> Modeled in Blender. Rendered in Povray.
Cool, a big truck. You did a good job. Maybe replace the micra's car of
Jaime's animation.
Lionel.
Do not judge my words, judge my actions.
http://www.avast.com
Am 26.08.2014 10:54, schrieb FractRacer:
> Jaime's animation.
... and have it do the ramp jump stunt. Yay! :-)
Might also add a load of boulders while we're at it, see if we can make
some big mess...
Great work! did you use the official exporter? if so do you mind if I link to
this image in the exporter's forumgroup at Blenderartists.org? If you used the
exporter, don't hesitate to share your feedback, for any improvement.
Thanks! I did use the built-in exporter (I assume that's the official one).
That'd be great if you post a link there. How to improve the exporter, I would
suggest making the
1) make the materials a separate *.mat file
2) place the color definition of the mesh also in the external *.mat file
These two would help greatly with speeding up tweaking materials manually
because the exported file from this scene is over 500 MB and it takes a while to
find specific areas in the file to change and also to write out the file.
Really great modelling, I have googled a few photos and you have paid excellent
attention to detail. My only criticism would be the tyre tread depth looks too
small, like the tyres are a bit worn down not brand new.
Are you going to texture a dirty version as well?
Sean
> Sean
Here's the dirty version rendered in Cycles. I'd like to do a Povray version and
compare the results. That'll come eventually.
Download 'nqsgtho.jpg' (304 KB)
Preview of image 'nqsgtho.jpg'
Thank you!
Very well!
I want to learn duration of a render: in Cycles and in Povray
I don't love Cycles, it isn't capable to work with animation because of a render
of a frame 24 hours
"LanuHum" <Lan### [at] yandex ru> wrote:
> Thank you!
> Very well!
> of a frame 24 hours
In Cycles, it's about 3 hours 45 minutes.
At this point, it's kind of a pain in the ass to convert the material
definitions over to Povray once I made the Cycles render, so it may be while
before I even get to it with the same scene. Currently working on TC RTC entry
that I hope will be spectacular (can't wait to see what s day and mcgregor come
up with).
>> car of Jaime's animation.
At 67Km/h? ...I doubt it would look very interesting. Also, to make it
realistic, it would have to break the exit ramp into pieces! :)
> make some big mess...
Now that you mention it, that would interesting to try with a pick-up
or a little truck, with the truck bed filled with boxes and cylinders
(maybes wood boxes and oil drums). Thanks for the idea!
Jaime
