POV-Ray : Newsgroups : povray.binaries.images : SSLT candle experiment Server Time
7 Oct 2024 07:23:24 EDT (-0400)
  SSLT candle experiment (Message 1 to 10 of 18)
Subject: SSLT candle experiment
Date: 15 Feb 2011 11:25:00
Message: <web.4d5aa7f0e5f2dd434aa45fdf0@news.povray.org>
Playing with SSLT, I took the candle from the subsurface.pov example, and tried
to have a satisfactory result. Used radiosity.
Bruno
Download 'candle7.png' (113 KB)
Preview of image 'candle7.png'
Subject: Re: SSLT candle experiment
Date: 17 Feb 2011 02:55:01
Message: <web.4d5cd3f944aed71b4aa45fdf0@news.povray.org>
> Bruno
Following this post and the 'SSLT and scaling' thread, here an attempt for
scaling the candle and see what happens for SSLT parameters. It appears to me
that subsurface parameters must be adjusted wrt scaling so as to have consistent
behaviour. One can turn comment out the candles to see them individually, and
use DECLARE=QUALITY=1 for quick rendering.
It also seems that the wick projects a shadow at its base despite the no_shadow
keyword.
Finally, I am wondering about the smallest candle and the sharp shadows in the
bottom right.
I continue playing.
Bruno
#version 3.7;
#declare m = 1;
#declare cm = m/100;
#declare mm = m/1000;
#declare FLAME_COLOR = (2*Orange+Yellow)/3;
#declare FLAME_POWER = 4;
#declare FLAME_FADE_DIST = 15*cm;
//#declare QUALITY = 1; // Use DECLARE=QUALITY=1 in command line
#declare RAD_COUNT = 50*QUALITY;
#declare SSLT_SAMPLES = <20, 5>*QUALITY*2;
#default { finish{ambient 0 emission 0}}
global_settings
    assumed_gamma 1
    mm_per_unit 1/mm
    subsurface { samples SSLT_SAMPLES.x, SSLT_SAMPLES.y}
    radiosity
        pretrace_start 32/image_width
        pretrace_end 2/image_width
        count RAD_COUNT
        error_bound 0.5
        nearest_count 15
        recursion_limit 2
        low_error_factor 1
        media on
  location  <0.0, 1.0, -4.0>*8*cm
  direction 1.5*z
  look_at   <0.5, 0.75,  0.0>*8*cm
declare LS_Lamp = light_source {<-5, 5, -5>*m color rgb 0.2}
#macro makeLSCandle(_power)
    #local _ret = light_source
      0
      color rgb FLAME_POWER*FLAME_COLOR*_power
      area_light 1*cm*x, 2*cm*y, 4*QUALITY, 4*QUALITY adaptive 1 circular orient
      //area_illumination on
      fade_power 2
      fade_distance FLAME_FADE_DIST
      //looks_like {sphere {0, 2*mm pigment {Red}}}
    _ret
#declare O_Floor = plane
    y, -0.1*mm
    pigment {rgb 1}
// a candle...
