Tim Cook <z99### [at] gmailcom> wrote:
> On 2014-06-02 12:07, s.day wrote:
> > Thought I was getting used to using SSLT but I think I have something wrong
> > somewhere as my poor ant looks like he is about to spontaneously combust..
> Is a...fire ant, ja?
> *puts on shades*
> ...that's made of 'a few blobs'? Whoah!
> Tim Cook
> http://empyrean.sjcook.com
Thanks, I am now thinking I need to model a child with a magnifying glass as I
already have the effect so I just need the cause.
People are way beyond my blob modelling skills though ;-)
Sean
Am 03.06.2014 00:49, schrieb s.day:
> Now I know it is not samples maybe I can lower them a bit and try some different
> options/variations as it will be a bit faster, it seems increasing the
> mm_per_unit helps to reduce the glow but getting it just right is the problem as
> if I reduce it too much the effect is no longer as good.
Leave the mm_per_unit setting be; it should always match the actual
scale of the object.
Any effect that can be achieved by tweaking mm_per_unit can also be
achieved by tweaking the materials' translucency.
>s.day on date 02/06/2014 19.07 wrote:
> Hi,
A great ant!
Paolo
> > Hi,
> A great ant!
> Paolo
Thanks Paolo, still may add a few improvements to it yet and hoping to stop it
going into meltdown but experimenting with SSLT is time consuming ;-)
Sean
I think it is a great ant, for a fire ant. ;-)
Seriously great modelling.
Regards
"s.day" <s.d### [at] uelacuk> wrote:
> Any help/tips greatly appreciated.
> Thanks
> Sean
Why you don`t adapt your gradient texture?
From my perspective, it's a povray prob (of sslt), not your adaption.
Personally speaking I always use gray colors for sslt, but I'm far of being
experienced like you... (I admire your starfish...)
Norbert Kern
>> wrong
>> combust..
Thanks Stephen, after my first attempt at modelling the ant I thought
maybe I should revisit Sculptris as it seemed like something I should be
doing with meshes. However, I like the challenge of just using SDL to
create images.
Sean
> Norbert Kern
Thanks Norbert, you are selling yourself short I think but thanks for
the compliment. You could be correct regarding the cause though as it
seems to be related to the HDR part of the image.
Sean
>> different
>> problem as
This is starting to look like it is related to the HDR probe, if I just
use HDR the issue is present stil but if I switch off HDR and use a
regular light source (no other change to the scene) the SSLT effect is OK.
Download 'ant - light only.png' (364 KB)
Preview of image 'ant - light only.png'
Am 06.06.2014 07:52, schrieb Sean Day:
Have you tried a more blurred version of the light probe?
I wouldn't be surprised though if you were in the process of discovering
a bug in the integration of radiosity and SSLT; so if you don't mind
digging a bit more, you'd do me a great favor.
