POV-Ray : Newsgroups : povray.binaries.images : luminance output Server Time
1 Apr 2026 15:37:06 EDT (-0400)
  luminance output (Message 21 to 23 of 23)
Subject: Re: luminance output
Date: 17 Apr 2014 11:30:00
Message: <web.534ff28ac34aaa776a92a3a00@news.povray.org>
scott <sco### [at] scottcom> wrote:
> > These "reflection" numbers in pov-ref.txt file are extracted from a image,which
> > with location and reflective information for 40000 points.We call this image a
> > reflecity image in remote sensing.This image is photoed by flight.Thank you for
> > your advice.I go to have a try!Gratitudes!
> I must admit I don't have much experience with OpenEXR output. What
> happens if you render the below scene to OpenEXR and check the
> luminance, what values to you get for different values of "ref"? Do they
> match up?
> #version 3.7
> global_settings {assumed_gamma 1}
> #default{ finish{ ambient 0.0 diffuse 1.0 }}
> camera
>   orthographic
>   location z
>   look_at  0
>   right    x*image_width/image_height
> light_source{ <0,0,10> color rgb 1 }
> #local ref = 0.5;
> box { -1/2 1/2 pigment{ color rgb ref} }
I have another confusion:I have known the value of solar irradiance(w/m^2) from
200nm-2200nm,how can I set the solar irradiance in pov?
Date: 17 Apr 2014 14:15:01
Message: <web.535019bfc34aaa77f1b07a8f0@news.povray.org>
It is not exactly clear what you are trying to do, but my best guess would be
that you are trying to match POV-Ray output with some physical measurements that
you got somewhere. That is something POV-Ray light models (or that of most
general purpose 3D programs) are not designed to do. You may get much better
results using Radiance (http://radsite.lbl.gov/radiance/HOME.html) or
special-purpose wave-model based ray-tracers.
Thorsten
Date: 17 Apr 2014 21:00:01
Message: <web.53507809c34aaa776a92a3a00@news.povray.org>
> Thorsten
Thank you for your help.Yes,what I want is matching POV-Ray output with some
physical measurements.I have used spectral
render.http://www.lilysoft.org/CGI/SR/Spectral%20Render.htm.
#version 3.7;
global_settings{ assumed_gamma 1.0 }
#declare SpectralWavelength =730;
#include "spectral.inc"
camera
angle  7.54371
location <camera_x,camera_y,camera_z >
look_at <0,0,0>
rotate <0,-31,0>
right x
up y
light_source {<sun_x,sun_y,sun_z>
             SpectralEmission(E_D65)   //some CIE standard illuminants
#declare n = 0;
#fopen   Input_geom_file geom_file_name read
#fopen   Input_spec_file spec_file_name read
#while(defined(Input_geom_file))
    #read(Input_geom_file,x1,y1,z1)
    #read(Input_spec_file,ref)
      box
           -1.55,1.55
           rotate y*-31
           translate <x1-center_x,y1-center_y,z1-center_z>
           pigment {color rgb 1}
           finish {
                 ambient 0
                 diffuse ref
    #declare n = n + 1;
My solar irradiance in 730nm is 1.33015(w/m^2),and I have converted irradiance
to illuminance with the lm/w in 730nm,then the value of illuminance in 730nm is
0.47262925(cd/m^2).My issue is how can I input the illminance in 730nm?
"light_source {<sun_x,sun_y,sun_z>
With this light_source,the illuminance is E_D65.How can I input my illminance?
