POV-Ray : Newsgroups : povray.binaries.images : strange behavior, lightsource + lookslike + media Server Time
30 Sep 2024 01:19:03 EDT (-0400)
  strange behavior, lightsource + lookslike + media (Message 1 to 10 of 15)
Subject: strange behavior, lightsource + lookslike + media
Date: 28 Oct 2011 07:50:01
Message: <web.4eaa95c011cbbbbd77e50e540@news.povray.org>
I do not understand why the position of this object controls its appearance.
Any clues?
I seem to have covered all position based params with the macro variable...
Source below:
camera
    location  <0, 0, -5>
    look_at   <0, 0, 0>
#macro BlackHoleWarp(Iterations, Falloff, Strength, Position, Radius)
    #local counter = 0; // set counter to 0
    #while (counter < Iterations)
        warp
            black_hole Position, Radius
            falloff Falloff
            strength Strength
            turbulence 0.4
        #local counter = counter + 1;
#macro Glow(glowPosition, glowRadius, glowColor)
light_source
    glowPosition
    color rgb glowColor
    looks_like
        sphere
            hollow
            pigment
                rgbt <0, 0, 0, 1>
            interior
                media
                    intervals 1 //  scale this in relation to distance from
camera
                    samples 1, 1
                    emission glowColor
                    density
                        spherical
                        scale 3
                        density_map
                            [0.0 rgb glowColor * 0.000]
                            [0.8 rgb glowColor * 0.250]
                            [0.9 rgb glowColor * 0.750]
                            [1.0 rgb glowColor * 1.000]
                    density
                        spherical
                        density_map
                            [0.00 color rgb glowColor * 0.000]
                            [ 0.90
                                granite
                                color_map
                                    [0 color rgb glowColor * 0.750]
                                    [1 color rgb glowColor * 0.250]
                                //BlackHoleWarp(4, 1, 1, glowPosition, 1)
                            [1.00 color rgb glowColor * 1.500]
            finish
                reflection 0
                diffuse 0
                ambient 0
                phong 0
                specular 0
                brilliance 0
Glow(<2, 0, 0>, 2, <1, 1, 1>)
Glow(<0, 0, 0>, 2, <0.5, 0.5, 0.55> * 1.5)
Glow(<-2, 0, 0>, 2, <0, 0.5, 0.5> * 1.5)
plane
    <0, 1, 0>, 0
    hollow
    texture
        pigment
            color rgb <0.5, 0.5, 0.55>
    scale <1, 1, 1>
    translate <0, -1, 0>
Download 'mediaglow2011_0.png' (55 KB)
Preview of image 'mediaglow2011_0.png'
Subject: Re: strange behavior, lightsource + lookslike + media
Date: 28 Oct 2011 08:43:31
Message: <4eaaa373@news.povray.org>
Am 28.10.2011 13:45, schrieb [GDS|Entropy]:
> Any clues?
Yes: You failed to translate the sperical pattern to the desired position.
I suggest to compose the Glow thing at <0,0,0>, and finally translate it
to where you want it:
> light_source
>      glowPosition
replace this line with:
        <0,0,0>
>      color rgb glowColor
>      looks_like
>          sphere
                <0,0,0>, glowRadius
>              hollow
>              pigment
>                  rgbt<0, 0, 0, 1>
>              interior
>                  media
>                      intervals 1 //  scale this ...
>                      samples 1, 1
>                      emission glowColor
>                      density
>                          spherical
>                          scale 3
>                          density_map
>                      density
>                          spherical
>                          density_map
>                              [ 0.90
>                                  granite
>                                  color_map
remove this line (or keep it commented out)
>              finish
>                  reflection 0
>                  diffuse 0
>                  ambient 0
>                  phong 0
>                  specular 0
>                  brilliance 0
insert here:
        translate glowPosition
> #end
Date: 28 Oct 2011 09:40:00
Message: <web.4eaaafc3693b004877e50e540@news.povray.org>
>snip
Good catch!
However, instead of two hemispheres 1 unit away from the central glow sphere,
they are now inside it. The issue of appearance altering with translation
persists.
I can see that the light source has translated, but it almost looks like the
media didn't.
Weird...
Ian
Download 'mediaglow2011_0.png' (46 KB)
Date: 29 Oct 2011 08:48:42
Message: <4eabf62a@news.povray.org>
Am 28.10.2011 15:36, schrieb [GDS|Entropy]:
> persists.
> media didn't.
