POV-Ray : Newsgroups : povray.binaries.images : WIP: We check the union Blender - Povray Server Time
2 Jun 2024 00:52:29 EDT (-0400)
  WIP: We check the union Blender - Povray (Message 32 to 41 of 51)
Subject: Re: WIP: We check the union Blender - Povray
Date: 24 Jun 2015 03:55:38
Message: <558a627a@news.povray.org>
On 23-6-2015 19:45, LanuHum wrote:
> Yesterday I checked export of a vase to .obj.
> Import of the file to Art of Illusion took place successfully. There are no
> errors.
> I compared results on a simple example:
> Difference in normals the very big.
> I attach the file, but I see that the exporter demands changes.
> Today I will try export of mesh2 to Povray to make on the basis of the exporter
> in OBJ.
Nothing wrong indeed with the obj version of the vase, so it is the
mesh2 exporter that goes wrong.
Here is the vase with the caustics at last.
Download 'lanuhum_caustics.png' (206 KB)
Preview of image 'lanuhum_caustics.png'
Date: 24 Jun 2015 08:55:00
Message: <web.558aa814b92297fd16086ed00@news.povray.org>
> > errors.
> > in OBJ.
> Thomas
Does this mean that the official exporter also has the problem? LanuHum could
you provide the Blender scene for a check and eventual fixing?
Date: 24 Jun 2015 13:30:01
Message: <web.558ae88db92297fd7a3e03fe0@news.povray.org>
Yes!
Does this mean that the official exporter also has the problem.
Download 'vase_officialpov.7z.zip' (162 KB)
Date: 25 Jun 2015 14:20:00
Message: <web.558c45f4b92297fd7a3e03fe0@news.povray.org>
> That is a possibility indeed. Could you provide an .obj version of the
> vase? Maybe I can see where the problem resides.
> Thomas
Thomas, Many thanks for your help! But
Check, please, in Poser this vase. Whether there will be artifacts in normals
now?
I try to change export of meshes.
Download 'wip.7z.zip' (716 KB)
Date: 26 Jun 2015 03:01:08
Message: <558cf8b4$1@news.povray.org>
> now?
I loaded the vase in Poseray; it is still corrupt in the same way.
When looking closely at the object, the triangle faces appear to be
formed from the wrong vertices, for instance crossing over from the
inner side of the vase to the outer side.
Date: 26 Jun 2015 08:49:26
Message: <558d4a56@news.povray.org>
Am 26.06.2015 um 09:01 schrieb Thomas de Groot:
>> normals
>> now?
Hmm... maybe an off-by-1 error in the triangle vertex indices generated
by the exporter?
Date: 26 Jun 2015 13:20:00
Message: <web.558d8916b92297fd7a3e03fe0@news.povray.org>
> by the exporter?
We will wait for Mr.
I don't see error. :(
Date: 27 Jun 2015 14:55:13
Message: <web.558ef123b92297fd7a3e03fe0@news.povray.org>
meshmaker creates correctly object, and caustics normal at settings of photons
    photons {
        spacing 0.01
        max_trace_level 8
  Trace Time:       0 hours  5 minutes 25 seconds (325.612 seconds)
              using 4 thread(s) with 1268.043 CPU-seconds total
POV-Ray finished
Download 'mesh2(meshmaker).jpg' (95 KB)
Preview of image 'mesh2(meshmaker).jpg'
Date: 28 Jun 2015 03:12:51
Message: <558f9e73@news.povray.org>
>      photons {
>          spacing 0.01
>          max_trace_level 8
> POV-Ray finished
This looks good and photons are all right, fairly fast too.
Date: 29 Jun 2015 05:05:01
Message: <web.559109beb92297fd16086ed00@news.povray.org>
"LanuHum" <Lan### [at] yandexru> wrote:
> > by the exporter?
Hi, sorry but I fail to see any problem in LanuHum's images or in mine when I
tried rendrering the scene in the official exporter. By just looking at
the pictures, the only problem I saw was ray depth set too low. Do you mean that
there is use of a syntax that is going to be deprecated ? I also checked the
normals of the file, which are fine. I don't have any urge to import the mesh
into PoseRay, though in the long run I can see it could be good to have a better
compatibility with it. But I'm probably missing something?
