Hi there,
I'm using the brick pattern to simulate the texture of ballistic nylon. Here's
the texture definition:
#local BallisticNylon = texture {
pigment {brick color Black transmit .3, color Black transmit 1}
scale <.05, .05, 1>
The texture is layered over another texture and then applied to a plane {z, 0}.
I noticed that when I render the image at 4000 x 3000 pixels then resize it to
1280 x 960 it looks great, but when I render it at 1280 x 960 it looks horrible.
The attached image shows what I mean. In both cases I'm using +am2 +r3. Am I
doing something wrong?
Dave Blandston
Download 'brick normal.png' (41 KB)
Preview of image 'brick normal.png'
Dave Blandston wrote:
> Hi there,
> scale <.05, .05, 1>
> Regards,
> Dave Blandston
It looks like something akin to a moire pattern to me. Can you post an
original 1280x960 image showing this problem?
Because the brick pattern is close to the resolution of the render (ie
the mortar gaps are about 1 pixel across at 1280x960) the AA sampling is
not good enough to correctly render the pattern. I suggest you look at
the AA options in the manual section 2.1.2.8.4, especially the
Antialias_Depth option.
Rarius
> Rarius
That was the problem. Lowering the aa-threshold to +a0.0001 seems to have fixed
everything. Thanks for the suggestion!
Dave Blandston
