverse is needed internally
for some computations, so maybe in some cases, what Blender considers
"the operation" might be what POV-Ray considers "the inverse of the
operation".