#macro make10cmCandleBody (_scale)
    blob
      threshold 0.5
      cylinder { <0.0, 0.0,  0.0>,
                 <0.0, 2.0,  0.0>,  1.0,   1.0 } // candle "body"
      sphere   { <0.0, 2.5,  0.0>,  0.8,  -2.0 } // (used to shape the candle
top)
      sphere   { <0.0,-0.52, 0.0>,  0.8,  -2.0 } // (used to shape the candle
bottom)
      sphere   { <0.0, 2.0, -0.5>,  0.1,  -0.2 } // the "notch" where wax runs
over
      cylinder { <0.0, 1.88,-0.52>,
                 <0.0, 1.5, -0.52>, 0.05,  0.2 } // a streak of wax running over
      sphere   { <0.0, 1.5, -0.55>, 0.07,  0.2 } // a drop of of wax running
over
      texture
        //pigment {wrinlkles scale 0.1 color_map {[ 0.3 Blue] [0.3 Red]}}
        pigment {rgb 1}
        finish
          specular 0.1 roughness 2*cm
          ambient 0
          // "artificial" wax parameters
          subsurface { < 1.6732, 1.2806, 0.6947>*pow(_scale,1/3),< 0.0005,
0.0018, 0.0131>*pow(_scale,1/3)}
      scale 1/2
      scale 10*cm
      scale _scale
      interior { ior 1.45 }
      rotate -y*45
// ... and the wick
#declare O_Wick = cylinder
    0, 1*cm*y, 1*mm
    pigment {rgb 0.05}
#macro makeFlame(_power)
    ovus
        3.5*mm, 3*mm
        pigment {rgbt 1}
        //finish {emission 1}
        hollow
        interior
            media
                samples 20
                scattering {1, (1/_power)*3/(1*cm)}
                absorption 6/(1*cm)
                density {spherical scale 2 warp {turbulence 0.7 octaves 8} scale
1/2 scale 0.3*cm scale 2*y translate -1*mm*y }
                density {spherical scale 0.3*cm scale 2*y translate -1*mm*y }
        scale 3
        no_shadow
#macro make10cmCandle(_scale, _power)
    union
        light_source {makeLSCandle(_power) translate 11*cm*y  scale _scale}
        object {make10cmCandleBody(_scale)}
        object {O_Wick translate 9.75*cm*y scale _scale no_shadow}
        object {makeFlame(_power) translate 11.5*cm*y scale _scale }
#declare O_Dome = sphere
    0, 5*m
    hollow
    pigment {checker scale 0.1*m}
//light_source {LS_Lamp}
object {O_Floor}
object {make10cmCandle(1, 1) rotate 90*y}
object {make10cmCandle(1/2, sqrt(1/2)) translate 7*cm*x - 5*cm*z}
object {make10cmCandle(1/4, sqrt(1/4)) translate 10*cm*x - 10*cm*z}
object {O_Dome}
Download 'candle14.png' (134 KB)
Preview of image 'candle14.png'
Date: 17 Feb 2011 04:01:11
Message: <4d5ce3d7$1@news.povray.org>
On 17/02/2011 7:53 AM, Bruno Cabasson wrote:
> I continue playing.
My experiments lead me to believe that AA settings have a strong effect
on SSLT.
Regards
Date: 17 Feb 2011 04:32:56
Message: <4d5ceb48$1@news.povray.org>
Am 17.02.2011 08:53, schrieb Bruno Cabasson:
> behaviour.
Scaling is /not/ necessary if you want the things to appear as being
made out of the same material but different sizes.
The differences you see are probably due to the many other tweakables
you have per candle.
> keyword.
No. I'm pretty puzzled about what's going on there, but it's definitely
not the wick, as can be plainly seen when you comment that out.
I prefer to think that the rim is brighter because it gets illuminated
not only by the light from above, but also from light being reflected
back at the candle's sides (remember fresnel reflectance), whereas at
the center the light just diffuses towards the bottom and gets absorbed
along the way, so maybe it's realistic after all (given the material
parameters we have, which are potentially bogus).
> bottom right.
That is, of course, the shadow from the smallest and medium candle, cast
by the light of the largest candle.
BTW, for more dramatic (and actually more realistic) atmosphere, reduce
FLAME_FADE_DIST, and increase FLAME_POWER instead.
As a rule of thumb, fade_distance of an area light source should be
about the same order of magnitude as the area light's dimensions.
Another issue with your scene is the non-circular circular area light.
I'm not sure whether this works at all, but in combination with orient
it may give you pretty surprising results, as the area light source may
essentially be rotated about /any/ axis to achieve the necessary
orientation.
> I continue playing.
> Bruno
> #version 3.7;
> #declare m = 1;
> #declare SSLT_SAMPLES =<20, 5>*QUALITY*2;
> global_settings
>      assumed_gamma 1
>      mm_per_unit 1/mm
>      radiosity
>          count RAD_COUNT
>          error_bound 0.5
>          nearest_count 15
>          recursion_limit 2
>          low_error_factor 1
>          media on
> camera {
>    location<0.0, 1.0, -4.0>*8*cm
>    direction 1.5*z
>    look_at<0.5, 0.75,  0.0>*8*cm
>        0
>        fade_power 2
>      _ret
> #end
>      y, -0.1*mm
>      pigment {rgb 1}
> // a candle...
