POV-Ray : Newsgroups : povray.binaries.images : Blobinator, 1M plus, blob test Server Time
19 Nov 2025 10:18:42 EST (-0500)
  Blobinator, 1M plus, blob test (Message 1 to 8 of 8)
Subject: Blobinator, 1M plus, blob test
Date: 16 Feb 2015 08:25:01
Message: <web.54e1eeec5920fa492b2130e90@news.povray.org>
Related to the Flyspray feature request #305;
remove maximum component limit for blobs (1M)
Start an array [736][350][736]
....fails on 32bit WinXP, run on 64bit WinVista
Initilize array element based on trace to mesh()
Create a blob component only if on surface.
....scan array, check for 6 face elements = fully inside, no component used
Full run, under 15 hours with 2.8Mhz cpu
array elements = 43,585,544
blob components = 2,826,336 <<<<<<<<<
Saved files:
array 1.64G
object 131M
about 3hrs to create array
about 11-12hrs to select points to use
trace 2min
Use results run,
Read object(blob) file and trace
4min
Comments welcome:
Stephen S
Download 'blobinator_g_test.png' (349 KB)
Preview of image 'blobinator_g_test.png'
Subject: Re: Blobinator, 1M plus, blob test
Date: 16 Feb 2015 08:40:00
Message: <web.54e1f2f14d9833de2b2130e90@news.povray.org>
Forgot to say, used:
Pov-Ray v 3.7.0.20140613.unofficial.msvc10.win64
from winpov help about
This should be Uberpov, but not sure what version.
Will update to latest and continue to play.
Stephen S
Date: 16 Feb 2015 22:47:20
Message: <54e2b9c8$1@news.povray.org>
Hi(gh)!
Perhaps you should have tried Linux - I experienced a slightly better
memory use under Linux when rendering scenes requiring huge amounts of RAM!
See you in Khyberspace!
Yadgar
Now playing: When I was a Man and you were a Woman (John Foxx)
Date: 18 Feb 2015 04:00:01
Message: <web.54e4541e4d9833de16086ed00@news.povray.org>
> Saved files:
> array 1.64G
> object 131M
> trace 2min
> Use results run,
> 4min
> Comments welcome:
> Stephen S
Looks like this could be usefull for muddy and particle based effects the
Blender exporter is already supposed to support blobs, so if it's not broken,
it could provide incredible tools for tree modeling and viscose matter using
blender particles to guide them! Great improvement!
Date: 22 Feb 2015 10:25:41
Message: <54e9f4f5$1@news.povray.org>
Am 16.02.2015 um 14:38 schrieb StephenS:
It isn't. v3.7.0.20140613 is just an unofficial binary release I built
quite a while ago from the official POV-Ray development sources, and a
precursor to the semi-official POV-Ray for Windows binary releases I'm
publishing on https://github.com/c-lipka/povray/releases from time to time.
UberPOV binaries can be found on
https://github.com/UberPOV/UberPOV/releases.
As for FlySpray issue #305, I forgot to close that one. Thanks for
reminding me.
Date: 22 Feb 2015 13:52:17
Message: <54ea2561@news.povray.org>
> Hi(gh)!
Linux won't help in this case: POV-Ray isn't optimized for parser memory
footprint, and will try to allocate some 3.5 GB of RAM for that array,
exceeding the 3 GB per-process user memory limit for 32 bit applications
imposed by both Windows and Linux.
This really is a matter of 32 bit vs. 64 bit.
Date: 25 Feb 2015 10:47:54
Message: <1194408193445822749.224288address_is-invalid.invalid@news.povray.org>
Hey, excellent!
Hopefully this makes it into main. A lot of my macros depend on blobs
(snow, ice coat, icicle, corrosion, etc..), and that limit was vexing.
Now if I can just get Glows in there... :p
Ian
> Related to the Flyspray feature request #305; remove maximum component limit for
blobs (1M)
> Start an array [736][350][736] ....fails on 32bit WinXP, run on 64bit
> WinVista Initilize array element based on trace to mesh() Create a blob
> component only if on surface. ....scan array, check for 6 face elements =
> Full run, under 15 hours with 2.8Mhz cpu array elements = 43,585,544 blob
> components = 2,826,336 <<<<<<<<< Saved files:
> array 1.64G
> object 131M
> trace 2min
> Use results run,
> 4min
> Comments welcome:
> Stephen S
Date: 28 Mar 2015 15:55:01
Message: <web.5517069d4d9833de5189b500@news.povray.org>
I like, that the surface of your cup looks a but like clay.
Give it a clay-red color, and the illusion is perfect.
> Saved files:
> array 1.64G
> object 131M
> trace 2min
> Use results run,
> 4min
> Comments welcome:
> Stephen S
