POV-Ray : Newsgroups : povray.binaries.images : SSLT Fun Server Time
27 Jul 2025 16:59:55 EDT (-0400)
  SSLT Fun (Message 1 to 10 of 10)
Subject: SSLT Fun
Date: 21 Sep 2010 23:45:01
Message: <web.4c9978f935d8e4da1a939910@news.povray.org>
More SSLT fun, and maybe I've got this all wrong, but I'm following Jaime's
wise ignorancia philosophy and this is working for me right now...
Please pardon the code here, but I think it's nice posted all in one spot like
this:
// Persistence of Vision Ray Tracer Scene Description File
// File        : sslt_spheres.pov
// Version     : 3.7
// Description : Playing with SSLT stuff
// Date        : 09/21/2010
// Author      : Robert W. McGregor, rob### [at] mcgregorFineArtcom
#version 3.7;   // beta 39
default { pigment { color rgb 0.75 } finish { ambient 0 diffuse 0.5 }}
#include "math.inc"
#include "rand.inc"
// Globals and radiosity settings
#declare R = seed(1234);
#declare Soft_Shadows  = 1;
#declare Use_Radiosity = 1;
#declare SCALE = 100;
global_settings {
   max_trace_level 5
   #if (Use_Radiosity)
      radiosity {
         brightness      1
         recursion_limit 2
         always_sample   off
         normal          off
         nearest_count   10
// Camera & lights
background { color rgb 0 }
   location  <0, 0, -15>*SCALE
   look_at   <0, 0, 0>
   right <image_width/image_height, 0, 0>
   angle 30
#declare light_pos = <-1.5, 1.5, 1.5>*SCALE;
light_source {
   light_pos
   color rgb 3
   #if (Soft_Shadows)
      area_light <10, 0, 0>, <0, 0, 10>, 5, 5
      adaptive 2
      jitter
      orient circular
   fade_distance VDist(<0,0,0>,light_pos)
   fade_power 2
// SSLT subsurface colors
#local sslt_aqua    = <1, 0, 0>;
#local sslt_magenta = <0, 1, 0>;
#local sslt_yellow  = <0, 0, 1>;
#local sslt_blue    = <1, 1, 0> ;
#local sslt_red     = <0, 1, 1>;
#local sslt_green   = <1, 0, 1>;
#local sslt_grey    = <0, 0, 0>;
// Macro: MakeSphere()
//        SSLT Sphere
#macro MakeSphere(clr)
   #local AMT = 0.5;
   //#local amt = < 1.6732, 1.2806, 0.6947>;   // clipka's from subsurface.pov
   #local amt = < 0.001, 0.001, 0.001>*AMT;
   sphere { 0, 1
         pigment {rgb 0}
         finish{
            #local AMT = 20;
            subsurface { amt, clr }
            bozo
            color_map {[0 rgbt 0][1 rgbt 1]}
            scale 0.2
            turbulence 0.5
            rotate RRand(0, 360, R)
         normal {
            bozo
            normal_map {
               [0 granite 1 scale 10]
               [1 agate 0.01 ]
            turbulence 0.5
            scale 0.075
            bump_size -5
         finish {
            ambient 0
            diffuse 0.6
            specular 0.25 roughness 0.02
      interior { ior 1.33 }
// The spheres
union {
   object { MakeSphere(sslt_green)   translate x*2.5 rotate z*360/7*0 }
   object { MakeSphere(sslt_aqua)    translate x*2.5 rotate z*360/7*1 }
   object { MakeSphere(sslt_blue)    translate x*2.5 rotate z*360/7*2 }
   object { MakeSphere(sslt_magenta) translate x*2.5 rotate z*360/7*3 }
   object { MakeSphere(sslt_red)     translate x*2.5 rotate z*360/7*4 }
   object { MakeSphere(sslt_yellow)  translate x*2.5 rotate z*360/7*5 }
   object { MakeSphere(sslt_grey)    translate x*2.5 rotate z*360/7*6 }
   scale SCALE
//end file======================================================================
Cheers,
Rob
www.McGregorFineArt.com
Download 'sslt_spheres.png' (440 KB)
Preview of image 'sslt_spheres.png'
Subject: Re: SSLT Fun
Date: 22 Sep 2010 03:22:57
Message: <4c99aed1@news.povray.org>
I like this, Robert. I have not experimented much with sss, but I am
certainly going to play around with your code for a start.
Date: 22 Sep 2010 05:15:00
Message: <web.4c99c7f927cc93676dd25f0b0@news.povray.org>
I, too, feel a need to play with this new feature. Nice example!
Date: 22 Sep 2010 07:45:01
Message: <web.4c99eaaa27cc93671a939910@news.povray.org>
Thanks guys, the documentation's a bit sketchy so I've been trying all sorts of
crazy things with SSLT to see what each parameter actually does. This morning I
discovered that there's a new global_settings param [mm_per_unit], so instead of
using the SCALE for scaling things up 100x to keep the effect subltle:
global_settings {
   mm_per_unit 1000  // default is 10
#declare SCALE = 1;
Not exactly the same but I like this better with a bit more SSLT happening.
Download 'sslt_spheres2.png' (431 KB)
Preview of image 'sslt_spheres2.png'
Date: 22 Sep 2010 07:50:01
Message: <web.4c99ec9b27cc9367196b08580@news.povray.org>
I have a funny feeling that I *might* not be seeing this .png image correctly in
my browser window, but I just don't know for sure. ( Firefox v3.6.10, the latest
AFAIK.) What I see is a generally dark image, as well as the bright soft
'crescents' of the spheres, with just a *hint* of color on their dark sides.
Sound correct? (I took the image into my old version of Photoshop, changed *its*
2.2 gamma to 1.0--brightening the spheres' dark sides up nicely--saved it as a
jpeg, and the image looks like what I *think* I should be seeing.) But of
course, the original darker image may be what's intended.
I just want to make sure that I'm seeing proper .png behavior on my end; I
sometimes wonder, given previous (but sporadic) behavior.
Ken
Date: 22 Sep 2010 15:21:13
Message: <4c9a5729$1@news.povray.org>
>        area_light<10, 0, 0>,<0, 0, 10>, 5, 5
>        adaptive 2
Do you realise that adaptive 2 tries to use at least a 5x5 aray in your
area_light?
In this case, with or without adaptive, it takes the same amount of time
as there is no adaptive sampling done at all.
nice image by the way. Time to play some more with sslt.
Date: 22 Sep 2010 19:45:49
Message: <4c9a952d$1@news.povray.org>
I'm fairly up to date over there reference-wise:
http://wiki.povray.org/content/Documentation:Reference_Section_5.1#Subsurface_Light_Transport
but would like to add something to the tutorial on this feature. I'm
currently working on a new radiosity tutorial, so couldn't possibly add
more at the moment, but if anyone would like to put together a bit of a
demo while you guys are toying around with this new feature, I'd love to
see it and perhaps get it into the docs ... Any takers?
Jim
Date: 24 Sep 2010 10:43:48
Message: <4c9cb924$1@news.povray.org>
Those balls look very good, I kinda like them. Can you create a version of
1600 pixels width? I would like to have it as desktop background. Thanks.
Date: 24 Sep 2010 14:14:54
Message: <4c9cea9e$1@news.povray.org>
You have the code, look at the first post, you can render it yourself at
any resolution you want.
Date: 25 Sep 2010 14:35:01
Message: <web.4c9e40ab27cc93674b72cc9c0@news.povray.org>
> this:
Appetizing!
