POV-Ray : Newsgroups : povray.binaries.images : Landscape tinkering Server Time
18 Feb 2025 17:07:58 EST (-0500)
  Landscape tinkering (Message 1 to 7 of 7)
Subject: Landscape tinkering
Date: 10 Feb 2010 12:05:00
Message: <web.4b72e697fa96b794b1680dd30@news.povray.org>
I have been lurking on these newsgroups for a little while now, and since I have
been raytracing again I thought I would post something.
I've been working with pseudorandom landscape generation --seemingly a phase
many people go through :) and here is one of the more interesting landscapes
that I have come across so far. Sorry for the very boring texture, no other
objects, etc.
function pattern dents - function pattern granite
Cheers!
Download 'landscape testwip21.jpg' (78 KB)
Preview of image 'landscape testwip21.jpg'
Subject: Re: Landscape tinkering
Date: 11 Feb 2010 10:00:53
Message: <4b741ba5@news.povray.org>
A nice startup.
Now, you can populate it with some grass or plants.
Paolo
> objects, etc.
> Cheers!
Date: 15 Feb 2010 09:38:12
Message: <4b795c54@news.povray.org>
High!
> objects, etc.
Interesting... as I myself started tinkering with a whole isosurface
planet, I would like to know how you combined the two functions, i. e.
what amount and scale for each!
My isosurface landscape (see below) currently is a combination of
x*x + y*y + z*z -1 for overall spherical shape of the planet,
granite, scaled to 10 and using a poly_wave with exponent 0.3333 for the
mountain ridges, finally
bozo for large-scale variance of elevation
The amount (multiplication factor within the combined isosurface) of
granite is 0.02, of bozo is 0.01.
Here my code:
#declare Terrain_Part1_Function=
function
   pattern
     granite
     scale 10
     poly_wave 0.333
#declare Terrain_Part2_Function=
function
   pattern
     bozo
#declare S =
function { x*x + y*y + z*z -1 }
#declare Ghurghusht =
union
   isosurface
     function { S(x, y, z) + Terrain_Part1_Function (x*50, y*50,
z*50)*0.02 + Terrain_Part2_Function (x, y, z)*0.01 } // f_noise3d
(x*100, y*100, z*100)*0.007 }
     contained_by { sphere { 0, 1 } }
     max_gradient 10
     accuracy 0.0001
     texture
       pigment { color rgb <0.98, 0.85, 0.45> }
       finish { ambient 0.05 diffuse 1 brilliance 0.98 }
   scale 5178 // radius in kilometres
Currently, I have not yet rendered a close-up surface view in
"pedestrian" perspective (only a close-up of the planet's limb at the
equator, see last image)... but I think I'll replace that simple granite
function later on by ridged_mf or a similar more sophicisticated
function to get wider lowlands at 0 to 200 metres elevation around the
lakes (see cylindrical map). Then there is also the problem of modelling
realistic erosion/drainage patterns...
See you in Khyberspace!
Yadgar
Download '2010-01-24 ghurghusht, lakes hemisphere, take 1.jpg' (180 KB) Download '2010-01-26 ghurghusht, highland hemisphere, take 1.jpg' (146 KB) Download '2010-02-05 cylindrical map of ghurghusht, take 3.png' (935 KB) Download 'ghurghusht0186.png' (348 KB)
Preview of image '2010-01-24 ghurghusht, lakes hemisphere, take 1.jpg'
Preview of image '2010-01-26 ghurghusht, highland hemisphere, take 1.jpg'
Preview of image '2010-02-05 cylindrical map of ghurghusht, take 3.png'
Preview of image 'ghurghusht0186.png'
Date: 16 Feb 2010 11:52:43
Message: <4B7ACD5A.7000500@gmail.com>
> High!
[snip]
For some reason this made me wondering how a planet(oid) would look like
with
http://upload.wikimedia.org/wikipedia/en/5/51/Cosmic_Background_Imager-_CMB.png
as a hightfield.
Date: 16 Feb 2010 12:19:36
Message: <4b7ad3a8@news.povray.org>
High!
> with
> as a hightfield.
Not really good - as the bitmap is neither seamless in the x direction
nor stretched appropriately towards its upper and lower edge along the x
direction to match the cylindrical projection! Also, then its x:y ratio
should be 2:1!
Yadgar
Date: 16 Feb 2010 14:27:19
Message: <4B7AF195.6060400@gmail.com>
> High!
>> like with
>> as a hightfield.
> should be 2:1!
This is only a small part. Obviously the whole thing should be seamless
and fit on a sphere, because that is how they measured it.
Date: 17 Feb 2010 04:03:11
Message: <4b7bb0cf$1@news.povray.org>
"andrel" <byt### [at] gmailcom> schreef in bericht
news:4B7### [at] gmailcom...
>> High!
> [snip]
> with
> as a hightfield.
I suppose that the whole cosmic background radiation map would look more or
less like a height_field using bozo...
