![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Thomas de Groot <tho### [at] degroot org> wrote:
>> The uv_mapping gives an interesting effect. You can also achieve this
>> with a gradient texture along the y-axis.
>> Thomas
> Thanks!
> Problem:
> mesh2 glass vase
You should use spacing instead of count for your photons.
That way, you set the density of the photons coverage and don't spread
your photons between the various objects and light_source.
Also, if one object seems to receive enough photons, but the other
don't, you can use target float.
The float value is to be used as a multiplicator for the spacing.
target 0.5 will reduce the effective spacing for that object by half,
for 4 times as many photons.
If you want the photons to be reflected by the mirror, using target 2 or
3 will reduce the number of photons dirrected at the mirror. As it's a
flat surface, it don't need as much coverage as the glasses.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> >> Thomas
> > Thanks!
> > Problem:
> > mesh2 glass vase
> Alain
It is impossible.
One vase without glasses also incorrectly draws caustic.
I attach a scene.
You can adjust?
For me it will be a good example during the work on the exporter.
Thanks in advance!
Download 'wip.7z.zip' (885 KB)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: WIP: We check the union Blender - Povray
Date: 22 Jun 2015 07:24:52
Message: <5587f084@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 21-6-2015 17:01, LanuHum wrote:
> Problem:
> mesh2 glass vase
Yes. Problem.
The following photon block in global_settings{} works well for the
glasses. If you remember, we did a Blender scene test last year and this
comes from my version then:
photons {
spacing 0.01 // higher value 'lower' quality, faster parsing.
gather 20, 100
autostop 0
jitter 0.5
max_trace_level 15
adc_bailout 1/10e5
See attached image.
However, for the vase, something funny happens and parsing seems to be
stuck in a loop, eating up memory.
Download 'lanuhum_caustics 1.png' (130 KB)
Preview of image 'lanuhum_caustics 1.png'
![lanuhum_caustics 1.png](/povray.binaries.images/attachment/%3C5587f084%40news.povray.org%3E/lanuhum_caustics%201.png?ttop=413793&toff=300&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 22 Jun 2015 07:36:58
Message: <5587f35a@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I think the mesh2{} of the vase is corrupt. This is how it shows up when
loaded in Poseray.
Download 'data_vase_dec.jpg' (25 KB)
Preview of image 'data_vase_dec.jpg'
![data_vase_dec.jpg](/povray.binaries.images/attachment/%3C5587f35a%40news.povray.org%3E/data_vase_dec.jpg?ttop=413793&toff=300&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> loaded in Poseray.
That is a mess. Have you tried deleting orphans and recalculating the
normals?
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 22 Jun 2015 07:54:39
Message: <5587f77f$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> loaded in Poseray.
> normals?
Yes.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 22 Jun 2015 08:06:12
Message: <5587fa34$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> loaded in Poseray.
>> normals?
> Yes.
To be more explicit: I guess that the mesh2 was made from an object
where the face normals were not all consistent, some facing inwards,
some outwards. This is typical for objects made with some high-end
modellers (!) or exported with a low resolution. So, what I would
suggest to Lanuhum is to check the original vase object.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>>> when
>>>> loaded in Poseray.
>>> normals?
>> Yes.
I thought that you might have. :-)
That's what it looks like to me too.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> >>> loaded in Poseray.
> >> normals?
> > Yes.
> Thomas
I did this vase for testing of Yafaray.
Yafaray has problems with heavy scenes, but
no problem with vase mesh.
If there is a problem in a mesh, probably it is the exporter's problem.
Download 'vase.yafaray.jpg' (167 KB)
Preview of image 'vase.yafaray.jpg'
![vase.yafaray.jpg](/povray.binaries.images/attachment/%3Cweb.5588417bb92297fd7a3e03fe0%40news.povray.org%3E/vase.yafaray.jpg?ttop=413793&toff=300&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 23 Jun 2015 03:07:04
Message: <55890598$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>>>> loaded in Poseray.
>>>> normals?
>>> Yes.
>> Thomas
That is a possibility indeed. Could you provide an .obj version of the
vase? Maybe I can see where the problem resides.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