> Weird...
To be honest, you just discovered a bug in 3.7.RC3 there. Apparently,
when a light source is translated, the looks_like object is translated
as well, but not its members (such as media).
3.6.2 does it right. Gotta fix this.
Date: 29 Oct 2011 08:57:44
Message: <4eabf848$1@news.povray.org>
Am 29.10.2011 14:48, schrieb clipka:
The issue can be worked around by creating the light source at the
target location - as you originally did; but note that a looks_like
object always needs to be specified as if the light source was at <0,0,0>.
Thus the following code should work with both 3.6.2 and 3.7.0.RC3:
 > light_source
 >      glowPosition
Leave this line as is.
 >      color rgb glowColor
 >      looks_like
 >          sphere
Replace this line with:
                <0,0,0>, glowRadius
 >              hollow
 >              pigment
 >                  rgbt<0, 0, 0, 1>
 >              interior
 >                  media
 >                      samples 1, 1
 >                      emission glowColor
 >                      density
 >                          spherical
 >                          scale 3
 >                          density_map
 >                      density
 >                          spherical
 >                          density_map
 >                              [ 0.90
 >                                  granite
 >                                  color_map
You'll probably need to replace this line with the following (in case
you ultimately decide to re-activate it):
                        //BlackHoleWarp(4, 1, 1, <0,0,0>, 1)
 >              finish
 >                  reflection 0
 >                  diffuse 0
 >                  ambient 0
 >                  phong 0
 >                  specular 0
 >                  brilliance 0
Do NOT insert a translate here.
 > #end
Date: 29 Oct 2011 14:20:54
Message: <4eac4406@news.povray.org>
> Any clues?
> Source below:
> camera
>      location<0, 0, -5>
>      look_at<0, 0, 0>
>      #while (counter<  Iterations)
>          warp
>              falloff Falloff
>              strength Strength
>              turbulence 0.4
>      #end
> #end
> light_source
>      glowPosition
>      color rgb glowColor
>      looks_like
>          sphere
A looks_like object location is relative to it's associated light_source.
This light_source have it's looks like correctly placed:
(texture intentionaly omited)
light_source{<100,0,0> rgb 1 looks_like{sphere{0, 1}}}
In your case, using <0,0,0> as the looks_like object location ALSO
translate the media to the correct location.
This one don't, it's located at <200,0,0>:
light_source{<100,0,0> rgb 1 looks_like{sphere{<100,0,0>, 1}}}
Any contained media will be located relative to the light_source, but no
longer with the container.
Some media hints:
intervals MUST remains at 1
samples NEVER use the second parameter when using the default smpling
method: method 3.
As it is, you take only one sample at the mid point of the container and
assume that it don't change.
Also, your containers overlap each other. As the spherical pattern have
an effective radius of 1, reducing your containers radius to that value
suppress the overlap, and some changes related to the location.
Date: 29 Oct 2011 14:29:59
Message: <4eac4627@news.povray.org>
>> sphere,
>> persists.
>> like the
>> media didn't.
>> Weird...
I don't know if it's realy a bug, I like to call it an improvement.
Anyway, as it is now, it makes it reasier to correctly place the
looks_like at the same place as the light_source.
You can have something like:
#macro My_light(Location, Colour) = light_source{Location, Colour
looks_like{Some_Object}}}
As long as the object is defined at the origin, then, for any value of
Location, the looks_like object will be at the correct location.
That behaviour did NOT change since the early betas of version 3.7.
Date: 29 Oct 2011 15:09:34
Message: <4eac4f6e$1@news.povray.org>
Am 29.10.2011 20:29, schrieb Alain:
No, it's definitely a bug: If you create the light source at <0,0,0>,
add a looks_like object, then finally translate the whole thing, then
the looks_like object moves (same as per 3.6) - but its texture and
media fails to move with it. That definitely does /not/ make things simpler.
Date: 30 Oct 2011 01:50:01
Message: <web.4eace579693b00485ae2687f0@news.povray.org>
If this is the case, then it explains a similar problem I came across while
making a star in 3.7.0 RC3. I worked around it using a union of a light_source
and a sphere with media and translating that instead.
D103
Date: 30 Oct 2011 17:04:02
Message: <4eadbbc2@news.povray.org>
> simpler.
THAT part is definitively a bug. The transform must affect everything,
especialy any texture and media.
The part I do like is that the looks_like object is centered on the
light_source whatever it's effective INITIAL location.
