POV-Ray : Newsgroups : povray.binaries.images : An experiment Server Time
27 Jul 2025 10:21:54 EDT (-0400)
  An experiment (Message 1 to 3 of 3)
Subject: An experiment
Date: 9 Mar 2011 16:25:01
Message: <web.4d77ef1bd8750ea91a86e02e0@news.povray.org>
A creation of impulse.  Based on an experiment with a tutorial.
It would be interesting to write a macro to create a parchment object based on a
silhouette, using eval-pigment.  As it is, this is an Isosurface, created with a
black-and-white mask of the parchment. The texture is an image map.
I had some ideas a while back about using trace with a text object to drop words
onto a sheet of material, and create a texture using the object pattern, but I
never really got anywhere, largely because of time constraints.
as usual, comments are welcome.
A.D.B.
Download 'parchment.png' (417 KB)
Preview of image 'parchment.png'
Subject: Re: An experiment
Date: 9 Mar 2011 20:30:01
Message: <web.4d782795a511215697eae0eb0@news.povray.org>
I like the sense that this parchment has overcome all odds, to be encased within
an environment resistant to decay.
I can sympathize with the request. There are some things we simply can't change
on our own (death, [really] deep programming, additional myriad circumstances
entirely out of our hands...).
What's wrong with using a height_field? It doesn't have to be *too* high-res,
only enough to withstand the subtle harshness of area_lights on triangle objects
for a given resolution.
Why not make your text objects into an object pattern? Such a pattern would
exist at z = 0.0, and could then made planar. A good way to make any pattern
infinite along the z-axis is to apply a planar warp: pigment{
MyTextObjectPattern warp{ planar } }.
This way your words will always show up :)
~Sam
Date: 10 Mar 2011 13:44:11
Message: <4d791bfb@news.povray.org>
> A.D.B.
If you use an object pattern for your text, there is nothing to prevent
you from using a very thick text object.
You can also scale your text along the Z axis as needed.
Then, as Samuel mentioned, there is the planar warp way.
