POV-Ray : Newsgroups : povray.binaries.images : 1957 Bel Air - revisited Server Time
18 Feb 2026 21:41:46 EST (-0500)
  1957 Bel Air - revisited (Message 1 to 10 of 20)
Subject: 1957 Bel Air - revisited
Date: 12 Feb 2011 20:55:01
Message: <web.4d5738e3bb36e172b05ef170@news.povray.org>
Rerun of an old scene, with lower perspective, different env map and focal blur
(of course...).
-tgq
Download '1957 chevrolet bel air.jpg' (531 KB)
Preview of image '1957 chevrolet bel air.jpg'
Subject: Re: 1957 Bel Air - revisited
Date: 12 Feb 2011 21:37:54
Message: <4d574402$1@news.povray.org>
> focal blur (of course...).
Very nice - one question, though, is it just me, or do the headlights
look odd?
Jim
Date: 13 Feb 2011 04:29:12
Message: <4d57a468@news.povray.org>
"Jim Henderson" <nos### [at] nospamcom> schreef in bericht
news:4d574402$1@news.povray.org...
> look odd?
I think they need some more subdivision as the mesh seems to be too crude.
Date: 13 Feb 2011 09:25:01
Message: <web.4d57e9b829817e6cb05ef170@news.povray.org>
> > look odd?
> Thomas
That's part of it.  The mesh I'm using (from elsewhere( is not refined enough as
can be seen around the wheel well and whell itself.
I think there is more issues with the headlight than just that though.  One
problem that always comes up, is these models come with a single layer mesh for
the window, headlight glass etc, which, when rendered as glass in POV becomes
infinitely thick, so I have to manually manipulate the mesh to add a second
layer so the glass has thickness.  Typically for older style head lights, the
interior surface of the glass is not smooth, but facted.  Perhaps I should try
adding some normals to them.
-tgq
Date: 13 Feb 2011 12:13:54
Message: <4d581152$1@news.povray.org>
Am 13.02.2011 02:50, schrieb Trevor G Quayle:
> (of course...).
I think it's a bit /too/ much focal blur to look realistic.
Note that the aperture parameter is the diameter of the camera opening
in POV units. To give a proper sense of scale, it should be in the order
of magnitude of a human eye's pupil.
Date: 13 Feb 2011 14:26:20
Message: <4d58305c$1@news.povray.org>
> enough as can be seen around the wheel well and whell itself.
> One problem that always comes up, is these models come with a single
> layer mesh for the window, headlight glass etc, which, when rendered as
> glass in POV becomes infinitely thick, so I have to manually manipulate
> the mesh to add a second layer so the glass has thickness.  Typically
> for older style head lights, the interior surface of the glass is not
> smooth, but facted.  Perhaps I should try adding some normals to them.
Ah, that explains it - I couldn't quite put my finger on what looked odd.
Thanks for that, and even with that issue, it's a fantastic image. :-)
Jim
Date: 14 Feb 2011 09:00:01
Message: <web.4d5934e229817e6c81c811d20@news.povray.org>
> > (of course...).
Focal blur is meant to be more photographic than human eye.
Thanks for the info on what the aperture number means, never really knew before.
 I'll see if I can figure out a way to translate it to camera aperture.
-tgq
Date: 14 Feb 2011 13:08:02
Message: <4d596f82$1@news.povray.org>
Am 14.02.2011 14:57, schrieb Trevor G Quayle:
With the aperture wide open, it would be the lens diameter. But you
wouldn't normally use that in good daylight - at least not with
conventional photographic cameras. I don't know about digicams.
With other aperture settings, just take any camera, look at its lens -
you should see the aperture in there - and use the /apparent/ diameter
of the aperture.
I guess in professional photograpy the aperture will typically be set to
something that comes close to the human eye, too, whenever there is
something visible in the foreground - if only to prevent the shot from
looking oddly miniature-ish. Where large aperture settings are used for
effect, you'll typically see either no foreground elements at all, or
they're blurred as hell.
BTW, shots with a gradual transition from foreground to motif - e.g. the
pavement in your shot - are worst of all I guess.
Date: 14 Feb 2011 15:45:01
Message: <web.4d59932a29817e6c81c811d20@news.povray.org>
> (of course...).
> -tgq
1967 Chevrolet Camaro SS.  Much nicer mesh.  Also, has hidden headlights, so no
concern with odd looking headlight modelling.
And less focal blur for clipka :)
-tgq
Download '1967 chevrolet camaro ss.jpg' (196 KB)
Preview of image '1967 chevrolet camaro ss.jpg'
Date: 14 Feb 2011 16:51:44
Message: <4d59a3f0$1@news.povray.org>
> -tgq
getting closer (car-wise) ... the scene looks great. Now lets see one of
a Ford Cobra ... blue with big white stripe, or are you strictly a GM fan?
