I need some help figuring out this output I'm getting (Attached). I can't tell
if its a bug or someting else that I just don't know about like surface
coincidence. I don't recognize what might be causing the planar like objects.
The spherical sweep code is
#declare i_start = 0;
#declare i_stop = 3;
#declare i_step = 0.05;
#declare i_inc = i_start;
sphere_sweep {
linear_spline // linear curve
//cubic_spline // alternative spline curves
//b_spline
(i_stop - i_start)/i_step + 1, // number of specified sphere positions
#while(i_inc<=i_stop)
#declare y_coor = 0.23*sin(7.1*i_inc);
<i_inc, y_coor, 0>, 0.05
#declare i_inc = i_inc + i_step;
pigment{color Orange}
The scene file is
#version 3.6;
global_settings {
assumed_gamma 1.0
location <0, 0.0, -4.0>
direction 1.5*z
look_at <0.0, 0.0, 0.0>
sky_sphere {
gradient y
color_map {
[0.0 rgb <0.6,0.7,1.0>]
[0.7 rgb <0.0,0.1,0.8>]
light_source {
<0, 0, 0> // light's position (translated below)
color rgb <1, 1, 1> // light's color
translate <-30, 30, -30>
plane {
y, -2
pigment { color rgb <0.7,0.5,0.3> }
sphere_sweep {
Can someone explain this?
Download 'sun20100327a.png' (15 KB)
Preview of image 'sun20100327a.png'
>tell
> objects.
Sphere sweep has been buggy since it's introduction in 3.6...
Here's a workaround that uses a macro instead...
// a sphere sweep
#macro Sweep(SPL, from, to, rez)
#local eval_to = to;
#local C = from;
sphere {<SPL(C).x,SPL(C).y,SPL(C).z>,SPL(C).t}
#while (C<eval_to-rez)
cone {<SPL(C).x,SPL(C).y,SPL(C).z>,SPL(C).t,
<SPL(C+rez).x,SPL(C+rez).y,SPL(C+rez).z>,SPL(C+rez).t}
sphere {<SPL(C+rez).x,SPL(C+rez).y,SPL(C+rez).z>,
SPL(C+rez).t}
#local C=C+rez;
// a spline for the sweep
#declare wave = spline {
natural_spline //linear_spline
#while(i_inc <= i_stop)
i_inc, <i_inc,0.23*sin(7.1*i_inc),0,0.05>
#local i_inc = i_inc + i_step;
// the sweep object
union {
Sweep(wave,0,3,0.005)
Am 28.03.2010 05:50, schrieb Woody:
That looks... um, shall we say, "interesting"? :-)
Seriously, that's a bug if I've ever seen one (and I've seen a few ;-)).
Obviously not only the cubic_spline sphere sweep needs reworking, but
also the linear_spline variant.
Save the code, it looks like a Dragon to me...
Eric
> sphere_sweep {
> //b_spline
> #end
> The scene file is
> #version 3.6;
> global_settings {
> assumed_gamma 1.0
> camera {
> location<0, 0.0, -4.0>
> direction 1.5*z
> look_at<0.0, 0.0, 0.0>
> sky_sphere {
> pigment {
> gradient y
> color_map {
> [0.0 rgb<0.6,0.7,1.0>]
> [0.7 rgb<0.0,0.1,0.8>]
> light_source {
> color rgb<1, 1, 1> // light's color
> translate<-30, 30, -30>
> plane {
> y, -2
> pigment { color rgb<0.7,0.5,0.3> }
> sphere_sweep {
> #end
It's just another instance of the sphere_sweep bug that receive so much
comments these days.
The interesting thing is that the linear_spline shows all those
artefacts while cubic_cpline is clean, and b_spline mostly clean but
does show a small artefact on the right. (a slight, narrow, black line)
Maybe the readon I normaly don't have much artefacts, I tend to mostly
use cubic_spline in my scenes.
Best----> cubic_spline
Correct-> b_spline
Worst---> linear_spline
Revised picture and code going into bug system
global_settings {
assumed_gamma 1.0
direction 1.5*z
light_source {
sphere_sweep {
Download 'bugtest.png' (35 KB)
Preview of image 'bugtest.png'
