POV-Ray : Newsgroups : povray.binaries.images : CGSphere WIP: stacked convex lenses Server Time
20 Apr 2026 13:00:35 EDT (-0400)
  CGSphere WIP: stacked convex lenses (Message 11 to 20 of 27)
<<< Previous 10 Messages Goto Latest 10 Messages Next 7 Messages >>>
Subject: Re: CGSphere WIP: stacked convex lenses
Date: 13 Nov 2014 17:02:28
Message: <54652a74$1@news.povray.org>
On 13/11/2014 21:21, Cousin Ricky wrote:
> My hardware is a Dell Inspiron 17R with Intel Core i7 (8 cores).
Isn't that 4 cores with HT ? (for povray, it would be worth 5 cores, YMMV)
IQ of crossposters with FU: 100 / (number of groups)
IQ of crossposters without FU: 100 / (1 + number of groups)
IQ of multiposters: 100 / ( (number of groups) * (number of groups))
Date: 13 Nov 2014 18:40:00
Message: <web.5465406854566a48192ae5f10@news.povray.org>
I've seen "quad core" in literature not attached to this particular model, but
in the POV-Ray statistics, there is a clear 8-to-1 ratio between CPU times and
elapsed times.  Does this mean that there are 2 CPUs in each core?
Date: 14 Nov 2014 06:59:54
Message: <5465eeba$1@news.povray.org>
Sort of... there is two full set of registers in each core, allowing to
run two code in parallel... as long as they do not need the same
resources from the core.
at 100% cpu like povray, yes there is a 8:1 ratio between cpu times and
wall-clock time. Yet, if the scheduler of the operating system is not
too bad, if you force povray to run on less threads (with -WT<number>
option), you can get some surprise like -WT8 is not twice faster that -WT4.
With good schedulers, povray -WT4 would run one thread per core, leaving
the other set of registers idle or used by something else.
Just because nobody complains does not mean all parachutes are perfect.
Date: 14 Nov 2014 07:06:48
Message: <5465f058$1@news.povray.org>
Talking of which, is there a difference between -WT and +WT? I get the
impression that both are used indiscriminately.
Date: 14 Nov 2014 10:41:35
Message: <546622af$1@news.povray.org>
Yep. Pretty much that. I've noticed that my work computer (core i3, dual
core) isn't quite as fast as my desktop PC (a Core2 Quad), even though
it appears to have 4 cores to applications.
I forget exactly what hyperthreading does, but it does give a bit of a
boost to multi-threaded applications.
Date: 14 Nov 2014 13:03:10
Message: <546643de$1@news.povray.org>
>>>> YMMV)
>>> model, but
>>> times and
>> -WT4.
> Thomas
Actually, for some option there is a difference between + and -
(usually one form disable the option, and the other enable it, with some
value).
For instance +KC and -KC are opposite of each other.
But +H and -H are happily setting both the height of the output.
Now, if I could find a mnemonic to remember which one is enable and
which one is disable... that would be a great year.
Date: 14 Nov 2014 14:05:00
Message: <web.546651d654566a48d19b0ec40@news.povray.org>
> Thomas
"Inflammable means flammable? What a country!"
Date: 14 Nov 2014 21:48:03
Message: <5466bee3$1@news.povray.org>
Am 14.11.2014 19:03, schrieb Le_Forgeron:
> value).
Uh... how about "+" adds something (turns it on), while "-" removes
something (turns it off)?
Not too difficult, is it ;-)
Date: 15 Nov 2014 03:20:09
Message: <54670cb9$1@news.povray.org>
>> value).
LOL. I must say that where on/off is concerned, I do not have much
problem with +/-. It is those cases where there is no such thing and
where you can either use + or - for the same result that I begin to feel
itchy. It confuses the issue and as one does not always remember which
of those bloody settings can or cannot be switched... ;-)
Date: 15 Nov 2014 13:10:00
Message: <web.5467967254566a48192ae5f10@news.povray.org>
I just make a habit of using + unless I want to turn something off.  That way
the question never comes up.
