Stephen wrote:
> On 02/06/2014 18:07, s.day wrote:
>> Thought I was getting used to using SSLT but I think I have something
>> wrong
>> somewhere as my poor ant looks like he is about to spontaneously
>> combust..
> I think it is a great ant, for a fire ant. ;-)
> Seriously great modelling.
Thanks Stephen, after my first attempt at modelling the ant I thought
maybe I should revisit Sculptris as it seemed like something I should be
doing with meshes. However, I like the challenge of just using SDL to
create images.
Sean
Norbert Kern wrote:
> Why you don`t adapt your gradient texture?
> From my perspective, it's a povray prob (of sslt), not your adaption.
> Personally speaking I always use gray colors for sslt, but I'm far of being
> experienced like you... (I admire your starfish...)
> Norbert Kern
Thanks Norbert, you are selling yourself short I think but thanks for
the compliment. You could be correct regarding the cause though as it
seems to be related to the HDR part of the image.
Sean
clipka wrote:
> Am 03.06.2014 00:49, schrieb s.day:
>> Now I know it is not samples maybe I can lower them a bit and try some
>> different
>> options/variations as it will be a bit faster, it seems increasing the
>> mm_per_unit helps to reduce the glow but getting it just right is the
>> problem as
>> if I reduce it too much the effect is no longer as good.
> Leave the mm_per_unit setting be; it should always match the actual
> scale of the object.
> Any effect that can be achieved by tweaking mm_per_unit can also be
> achieved by tweaking the materials' translucency.
This is starting to look like it is related to the HDR probe, if I just
use HDR the issue is present stil but if I switch off HDR and use a
regular light source (no other change to the scene) the SSLT effect is OK.
Download 'ant - light only.png' (364 KB)
Preview of image 'ant - light only.png'
Am 06.06.2014 07:52, schrieb Sean Day:
Have you tried a more blurred version of the light probe?
I wouldn't be surprised though if you were in the process of discovering
a bug in the integration of radiosity and SSLT; so if you don't mind
digging a bit more, you'd do me a great favor.
> create images.
As someone cannot get blobs to work the way I want them to work. I can
only gasp and stare. With admiration.
Regards
Hi Clipka,
Going to show my ignorance here but how do I blur the light probe?
Happy to help in any way possible, I tried a different light probe and
had a similar but more uniform problem (attached). I am happy to upload
the source if that helps or run test renders myself. The light probes I
have tried so far have both been from the same source so I will try one
from a different source.
Both the probes were from http://www.hdrlabs.com/sibl/archive.html the
backyard and harbour3 ones towards the bottom of the page.
Sean
Download 'ant - harbour.png' (690 KB)
Preview of image 'ant - harbour.png'
They can be tricky that is for sure, the legs were actually a lot easier
than I expected (just translate the components along a spline and adjust
the scale at certain points) it was (and still is) the head that is
giving me the most trouble, once the model is complete I will upload it
to the objects or source files thread.
It is probably something that just comes to you. Too bad I was behind
the door. When that knack was given out. ;-)
That would be worthwhile. :-D
Regards
Am 06.06.2014 21:31, schrieb Sean Day:
HDRshop is probably the best tool for the job.
Uh, that definitely looks wrong. Can you do me another favor and use
that same light probe but with (a) a simple sphere, and (b) a
single-sphere blob?
Am 07.06.2014 00:44, schrieb clipka:
Dang, forget about that one. It used to be free some years ago, but
apparently they've made it payware.
