I'm working on a concept for a shoreline backed by Basalt columns. I'm using a
randomly tiled hexagonal pattern function with a height field and multiplying it
by f_ridged_mf
The problem I'm having is that the tops of the columns should be flat, not
slanted, so that the base offset follows the contour of f_ridged_mf, but their
height does not.
Not sure if that makes sense.
the code is as follows, Image attached at bottom.
#include "kolors.inc"
#include "functions.inc"
light_source { 1e4 1 }
camera { location 60 look_at 0 }
#declare pigA=pigment { cells
warp { repeat z offset <-.5,10,0>}
translate z/2
scale <3,1,sqrt(6.75)>
#declare pigB=pigment { cells
translate <1.5,7,0>
#declare pigC=pigment { cells
translate <0,-7,0>
#declare basaltColumns =
function {
hexagon
pigment { pigA },
pigment { pigB },
pigment { pigC }
rotate 90.0*x
sky_sphere {
function { abs(y) }
color_map {
[0.0 rgb 1 ]
[0.1 SkyBlue ]
[1.0 SkyBlue ]
isosurface {
function { y - 3.0 * basaltColumns(x,y,z).y }
max_gradient 5206
threshold 0
contained_by { box { -5, 5 } }
pigment { rgb 1 }
finish { ambient 0.2 diffuse 0.6 }
// f_ridged_mf(x,y,z, 0.1, 3, 7, 0.7, 0.7, 2)
object {
height_field {
function 512, 512 { f_ridged_mf(x*3,y*3,z*3, 0.6, 3, 7, 0.7, 0.7, 2)
* basaltColumns(x*60,y*60,z*60).y }
// water_level 0.15
translate <-0.5, 0.0, -0.5>
scale <100, 20, 100>
pigment { White }
Any advice would be appreciated.
A.D.B.
Download 'hextile.png' (341 KB)
Preview of image 'hextile.png'
> by f_ridged_mf
> height does not.
> Regards,
> A.D.B.
For that, I'd use an hexagonal prism, modeled as a mesh, that is tilled
with various vertical scales dictated by your function.
The mesh is to reduce the memory use and will render much faster than
the isosurface version.
> > by f_ridged_mf
> > height does not.
> > Regards,
> > A.D.B.
> Alain
Yeah... Not sure what you have in mind, but I couldn't figure out anything that
looked remotely right.
I realize there are going to be problems with the height_field approach, not the
least of which are the vertical striations in the columns, I would like to use
your approach. (although I might use a csg hex tile)
I could create caves this way.
the thing I like about the hf approach is that I could conceivably create a
pigment function that contains multiple sub-patterns using pigment_map (Basalt
columns turning into black sand, for instance.)
I'm quite at a loss... What I'd like to do, ultimately is a shoreline of basalt
columns and outcroppings fading into green hills inland, which is why I was
using the height_field. I tried using an isosurface, but the max_gradient was
way too high. (over 5000)
A.D.B.
>>> by f_ridged_mf
>>> height does not.
>>> Regards,
>>> A.D.B.
>> Alain
Using CSG is correct, but you won't benefit from the instantiation you
get with meshes, resulting in a increased memory useage.
> Regards,
> A.D.B.
In real life, those columns don't "fade" into some other features, they
get covered up with the other features.
So, you can have a hightfield for your sandy area at the base, and
another for the grassy regions.
> by f_ridged_mf
> height does not.
I think you you could achieve that by slightly modifying your
code to produce two function definitions that are then combined
using the max function. The exact definitions will depend on
the intended result (e.g., should the height of a column be
constant or depend on the (average) height of the ground?
> by f_ridged_mf
> height does not.
Hi Anthony,
You can use an array of cones to produce the needed topology for your basalt. It
will need to be rendered as a height map beforehand. Here's a quick idea that
might help you on your quest:
basalt.pov
2011 Samuel Benge
A quick basalt height map generator. Render with +rng or hf_gray_16
#include "math.inc"
// user variables
#declare N_Rows = 20; // this determines the number of columns
#declare N_Extra_Columns = 0; // how many columns to randomly add
#declare Jitter = 0.2; // makes everything a bit more natural
#declare Height_Function = // your height function here
function{
// ~user variables
#default{ finish{ ambient 1 } }
camera{
orthographic
right x*2 up y*2
location -z*10
union{
#declare R = seed(1001);
#declare Z = -int(N_Rows*1.4/2);
#while(Z<=int(N_Rows*1.4/2))
#declare X = -int(N_Rows/2);
#while(X<=int(N_Rows/2))
cone{0,0,-y,2/N_Rows
#local Vec =
X+odd(Z)/2+rand(R)*Jitter,
0,
Z+rand(R)*Jitter
>/N_Rows*<1,1,sin(pi*2/3)>*2;
#declare XV = Vec.x;
#declare ZV = Vec.z;
translate Vec
pigment{rgb Height_Function(XV,0,ZV).x}
#declare X=X+1;
#declare Z=Z+1;
// extra columns
#declare V=0;
#while(V<N_Extra_Columns)
cone{0,0,z,1/N_Rows
#local Vec = <-1+rand(R)*2, -1+rand(R)*2, 0>;
#declare YV = Vec.y;
translate Vec
pigment{rgb Height_Function(XV,YV,0).x}
#declare V=V+1;
rotate x*270
// ~basalt.pov
The edges of each column will still produce artifacts, but you can overcome this
to some degree by blurring the 16-bit gray scale image. I've provided a scene
file for blurring an image. It's over at p.t.scene-files and is called
"blurResample.pov."
http://news.povray.org/povray.text.scene-files/thread/%3C4d34c72d%40news.povray.org%3E/
I hope that helps!
Sam
Ack, there was a glaring error with the code I posted. Here's a fully-working
version (c:
basalt.pov
2011 Samuel Benge
#include "math.inc"
// user variables
#declare Jitter = .5; // makes everything a bit more natural
function{
f_ridged_mf(x*3, y*3, z*3, 0.6, 3, 7, 0.7, 0.7, 2)
// ~user variables
camera{
orthographic
right x*2 up y*2
location -z*10
union{
#local Vec =
0,
Z+rand(R)*Jitter
translate Vec
#declare X=X+1;
#declare Z=Z+1;
// extra columns
#declare V=0;
#local Vec = <-1+rand(R)*2, 0, -1+rand(R)*2>;
translate Vec
#declare V=V+1;
rotate x*270
// ~basalt.pov
> version (c:
> basalt.pov
> 2011 Samuel Benge
> #include "math.inc"
> // user variables
> function{
> // ~user variables
> camera{
> orthographic
> right x*2 up y*2
> location -z*10
> union{
> #local Vec =
> 0,
> Z+rand(R)*Jitter
> translate Vec
> #declare X=X+1;
> #end
> #declare Z=Z+1;
> #end
> // extra columns
> #declare V=0;
> translate Vec
> #declare V=V+1;
> #end
> rotate x*270
> // ~basalt.pov
Looks like a cells pattern to me. Basalt is crystalline, and I've noticed from
looking at photos that the fracture tends to be either hexagonal or cubic.
I'm currently working on modifying my original pigment so that the greyscale
values for certain ranges are determined by my hex-tile function.
A.D.B.
