POV-Ray : Newsgroups : povray.binaries.images : (alpha channel not work )Another example Server Time
21 Dec 2025 20:24:18 EST (-0500)
  (alpha channel not work )Another example (Message 1 to 8 of 8)
Subject: (alpha channel not work )Another example
Date: 6 Aug 2014 03:05:04
Message: <web.53e1d3332a4d6c721ccfd0a0@news.povray.org>
background {
  color rgb < 0.60, 0.70, 0.95 >
  location <0, 15, -60>
 direction <0, 2,  1>
  right x*1.33
 look_at <0,15,0>
light_source {
  <0,28,0> // position of a coner of the light plane
  rgb<1.0,1.0,1.0>
  area_light <3, 0, 0>, <0, 3, 0>, 2, 2 // light plane's edges; m by n bulbs
 adaptive 1 // if on, some rays will not be traced
 jitter // randomization of bulb's positions, emulating fuzzy shadow edges
  object {
      mesh2{
         vertex_vectors{
                      5
                        <-500, 0, 30>, < 500, 0, 30>,<500,  500, 30>, < -500,
500, 30>  , < 0, 250,  30>
             uv_vectors{
                       5
                         <-25.0, -25.0>,< 25.0, -25.0> ,  < 25.0,  25.0>,
<-25.0,  25.0>,  <0.0, 0.0>
           face_indices{
                       4,
                        <0,1,4>, <1,2,4>,<2,3,4>, <3,0,4>
             uv_indices{
                     4,
     texture{
         pigment{
       uv_mapping
        image_map { png "DHKX0221.png"  map_type 0   interpolate 2 }
         finish {
      specular 0.3
      roughness 0.01
Download 'dhkx0221.png' (1250 KB)
Preview of image 'dhkx0221.png'
Subject: Re: (alpha channel not work )Another example
Date: 6 Aug 2014 03:10:04
Message: <web.53e1d4788bdc3f3e1ccfd0a0@news.povray.org>
"liujg" <seu### [at] qqcom> wrote:
> background {
> camera {
>  direction <0, 2,  1>
>   right x*1.33
>  look_at <0,15,0>
> light_source {
>   rgb<1.0,1.0,1.0>
>   object {
>       mesh2{
>          vertex_vectors{
>                       5
>              uv_vectors{
>                        5
>            face_indices{
>                        4,
>              uv_indices{
>                      4,
>      texture{
>          pigment{
>        uv_mapping
>          finish {
>       specular 0.3
>       roughness 0.01
the render result.
Download 'qq??20140806144335.jpg' (101 KB)
Preview of image 'qq??20140806144335.jpg'
Date: 6 Aug 2014 03:20:04
Message: <web.53e1d6b28bdc3f3e1ccfd0a0@news.povray.org>
> > background {
> > camera {
> >  direction <0, 2,  1>
> >   right x*1.33
> >  look_at <0,15,0>
> > light_source {
> >   rgb<1.0,1.0,1.0>
> >   object {
> >       mesh2{
> >          vertex_vectors{
> >                       5
> >              uv_vectors{
> >                        5
> >            face_indices{
> >                        4,
> >              uv_indices{
> >                      4,
> >      texture{
> >          pigment{
> >        uv_mapping
> >          finish {
> >       specular 0.3
> >       roughness 0.01
> the render result.
Download '123.png' (262 KB)
Preview of image '123.png'
Date: 6 Aug 2014 04:09:34
Message: <53e1e2be@news.povray.org>
Check your png.
The alpha channel is present, but in the attached image of the previous
message, it is 100% opaque everywhere.
So far, povray is working as expected. You need to have less than 100%
opaque in part of your png to see it as transparent (even partially) in
the rendered image.
Just because nobody complains does not mean all parachutes are perfect.
Date: 6 Aug 2014 18:48:36
Message: <53e2b0c4$1@news.povray.org>
> background {
> camera {
>   direction <0, 2,  1>
>    right x*1.33
>   look_at <0,15,0>
> light_source {
>    rgb<1.0,1.0,1.0>
The adaptive feature value is NOT a boolean value but an initial or
minimal subdivision value.
It's turned ON by the sole presence of the keyword "adaptive" followed
by some value, even zero.
adaptive 0 will shoot at least 4 rays in a 2 by 2 array, the size of
your array.
adaptive 1 will attempt to shoot at least 9 rays in a 3 by 3 array, but
your array, at 2 by 2, is not large enough.
adaptive 2 will attempt to shoot at least 25 rays in a 5 by 5 array
If a dimention for the sublights is to small in any direction to allow
for the desired minimal subdivision, it won't attempt to subdivide further.
Using an area_light 3*x, 3*y, 2, 2 with adaptive is totaly pointless.
Using this area_light setting is prety fast and gives very smooth results:
area_light 3*x, 3*y, 33 33 adaptive 0
You can go overboard:
area_light 3*x, 3*y, 1025 1025 adaptive 0
whitch is almost as fast and so smooth that jitter not usefull.
Date: 6 Aug 2014 21:40:01
Message: <web.53e2d81b8bdc3f3e99daad1c0@news.povray.org>
> > background {
> > camera {
> >   direction <0, 2,  1>
> >    right x*1.33
> >   look_at <0,15,0>
> > light_source {
> >    rgb<1.0,1.0,1.0>
> your array.
> Alain
Thank you ,My question is that in the render result picture the black area
should be transparent,because my bitmap have alpha channel .
Date: 7 Aug 2014 00:23:33
Message: <53e2ff45$1@news.povray.org>
On 8/6/2014 6:36 PM, liujg wrote:
> Alain <kua### [at] videotronca> wrote:
>>> background {
>>> camera {
>>>    direction <0, 2,  1>
>>>     right x*1.33
>>>    look_at <0,15,0>
>>> light_source {
>>>     rgb<1.0,1.0,1.0>
>> your array.
>> Alain
You may be misunderstanding the alpha channel, and how it works. We
would need to see the actually png, to be sure, but.. its not like a
gif, there isn't just "one color" that functions as an "alpha channel".
In png, the colors are stored as red, green, blue, alpha. The last one
can be anything from 100% visible, to 100% see through, and anything in
between. The only reason why alpha, as far as I know, can possible not
work in POVRay is if your imagine has the color <0,0,0,0> for the parts
you want to see through - which would mean Black, 100% visible. I.e.,
the png *may* contain alpha information, but the "color" you are trying
to see through "does not contain any".
Commander Vimes: "You take a bunch of people who don't seem any
different from you and me, but when you add them all together you get
this sort of huge raving maniac with national borders and an anthem."
Date: 8 Aug 2014 19:27:13
Message: <53e55cd1@news.povray.org>
>>> background {
>>> camera {
>>>    direction <0, 2,  1>
>>>     right x*1.33
>>>    look_at <0,15,0>
>>> light_source {
>>>     rgb<1.0,1.0,1.0>
>> your array.
>> Alain
Your image DOES have an alpha channel, but that channel say "this pixel
have zero transparency" everywhere. If the alpha channel was correct,
then Thunderbird would show the background colour of the page instead of
black. Also, in the web version, just any browser should also show the
black areas as transparent, meaning that any background will show
through. This _IS NOT THE CASE_ with your image !
The fact that a given pixel is black *never ever* make it transparent.
In fact, it can be absolutely any colour of the 16.4 millions available.
