POV-Ray : Newsgroups : povray.binaries.images : polygon to circle loft Server Time
18 Mar 2026 08:53:51 EDT (-0400)
  polygon to circle loft (Message 32 to 41 of 51)
Subject: Re: polygon to circle loft
Date: 12 May 2015 13:05:01
Message: <web.555231c8908ae4217a3e03fe0@news.povray.org>
"And" <49341109@ntnu.edu.tw> wrote:
> The file is here:
http://news.povray.org/povray.binaries.scene-files/thread/%3Cweb.5551a29627d064353f4ed4340%40news.povray.org%3E/
> You can just include it and use the macro:
> //------coding here------------
> #include "blending_polygon_circle_shape.inc"
> object{
> Shape_Polygon_To_Circle_Blending(5, x, 0.3, 0.1, 0.8)
> pigment{rgb<0.5,0.56,0.5>}
> 1. The macro create a shape that blend a regular polygon of which center is at
> <0,0,0>, to a circle of which center at <0,0, height>.
> 2. The first parameter is the number of sides of the polygon.
> 3. The second parameter is a vector.
> 4. The third parameter is the circumscribed circle radius of the polygon.
> 5. The fourth parameter is the radius of the circle.
> 6. The fifth parameter is the height of the shape.
Thanks!
Date: 13 May 2015 04:07:16
Message: <55530634$1@news.povray.org>
And wrote on 11/05/2015 18.01:
> Well, here is its bottom.
:D
Date: 13 May 2015 13:35:01
Message: <web.55538a7e908ae4217a3e03fe0@news.povray.org>
> The file is here:
> object{
even it is correct, odd it is incorrect
Download 'polynomcircle.jpg' (59 KB)
Preview of image 'polynomcircle.jpg'
Date: 14 May 2015 03:45:01
Message: <web.5554517b908ae4213f4ed4340@news.povray.org>
I have to get to work, I will investigate it later.
Date: 14 May 2015 11:45:03
Message: <web.5554c26b908ae4213f4ed4340@news.povray.org>
Could you give me an example (code)?
I never saw it.
Date: 14 May 2015 12:15:01
Message: <web.5554c9d2908ae4213f4ed4340@news.povray.org>
My renderings
Download 'loft test2 7 tri.png' (38 KB)
Preview of image 'loft test2 7 tri.png'
Date: 14 May 2015 12:20:01
Message: <web.5554cada908ae4213f4ed4340@news.povray.org>
I have a question.
Can I upload more than one picture here?
Download 'loft test2 7 quad.png' (40 KB)
Preview of image 'loft test2 7 quad.png'
Date: 14 May 2015 13:00:01
Message: <web.5554d462908ae4217a3e03fe0@news.povray.org>
> I never saw it.
#version 3.7;
global_settings {
background {rgbt<0.05, 0.05, 0.05, 0>}
#declare Default_texture = pigment {rgb 0.8}
#declare Material = texture {pigment {rgbt <0.8,0.8,0.8,0>}}
#declare height = 0.5;
#declare poly_n = 3;
#declare poly_r = 0.5;
#declare cycle_r = 0.13;
#declare an = 2*pi/poly_n;
#declare poly_thr = poly_r*cos(an/2);
#declare bound=max(cycle_r,poly_r);
#declare multi = 10;
#declare poly_obj =
polynomial{
4,
xyz(0,2,2):multi*1,
xyz(2,0,1):multi*2*height,
xyz(1,0,2):multi*2*(poly_thr-cycle_r),
xyz(2,0,0):multi*(-pow(height, 2)),
xyz(0,0,2):multi*(-pow(cycle_r - poly_thr, 2)),
xyz(1,0,1):multi*2*height*(-2*poly_thr + cycle_r),
xyz(1,0,0):multi*2*pow(height,2)*poly_thr,
xyz(0,0,1):multi*2*height*poly_thr*(poly_thr - cycle_r),
xyz(0,0,0):multi*(-pow(poly_thr*height, 2))
sturm
#declare mockup2 =
difference{
    cylinder{
    <0,0,0.0>,<0,0,height>, bound
    #for(i, 0, poly_n-1)
        object{
        poly_obj
        inverse
        rotate <0,0,degrees(an*i)>
        plane{
        <1,0,0>,-poly_thr
texture {pigment {rgb 1}}
scale 3
rotate <0,90,90>
mockup2
light_source {
    <4.08,5.9,5.1>
    color rgb<1, 1, 1>
    location  <0, 0, 0>
    look_at  <0, 0, -1>
    right <-1.7777777777777777, 0, 0>
    up <0, 1, 0>
    angle  49.134343
    rotate  <-27.098163, 46.688390, -0.903519>
    translate <7.481132, 5.343666, 6.507640>
Date: 14 May 2015 15:04:09
Message: <5554f1a9@news.povray.org>
On 14/05/15 17:18, And wrote:
> I have a question.
Yes. Proof attached
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Download 'papi.jpg' (146 KB) Download 'kfm4.jpg' (100 KB)
Preview of image 'papi.jpg'
Preview of image 'kfm4.jpg'
Date: 14 May 2015 15:36:36
Message: <5554f944$1@news.povray.org>
>> I have a question.
> Yes. Proof attached
> John
I like that second one. The first, well, I'll opt not to comment...
And, I use Thunderbird as my interface to the povray news groups. With
Thunderbird or similar you can indeed upload more than one image as John
showed.
While I am too lazy to verify it at the moment, I seem to recall the web
interface to the news groups permits only one image per post. If true,
and you are using the web interface, perhaps this is why you cannot
attach more then one image.
Bill P.
