POV-Ray : Newsgroups : povray.binaries.images : Flame Server Time
23 Aug 2025 07:37:21 EDT (-0400)
  Flame (Message 1 to 7 of 7)
Subject: Flame
Date: 25 Feb 2011 21:25:01
Message: <web.4d686370c4ff33658739afcb0@news.povray.org>
An attempt for a flame, using a blob container. Some dots appear on the surface:
known bug?
Also: In the doc at "3.4.7.5 Area Lights" it is explained that, with 'circular',
area_lights can be elliptical if x and y axis are not equal. It seems that if I
make so, the thickness of the soft shadows are of the same thickness in all
directions. In this test scene I tried y=5*x, but the soft shadow of the sphere
on the left is even all around. Is this the effect of 'orient'? What did I miss?
Download 'flame2.png' (64 KB)
Preview of image 'flame2.png'
Subject: Re: Flame
Date: 25 Feb 2011 22:34:07
Message: <4d6874af@news.povray.org>
Am 26.02.2011 03:24, schrieb Bruno Cabasson:
> known bug?
That would depend on what you actually did there :-)
I think the docs don't mention it, but in case "orient" is used, the
area light's Y axis is effectively ignored.
The reason is probably because when you use "orient", it is no longer
clearly defined in which directions the area light's axes point - only
that the axes are re-oriented to be perpendicular to the direction of
the light; so the result might get messy. And even if "orient" would be
specified to try keep the Y axis "as vertically as possible" (like
point_at does with the camera), it still wouldn't give you what you'd
want for shadows above or below the light source.
Subject: Re: Flame
Date: 26 Feb 2011 05:00:01
Message: <web.4d68cece2bc4e8d327dfd4010@news.povray.org>
> > known bug?
See code below (other version with only the area_light inside the flame, but
artifact still there)
Would it be possible to specify a rotation axis with some keyword like 'up' or
'axis' or whatever?
Bruno
#include "strings.inc"
global_settings
    assumed_gamma 1
    ambient_light 0
#declare LIGHT_COLOR = (2*Yellow+2*Goldenrod+Blue)/5;
#declare FLAME_COLOR1 = (2*Yellow+2*Goldenrod)/4;
#declare FLAME_COLOR2 = (2*Red+Yellow+2*Goldenrod)/5;
camera
    location -10*z
    angle 40
light_source {
  0 color LIGHT_COLOR*4
  area_light x/5, y, 11, 11 adaptive 1 circular orient area_illumination
  fade_distance 2 fade_power 2
sphere
    0, 1
    hollow
    pigment {brick scale 0.5*x scale 1/150 warp {spherical}}
    scale 15
#declare Sp_Flame = spline
    cubic_spline
    -0.1, <0, -0.5, 0, 0.9>
    0.00, <0, 0, 0, 0.8>
    0.30, <0.1, 1.5, 0, 0.7>
    0.9, <0.1, 5.5, 0, 0.3>
    1.00, <0.1, 6, 0, 0.15>
    1.1, <0.05, 6.5, 0, 0>
#declare Sh_Flame = blob
    #local i=0;
    #local N = 101;
    #while (i<N)
        #local _v = Sp_Flame(i/(N-1));
        #local _p = <_v.x, _v.y, _v.z>;
        #local _r = _v.t;
        sphere {_p, _r, 1}
        #local i=i+1;
    threshold 0.6
    scale 1/6
#declare M_EMedia = media
    samples 20
    emission 15
    density
        gradient y scale 1.2 translate -0.15*y
        scale 5 warp {turbulence 0.4*y octaves 1} scale 1/5
        translate -0.4*x
        color_map
            [0.10 rgb 0]
            [0.15 Navy/2]
            [0.25 FLAME_COLOR2*1.3]
            [0.45 FLAME_COLOR1*1.6]
            [0.90 FLAME_COLOR1]
            [0.95 Orange]
#declare M_AMedia = media
    samples 20
    absorption 5
    density
        translate -0.4*x
        color_map
            [0.10 rgb 0]
            [0.15 rgb 1]
            [0.25 rgb 3]
            [0.45 rgb 2]
            [0.90 rgb 1]
            [0.95 rgb 0]
#declare Ob_Flame = object
    Sh_Flame
    pigment {rgbt 1}
    hollow
    interior
        media {M_EMedia}
        media {M_AMedia}
object {Ob_Flame scale 1.5 translate -y/2}
cylinder {0, 2*x, 0.05 pigment{Tan} translate -0.1*x-1.1*y/2}
sphere {0,1 pigment{White} scale 1/3 translate -x+y/3+3*z}
Subject: Re: Flame
Date: 26 Feb 2011 05:35:01
Message: <web.4d68d7432bc4e8d327dfd4010@news.povray.org>
I just noticed that the artifact disappears if I remove the dome.
Subject: Re: Flame
Date: 26 Feb 2011 13:14:18
Message: <4d6942fa@news.povray.org>
> 'axis' or whatever?
> Bruno
I'm also thinking about some variation for orient. My take would be
orient axis. Here, the area_light would be rotated ONLY around a
provided axis, making it cylindrical instead of spherical.
Ex.: orient x
Another variation: the possibility to punch a hole in the center of the
array, keeping only the outer elements. With circular, it makes a crown
shaped light. Less usefull, but there are lights that have such a shape.
Subject: Re: Flame
Date: 26 Feb 2011 14:04:54
Message: <4d694ed6@news.povray.org>
Am 26.02.2011 19:14, schrieb Alain:
> Ex.: orient x
Thought about that, too. With exactly the same syntax, actually.
Re-orientation would then be limited to rotations about that axis, and
the "orientation direction" would be that which comes closest to the
direction towards the illuminated object.
Maybe some "volume_light", taking a pattern or df3 file for the
brightness of sub-regions.
Subject: Re: Flame
Date: 26 Feb 2011 17:59:29
Message: <4d6985d1$1@news.povray.org>
>> Ex.: orient x
That would be nice. Some totaly customisable light sources. Obviously,
you probably can't optimize those as well as a regulat area_light.