>      blob
>        threshold 0.5
>        cylinder {<0.0, 0.0,  0.0>,
>        sphere   {<0.0, 2.5,  0.0>,  0.8,  -2.0 } // (used to shape the candle
> top)
>        sphere   {<0.0,-0.52, 0.0>,  0.8,  -2.0 } // (used to shape the candle
> bottom)
>        sphere   {<0.0, 2.0, -0.5>,  0.1,  -0.2 } // the "notch" where wax runs
> over
>        cylinder {<0.0, 1.88,-0.52>,
>        sphere   {<0.0, 1.5, -0.55>, 0.07,  0.2 } // a drop of of wax running
> over
>        texture
>          pigment {rgb 1}
>          finish
>            ambient 0
>            subsurface {<  1.6732, 1.2806, 0.6947>*pow(_scale,1/3),<  0.0005,
>        scale 1/2
>        scale 10*cm
>        scale _scale
>        rotate -y*45
> #end
> // ... and the wick
>      0, 1*cm*y, 1*mm
>      pigment {rgb 0.05}
>      ovus
>          3.5*mm, 3*mm
>          pigment {rgbt 1}
>          hollow
>          interior
>              media
>                  samples 20
>                  absorption 6/(1*cm)
>          scale 3
>          no_shadow
> #end
>      union
> #end
>      0, 5*m
>      hollow
> object {O_Floor}
> object {O_Dome}
Date: 17 Feb 2011 04:35:47
Message: <4d5cebf3$1@news.povray.org>
Am 17.02.2011 10:01, schrieb Stephen:
>> I continue playing.
> on SSLT.
They do insofar as they counter some of the noise. Other than that, they
shouldn't make a difference.
(Note in that context that if you're using an assumed_gamma other than
1.0, or have your display gamma wrong, noisy areas appear to have
different brightness than de-noised ones.)
Date: 18 Feb 2011 01:40:01
Message: <web.4d5e134344aed71bf7fe15af0@news.povray.org>
> >> I continue playing.
> > on SSLT.
Is this one better?
Download 'candle15.png' (139 KB)
Preview of image 'candle15.png'
Date: 18 Feb 2011 02:35:01
Message: <web.4d5e1fa744aed71b53da43a00@news.povray.org>
> Is this one better?
The wax looks just right, you can see the sizes just at a glance by the SSLT!
Cheers,
Edouard.
Date: 18 Feb 2011 05:05:01
Message: <web.4d5e43e544aed71b4aa45fdf0@news.povray.org>
"Edouard" <pov### [at] edouardinfo> wrote:
> > Is this one better?
> Cheers,
> Edouard.
In this experiment, I intended to make the size of the flame proportional to the
size of the candle. So, I adjusted the lights powers according to the sizes
proportionally, ie: *2 for the biggest, *1, *1/2, *1/4 respectively. I don't
know the law for the illumination of flames wrt their size. I suppose the
illumination comes from the surface of the flame, and therefore follows a
quadratic law. My powers are surely wrong for flame powers proportional to the
flame sizes.
However, in RL, the size of the flame is generally not proportional to the size
of the candle ...
I also set the fade_distance in the same order of magnitude than the area light
(twice). I am a bit confused by the fact that the dome is so barely visible,
despite 4 candles. But, after all, they are small (the biggest is 16 cm high)
and the dome is 5 metre from there. Maybe relative illuminations are correct.
Date: 18 Feb 2011 07:17:47
Message: <4d5e636b$1@news.povray.org>
Am 18.02.2011 07:35, schrieb Bruno Cabasson:
> Is this one better?
Hell, yeah!
Date: 18 Feb 2011 07:20:39
Message: <4d5e6417$1@news.povray.org>
Am 18.02.2011 11:03, schrieb Bruno Cabasson:
I never liked that dome anyway :-P
